Question about Kenmore 24032\24036 Top Load Washer
Water will not drain during spinning
Put on new water pump but will not drain water from washing machine
kenmoore.also added a new wig wagger
    Sergeant:
    Champion:
  • 291 Answers
Look at the pump and make sure you have the arm in the slot or it will not switch over to drain the water out
Posted on Nov 24, 2008
Water does not drain during spin cycle. Tub spins, but water remains in the tub.
Water pump is out. Will need a new pump.
Only other possibility is your drain hose is clogged check that first.
Drain Pump Part #: AP5684706 Runs about $95:
Frigidaire 137221600 Drain Pump AppliancePartsPros com
Apr 18, 2014 | Westinghouse WWS833ES Super Capacity Top...
Hello I have a Maytag Washer Model A512 The machine goes through a regular cycle OK - However, it DOES drains the water out during the rinse cycle, but does NOT drain the water out during the spin...
The timer will always advance to the next program if the machine does not fully drain. There is ALWAYS a spin when draining the water out, there is only one pump and one motor. The waterlogged laundry maybe telling the timer that there is still water in the tub. Put the machine on "Spin" and cheat the lid switch into thinking that the lid is closed. Use a clothes peg or wide ended screwdriver and see if there really is a spin....
Apr 07, 2017 | Maytag Neptune MAH5500B Front Load Washer
Our whirlpool sport will not drain, 5d code has appeared. what can we do
SUDS LOCK (OVERDOSE OF DETERGENT DETECTED DURING THE WASH CYCLE)
If suds are detected continuously by the pressure switch during the drain or spin phases, the washer will fill 4 liters of water and during 5 minutes the unit will rest without tumbling, the water will be drained and it will try to spin or drain again.
Possible Causes/Procedure
• If too much detergent was used:
- Run the unit through a RINSE/SPIN cycle.
- Run a NORMAL cycle without adding any detergent,
• This should clear the unit of the excess detergent.
1. Check the drain hose and make sure it is not plugged or kinked.
2. Unplug washer or disconnect power.
3. Check wire harness connections to the drain pump, pressure switch, and Central Control Unit (CCU).
4. Check/clean drain pump filter of foreign objects.
5. Plug in washer or reconnect power.
6. Check drain pump.
7. Check the pressure switch.
8. Verify CCU operation by running a Diagnostic Test or any cycle.
Nov 30, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Washing machine wont drain keeps bleeping ERR2
It will not spin with water in.
See if you can locate a filter, and clean same.
Jan 19, 2010 | Haier Washing Machines
Hoover hpe 236. water not draining, stops mid cycle, lights flash
Have you checked the pump filter, and or that the pump is actually working. if it spins o/k with no water in, then I would suspect a draining problem.
If filter clean and pump o/k, then it could be a control module fault. if this were the case, then it would probably be wiser to purchase a new washer.
Hope this is of some help to you.
Jan 16, 2010 | Hoover Washing Machines
Water not draining during rinse cycle
check the drive belt for the pump under the machine
May 09, 2009 | Frigidaire ATF6000ES Front Load Washer
I manually put water in my washer; water stuck inside
drain hose kinked or belt off pump . lower drain hose to floor if empties the pump is the problem
Apr 17, 2009 | Whirlpool Washing Machines
MY 25062500 Kenmore Elite spins and clicks but won't drain.
I followed the advice from one of your postings about the Calypso pump, leaning the washer back and removing the bottom access panel. (Be sure to disconnect AC power first!!!). Heeding the warning about "lots of water" -maybe 10-15 gallons!!!-I removed the back access panel and loosened the drain hose, then I put a pie plate beneath it to pool the H2O as it rushed out, cranked up the shop vac undid the hose and let it rip. I filled my shop vac 3 times!). Then I tipped the washer back removed the the pump which is on the right, opened it up and cleaned out the impeller. It works like a champ now. Thank you for your help!!
Dec 27, 2008 | Kenmore 22422 Top Load Washer
Washing machine not draining
If you are confident you can do it pull your pump off washing machine and pull the pump houseing apart most will come apart and make sure there is nothing in the pump maybe a small piece of plastic or other item in it. you could also try taking the hoses off the pump and just flush water through it backwards this will also sometimes work I have come across this a lot and normally it is something in the pump interupting the water flow. There may also be sand or small pebbles in the drain holes under the adgitator if flushing the pump doesn't help check under the adgitator for something in the holes. Hope this helps
Jul 21, 2008 | Whirlpool LBR4132JQ Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
65 people viewed this question
Sal De
fordexpert
Robert Rankin
