Question about Dell XPS M1330 (dydotv2_6) PC Notebook
Error code 2000-0148 unit1 IDE. Error
It
2 Suggested Answers
SOURCE:
  • 11800 Answers
SOURCE: Dell Inspiron 5100 will not boot. Error ide
The hard disk is dead, it must be replaced and Windows reinstalled .
Posted on Oct 28, 2009
Testimonial: "Thanks, sad but true. It is an older laptop and was bound to need an upgrade. Thanks again."
Need help trouble shooting stuck on black screen dell inspiron 1720 so ran Diagnostics this is what i get backError code 0148 Msg:error code 2000-0148 Msg: unit 0:Ide error: status 1A error registry 0020h...
Error Code 0148
msg: Error Code 2000-0148
msg: Hard Optical Drive 0 - incorrect status 1 A Error
Register: 0020h
sense information: (02-0401)
sense: 70h 00h 02h 00h 00h 00h 00h 0Ah 00h 00h 00h 00h 04h 01h 00h 00h 00h 00h
Sorry but you have a hard drive issue. Replace the drive.
Mar 10, 2014 | Computers & Internet
Resolve Error Code: C7 on SuperMicro Server
First check the OS compatibility for you motherboard here:
http://www.supermicro.com/support/faqs/os.cfm
Then, if compatible, check the IDE/SATA setting. Change the hard drive controller settings from IDE to AHCI or vice versa to see if the OS kernel panics on boot. If that does not work, please reply with your OS version and motherboard model.
Apr 12, 2012 | SuperMicro Computers & Internet
Dell studio windows failed to start. error code 2000-0146
the Error code was sited below as the (Disk Self Test) DST Log contains previous error(s)
in case of your error DST log contains previous error(s) doing a
chkdsk /r or a repair reinstall of xp might resolve the issue.
to resolve issue...
Error Code Error Message 1000-0141
or
2000-0141 No Drive Detected 1000-0142
or
2000-0142 Drive Self Test Failed Status Byte=XXh 1000-0143
or
2000-0143 Drive Smart Read Command Failed 1000-0144
or
2000-0144 No Support for Drive Self Test Error Code Error Message 1000-0145
or
2000-0145 Timeout waiting for Drive Self Test to complete 1000-0146
or
2000-0146 DST Log contains previous error(s) 1000-0147
or
2000-0147 Unit (x): IDE status failed. Status byte = (x) Control Code = (x) Msg = (s) 1000-0148
or
2000-0148 IDE ERROR: status (x) (s)
Aug 07, 2010 | Dell Studio 17 Laptop
Oct 28, 2009 | Dell Inspiron 5100 Notebook
Toshiba satellite error code ide #0 error
IDE #0 is where your hard drive connects to your computer's motherboard. You may be able to connect your hard drive to IDE#1 or you will have to have your motherboard replaced.
Jun 28, 2009 | Toshiba P000392200 - Satellite A40, A45...
To solve code error 0146 and 0148
Hi there.
0146 error is DST Log contains previous error(s).
0148 error is
This could be a problem with the BIOS, restart the PC and hit F2 as it starts up, this will take you into the bios, reset the bios to default setting, press F10, save and exit the bios, the PC will restart so perform another check and see if the same error code return.
Good luck
May 29, 2009 | Dell Inspiron 6400 Notebook
E001
Check the fuser rollers for wear. When this occurs the rollers lose their roundness and get flat spots on them. This can cause the thermistors and thermal switches to bounce on thier surface and get incorrect readings. Should replace upper and lower fuser rollers every 150,000 copies (A4).
Oct 15, 2007 | Canon imageRUNNER 8500 Copier
Open Questions:
Dell XPS M1330 (dydotv2_6) PC Notebook Logo
101 people viewed this question
Clive
Clive
Alun Cox
