Question about Maytag MGR5770 Gas Kitchen Range
We have a Maytag Gas Range Model MGR5770 and it is showing a code of F-1 and will not reset. We just had the oven clean itself and when it was through it gave a Maint code of F-1 and will not rewset so we can use the oven. Help
  • dnickhawaii Dec 01, 2008
    My model CRG9800AAB is doing the same thing. We changed out the propane tank and then it started beeping at odd times. It is not the same beep as when the timer goes off. I don't even see my model number on the list of gas ranges.
  • nutella123 Mar 29, 2009
    we experienced the exact same problem with our maytag range (same model # as well). Following the self cleaning mode we received the F1 code and can't reset it.
  • 473 Answers
Here are the codes for magic chef:
F1 1. Watchdog on board
2. Touch membrane defective To determine which component is at fault, disconnect ribbon strip. If NO fault code, replace membrane, otherwise replace board F2 Oven too hot Check oven temperature sensor F3 F4 Open or shorted oven temperature sensor Replace F5 Hardware and watchdog circuits disagree Replace clock assembly (also called the ERC) F6 Missing AC signal Replace clock assembly (also called the ERC) F7 Function key shorted Replace touch pad F8 Analog/Digital converter Replace clock assembly (also called the ERC) F9 Door latch Check door lock circuit F10 Function key stuck Replace touch pad
Posted on Nov 18, 2007
  • 943 Answers
SOURCE: Maytag gas range model MGR5750ADW
hi thanks for the question the part you need is the oven sensor witch is located , in the oven top left /looks like a pen replace that part the number i got is 1365 from repair clinic . thanks the appliance doc
Posted on Sep 28, 2008
SOURCE: Maytag Gas range
Had the same problem.... just replaced the ignitor in the bottom of the oven... worked like a charm. 10 minute fix
Posted on Oct 22, 2008
  • 19396 Answers
SOURCE: Maytag MGR5770 Gas Kitchen Range displays OFF and nothing works!
That is normal, whenever you cut power the range goes in Off mode, that is a safety standby mode. The same as you first installed the kitchen.
No faulty thing and no need to take apart anything, do not disassemble the appliance.
The usual procedure to activate back the kitchen range is by downpressing the timer main wheel.
If this does not work, then there must be a different command, check the user instructions , or try playing withthe controls.
Posted on Nov 07, 2008
  • 1865 Answers
SOURCE: I have a Maytag Gemini double oven with a gas
18" is standard
Posted on Apr 16, 2009
F3 error code
F3-Shorted or open oven temperature sensor. Here is the part to order.
Dec 08, 2012 | Maytag MGR5770 Gas Kitchen Range
WHen turning on the oven to bake it will not ignite a flame. I can broil and cook on top however the gas will not lite when baking. The pilot is on however the gas will not burn unless banging on the part...
This is usually a symptom of a faulty oven safety valve. Over time, it tends to stick internally and banging on it helps unstick it. You can either continue banging on it for faster burner ignition or have it replaced. You'll need the make, model # and sometimes serial # if it's an older model, to replace the part. If you do it yourself, be sure to close the shut off valve behind the stove before you remove it. Douglas
Aug 18, 2010 | Maytag MGR5770 Gas Kitchen Range
Takes foever to warm up. Oven Burner flame is
hey could you please go back and givce the chat session a good rating for me so i can continue to help others like yourself
Jan 03, 2010 | Maytag MGR5770 Gas Kitchen Range
What would cause incomplete combustion on burners and oven?
Look at oven burners while  they are lit. Is the flame coming from all of the holes. If not, see if the piolet or glow coil of ignitor is close enough to that side to make them light.Also make sure holes are not dirty (opened).The flame should be blue with just the tip red . If not adjust the air door to get more air and less gas. Their is also a gas ajustment on the oven gas valve on most. If the flame is jumping out of the hole,too much gas is coming through and you need to adjust the screw to get less gas flow. I hope I understood correctly and this is information that you need.
Dec 14, 2008 | Maytag MGR5770 Gas Kitchen Range
most f-3 error codes are for the oven sensor. you sensor is probably bad and needs to be replaced. Joe
Dec 02, 2008 | Maytag MGR5770 Gas Kitchen Range
baking system-not lighting up.Code f-9 did show up.broiler works.Please advise
Sep 15, 2008 | Maytag MGR5770 Gas Kitchen Range
Maytag MGR5770 Gas Kitchen Range Logo
51 people viewed this question
Top Maytag Kitchen Ranges Experts
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
