Question about HP Compaq NC6400 Business Notebook
No display Hi i have a hp nc6400 with the 128 ati board and one day it was working then just went of comletely stumped. Everytime on boot up no display have checked most parts CPU, memory all fine as i have another machine. Even the screen works do i need a complete new board or is there a wayto repair the original one thanxs in advance.
  • brogandbrit Dec 12, 2008
    Yes have checked all that prior to posting have now found out it is indeed the board. There is a chip underneath the processor that appears to have fried not sure if it has shorted on the casing mmmm.
    Problem Solver:
  • 14 Answers
Basic diagnostics when you experience display problems
Display is black?
Does the external vga output works?
Yes >> only your display assembly is defect
No >> your mainboard is defect
Mostly it results in the replacement of the complete mainboard.
Last things you can trie is flash a new bios version using the the external output if that works.
Posted on Dec 12, 2008
NAD T752 display totally lit up. FM sound works but no frequency display.
Sounds like display driver board {IC} has damaged. Contact any service technician. Electro help
Dec 08, 2014 | NAD T752 A/v Surround Sound Receiver
Ato x600 hp pavillion won't boot
You could try disabling the on board video in BIOS.
Feb 04, 2013 | HP Pavilion Computers & Internet
Slimline if on, but won't boot up and there is no signal being output to the monitor
HP had a lot of problems with these PCs, the video card is on-board and seems to be failing a lot. They even had a recall on these, but unless it is still under warranty you are out of luck. I am currently working on one right now that has the same problem. I installed a low profile ATI 4600XT video card and still nothing. I went into the BIOS and somehow navigate to the right spot to tell the PC not to use the on-board, but instead use the PCIe. It was a real pain when the screen is having a sync problem and everything looks funky. But even after that it still tries to boot using the defective on-board. Hope this helps.
Sep 29, 2009 | HP Pavilion Slimline S3123W Desktop PC -...
ATi radeon HD4650 issue
First enable you onboard video the connect your monitor to it. Insert you ATi video card in the mother board. Boot up. Install the ATi driver. Shutdown. Trasfer the monito to ATi video card. Then enjoy with you new vedeo card!
cheers!
Jul 18, 2009 | Computers & Internet
ATI Radeon HD 2400 Pro install - computer won't boot when added
Click here to for your computer product specification.
ATI Radeon HD 2400 Pro is a PCIe and your computer is compatable only for PCI
hope this helps,
Thanks, Prem
Feb 18, 2009 | ATI Diamond Multimedia Stealth RADEON HD...
With ASUS M2N-MX mainboard, ATI Radeon 7000 Series problem.
Your Motherboard has an onboard video chipset made by Nvidia. Nvidia and ATI have a history of not playing nice with each other.
I have 2 possible solutions for you.
1.) Remove the Radeon card and use the Nvidia onboard card (Essentially a Geforce 6100)
2.) Enter the bios (Usually done by hitting <Delete> or <F12> while the computer is booting up) Your Motherboards manual can tell you for certain. Then find the options for onboard video and disable it.
Then boot up the PC, When it say starting Windows press <F8> to bring up the windows boot menu. Select "Start in Safe mode" Once this loads up open the device manager, look under "Display adapters" find the entry for the Nvidia adapter, right click on it and select either "Uninstall" or "Disable this device"
Which you choose depends on your personal preference Whether you like Nvidia or ATI boards better.
If it makes your decision easier a Geforce 6100 is roughly equivalent to a Radeon 8500 in performance.
I hope this helps
Dave
Nov 11, 2008 | ASUS M2N-MX Motherboard
Ati video driver
You're ATI video card has software called VPU recovery. You can shut that off in you're display properties. Suggest you upgrade you're current display drivers. If you are running Windows XP any version, than click on the link below & download the latest driver combo for you're notebook. Creat a folder on you're desktop & save the download into that folder.
After the download is complete, open add/remove programs & uninstall the older driver software. (Do not restart you're notebook)! Install the new driver combo. Than restart you're notebook.
ATI mobility radeon driver link. Choose the correct card.
http://ati.amd.com/support/driver.html
Good Luck!
Mike
May 17, 2008 | ATI Mobility RADEON Graphic Card
Radeon ATI 9600XT video card
Try this, I just tested (2 days ago) an Albatron that arrived here with a 9800pro, crashing everytime they tried to play games.
I installed the latest drivers etc that "should" have resolved the issues...It made it worse. Updated everything including the chipset etc.
After driving myself crazy for several hours I installed the Catalyst 7.3 drivers... Away it went fine, tried the 7.4 (same problems as before), back to 7.3 and fine again.
So with Albatron boards and ATI cards, try the Catalyst 7.3 driver located <HERE>
Apr 16, 2008 | ATI RADEON 9550 Graphic Card
Problem with Video on HP Pavilon Laptop
are you sure your using the right ati driver ?
Try downloading the one for you laptop on the hp website
or
try downloading the ones from here
http://omegadrivers.net/ati.php
Feb 25, 2008 | ATI Mobility RADEON Graphic Card
HP Compaq NC6400 Business Notebook Logo
245 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
