Question about Brother SE-270D Computerized Sewing Machine
Thread tangles under throat plate while embroidering
I have a problem while embroidering with my Brother SE-270D. It usually happens when embroidering a denser design. The upper thread tangles under the throat plate, causing the stitching to eventually stay in one place and then bunches the fabric. I have to lift up the embroidery hoop as much as possible and get a scissor in underneath to cut the threads. The bobbin is wrapped with tons of thread. There is a hook about an inch long that seems to be stuck over the bobbin area. I have pushed (with force) this hook back so that it aligns with the side of the inside of the machine. Have I broken something? I am using bobbin thread for embroidery. My tension is set at about 2-3, because anything tighter seems to make it worse. I am using a Size 15 bobbin, but not necessarily the one that is made for a Brother machine. Any help would be much appreciated. It is extremely frustrating. I would have to drive almost 70 miles to get it looked at.
  • 1 more comment
  • Anonymous Nov 25, 2008
    I have the exact same problem and yes it is very frustrating!! This is a wonderful sewing/embroidery machine and I cannot get it to work right. Have not had it long. If anyone knows the answer to this please please give some feedback!!
  • AmyB55 Dec 01, 2008
    I have tried a few things since I posted this problem. I make sure that the pressure foot is up when I load the thread. I noticed that I did not always have it in the "up" position.
    Also, I used the 60 wt. Brother bobbin thread that came with the machine. I had been using bobbin thread, but noticed it was 70 wt.
    One other thing I did, but don't know if it would make a difference. I used a cone holder that I bought at JoAnn Fabrics that holds the thread spool separately from the machine.
    With these changes (and lots of praying), I was able to successfully complete 10 designs in a row with no problems. These designs were very small, from 1 - 2.5 inches, so not a real big design. But it used to give me problems with even this size. And some of these designs were dense in spots. I have to put a little pressure on the design part of the hooped item when it comes to the denser parts, as the hoop likes to "jump" up and down. I just use a little pressure with a blunt instrument.
    Anyway, having better luck, so I thought I would share these ideas. Actually got them from reading other posts and tried them.
  • krnolan Mar 27, 2009
    I've run into this problem over and over again as well. After googling and finding these same questions here (and I thank everyone very much for your fixes), I have to ask, has anyone ever talked to Brother directly? If so, did they have a solution? I'm very new at using my machine so at first I thought this problem was something I was doing wrong. I took the machine to a sewing class to learn to use it. That was the 1st time it ever came out of the box. It didn't come with an embroidery bobbin at all. Perhaps a factory mistake. I bought Brother bobbin thread and reusable bobbins (11.5 mm) which was suggested by the sewing teacher. Is this the wrong size bobbin? I also purchased a bobbin guide/riser which worked in class but not at home. I let my instructor know but she didn't have any suggestions other than, take it out. I also purchased a complete set of embroidery thread. The machine doesn't seem to like it for the self threading....it doesn't want to catch. I have to put on a head lamp and go VERY slow to get a catch, sometimes, several times. I'm so confused and there doesn't seem to be very good technical help on the Brother website,
Could the little hook that is stuck over the bobbin area be the thread cutter? My thread cutter gets stuck there and I have to turn my machine off and then try to use the cutter to reset it to its "resting" position.
Posted on Feb 04, 2009
Take the cover off or at least enough to blow the gear drives out around the area of the thread cutter. We use a air pump that you use to blow up an air mattress with. You will also need tweezers to pick out the thread etc. that gets wrapped around the gear and in the teeth. What happens is the gear drive gets clogged and does not turn freely.
Mary
Posted on Jul 26, 2009
    Problem Solver:
  • 9 Answers
I have this problem more frequently when I use a bobbin spool it doesn't like. It happens occasionally anyway but more when I use a different bobbin than it came with.
Posted on Nov 26, 2008
My thread keeps getting knotted up underneath. I have followed all the trouble shooting procedures and it still won't work.
Usually it is the top threading, tangled thread or a bent needle that causes that problem. You can call Brother at 1-877-276-8437 and maybe they can suggest something else to try.
Oct 01, 2010 | Brother SE-270D Computerized Sewing...
Having issues with my Se-270D can you help
The brother machines are notorious for jamming if there is even a tiny bit of lint in the machine. Take out your bobbin, unscrew the plate, take out the bobbin holder. Use a pipe cleaner or paint brush to brush all around inside the machine and pull out any little threads/lint that has collected in there. Replace the bobbin holder by lining up the screw toward the front. Replace the plate and screws. Make sure your bobbin doesn't have any little nicks around the edges that could catch thread. Replace the bobbin and rethread. Replace your needle (this needs to be changed often) rethread your upper thread. Test stitch.
Mar 16, 2010 | Brother SE-270D Computerized Sewing...
I have a Brother SE-270D. The top thread is not
A bent needle will cause this. Otherwise the shuttle is out of time, have it serviced..
Feb 09, 2010 | Brother SE-270D Computerized Sewing...
Brother embroidery machine broken
make sure the bobbin thread is wound and installed correctly
remove tangled thread and clean lint out from under feed plate
clean and remove shuttle to clean out area with lint brush
inspect bobbin for burs and scratches...make sure when reinstalling shuttle and bobbin that it rotates freely
hope this helps
Feb 04, 2010 | Brother SE-270D Computerized Sewing...
Bobbin thread comes out on top
You need to read the section of your manual that talks about thread tension. That occurs when your thread tension is off.
Dec 12, 2008 | Brother SE-270D Computerized Sewing...
Tangled thread under metal plate
-The bobbin is too lose. Tight the adjustment screw on the bobbin case a little more and test, keep doing until it's good.
-Or possibly the upper threat is too lose so it won't pulls the bottom up as well.
-Check it out and adjust it.
Good luck
Mai
Jan 18, 2018 | Brother SE-270D Computerized Sewing...
My Disney Brother SE-27OD Embroidery Sewing Machine/trouble
Make sure that your needle is put in the correct way, there is a groove in the front of the needle, check with your finger nail, this is usually to be facing you, and make sure the thread is going through the tension holder correctly do not have the foot down when you are threading the machine,as this stops the thread from going through the needle tension holder.
Sep 09, 2008 | Brother LS-2125 Mechanical Sewing Machine
Thread get's tangled and attached to plate while embroidering
Just a thought. Is it possible that your thread is wrapping around your spool post or snagging on your thread spool?
sewman7
Jun 09, 2008 | Bernina Artista 180
Top thread wraps around bobbin
Is it birdnesting under the bottom or it is actually getting tangled inside the bobbin case? I've had my machine for almost a year and don't think I've had your exact issue. Sometimes, when you do a stich over a already stitched portion, you may have a problem with the bobbin and I just generally stop and start it again. It is important that you use the correct needle and also use a good embroidery thread and stablizer. Another thing suggested is changing the needle after about every 5 designs. Also, check the bobbin case to make sure there's no fuzzies caught in it. I use "canned air" like you use on computer keyboards. I also only use 40 weight emboidery thread for the top and actual bobbin thread for the bottom. Other threads can really jam everything up. So it's been trial and error to find the right combinations. Good Luck!
Oct 30, 2007 | Brother SE-270D Computerized Sewing...
Brother SE-270D Computerized Sewing Machine Logo
674 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
