Question about RCA H115 MP3 Player
File system corrupted
I dont even know how it happened. One day i just turned it on, and i noticed it was taking too long to load, so i pressed the button in the middle and....file system corrupted. Is this fixable?
  • Anonymous Feb 05, 2009
    Solution provided:
    Fist you press the middle button, far on you press the on button, then you press the music and what not button and it should work just fine if you have and questions about computers just email me
    What does this mean? The first step makes sense, from there on it's just mumbo-jumbo.
Fist you press the middle button, far on you press the on button, then you press the music and what not button and it should work just fine if you have and questions about computers just email me at...ifixitcomputers@live.com
Posted on Dec 26, 2008
Drive is write protected. Running XP 64.
This seems to be the problem of most of us these days and some of our readers who wanted to know the methods how they can remove the Write Protected error from their USB drives like Pen Drives and memory cards.
What is Write Protected error and why it happens?
In the Write Protected error, we can’t write or copy any data in our flash drives and even can’t format the drive.
There are many reasons that cause this problem, let’s see solutions of them.
Solutions:
• First of all try to locate a small switch (if any, that you may have not noticed) at some place on the drive or memory card reader. This is the prime reason for this error. If there is one, switch it to the other side to turn the protection off.
• Yes I know this problem is also occurring these days without this switch but not to worry. Just download this helpful software form here
http://www.softpedia.com/get/System/Hard-Disk-Utils/HDD-Low-Level-Format-Tool.shtml
and run it to execute a “low-level format” on the drive. This software is quite handy and may take few attempts to actually remove the error.
• The problem can also be caused by some virus activity so just get it scanned by some updated good anti virus which may solve your problem.
• BUT if none of the methods listed above solves your problem then your pen drive might have gone corrupted, so just get it replaced.
Hope any of the methods listed above solves your problem.
Update 1:
After the low level format, you may need to “Partition the drive“. Dont worry, partitioning a pen drive means allocating it its File System and Cluster Size that was lost after the Low Level Format.
For that:
  1. Run diskmgmt.msc in Run.
  2. In the disk management window, select the pen drive, right click on it and click on Format.
  3. Now choose the File System and Allocation Unit Size and do not check the boxes below.
Click OK and the drive will be reusable after this.
Update 2 (Better Solution):
Follow the steps in this post and just put the value 0 (zero) in step 5.
This will surely solve your problem now.
rate me and vote me..
Nov 21, 2009 | SanDisk Sansa Shaker SDMX9N-512 MP3 Player
Sansa clip files are write protected, can't delete songs
Solutions:
Update 1:
For that:
Sep 08, 2009 | SanDisk Sansa Clip MP3 Player
Transcend tsonic 850 freezing up
If your MP3 player still has warranty, take it back to the store or get it repair. Try to avg scan all the files on your MP3 player and your laptop as well. There might be a possible virus or a corrupted file that is causing your T.Sonic to froze.
May 02, 2009 | Transcend T-Sonic 850 Digital Media...
Sansa e200 load main image failed
If this happened after updating your firmware, the Sansa FAQ from here http://www.sansa.com/support/sansa_e200/faqs says try this -
03. "Load image failed" appears after updating e200 firmware Applies to the following Operating Systems:
  1. Windows XP, Vista
This error may be caused by the firmware failing to load or the file system is corrupted.
STEP 1 – Reset the player
  1. Press and hold the Power button for approximately 30 seconds.
  2. Turn the player back on.
If the error persists, proceed to steps 2 and 3.
STEP 2 – Connect the player in Recovery Mode
  1. Turn off the player.
  2. Slide the Hold/Lock switch on top of the player so an orange color is showing.
  3. Press and hold the REC button and connect the device to the computer.
  4. A message will appear on the device display screen confirming the connection and a 16MB partition will be viewable in My Computer.
  5. Release the REC button.
STEP 3 – Download and update the firmware
  1. Download the firmware from the Sansa Forum.
  2. Open the zip file
  3. Extract all the firmware files to the 16MB-FORMAT drive.
  4. Disconnect the player.
  5. Slide the Hold switch to the unlock position.
  6. Turn on the player
Dec 29, 2008 | SanDisk Sansa e200 MP3 Player
Iriver h 10 mp3
OK, one day i turned on mu iriver and it's say's "system file missing to restore the system files connect to H10 to iriver and i dont know how to connect it.The other proplem when playing the music it's like a scratch CD i dont know how to fix it.
Sep 25, 2008 | iRiver H10 MP3 Player
Msg on player "file system corrupted"
Ribbin cable is loose inside from motherboard to hard drive. take it apart and slide it back in.
Sep 11, 2008 | RCA Lyra RD2762 MP3 Player
..file system corrupted...
if you specify "corrupted" then i may be able to help what exactly happened?
Mar 01, 2008 | RCA Lyra RD2765 MP3 Player
Cannot play file! File is corrupted.
I had that problem with music files. Said corrupt file whenever I played in shuffle/all mode. I fixed it very simply. Here's how.
On your screen (not computer, just your 605), open Menu, then hit Settings. At the bottom is System. Open that. When you do, you'll see your system info. There's a button that says "Update ARC Library." Hit it. It will take a few seconds, but you'll see everything new you've loaded being updated quickly. After I did that, I had no more problems. Hope it helps on your music, and also any other problems. paul4laffs
Feb 13, 2008 | Archos 605 WiFi Digital Media Player
Corrupt Files/Other?
Good Day, Have you tried reformatiing it? Over a period of time your info can get corrupt from transering music back and forth. To format plug it in to usb. Go to my computer It shows up as a removably disc, usually drive f: Right click on drive f: (or the approriate drive) and click format. Let me know what happens, you will have reload the player, also try bypassing the software you are using to tranfer, by opening up drive f: and clicking and dragging your music into it , or you can copy and paste it into drive f: L8R
Sep 16, 2007 | Philips GOGEAR SA6045 MP3 Player
RCA H115 MP3 Player Logo
166 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
