Question about Video Cameras
Tape eject button not working on Sony ccdfx640 handycam
Trying to get this 1995 model working for my daughter. so far it is up and running except there is a tape in the recorder and the eject button will not operate. Batteries ok, records onto tape in camera. Please help!
DN
Portland, OR
  • Video Cameras Master
  • 586 Answers
     Your camera loading section get mechannically unstable.Contact any expert nearby to you to for mechanical adjustment.
   Thanks
Posted on Nov 23, 2008
Sony PC-105 - camera won't charge, hence tape will not eject. Is
I just had the same issue except I left my camera out in the rain. My camera is a DCRF-HC32 Sony Handicam. There is a reset button on the side of the camera where the eject door is. Take a paper clip and hold the reset button in for 5-10 secs. The camera will beep, power on, open the door and it ejected.
Jan 21, 2010 | Sony Handycam DCR-PC105 Mini DV Digital...
Cannot find way to eject tapecassette
Check eject lever near battery, press it downward to open tape compartment, take out old tape and put new tape, close tape door and let it go inside by itself. Close tape compartment.
Below image will help you to locate eject button/ lever in DCR-HC18E camcorder.
Thanks.
Sep 20, 2009 | Sony Handycam DCR-HC40 Mini DV Digital...
ERROR C:32:11
GO TO REPAIRING INTERNAL PROBLEM
Sep 09, 2009 | Sony Handycam DCR-TRV140E Digital...
My handycam sony steady shot , the tape deck will not open
Try using the battery charger while attempting to eject it. The battery, although you may not know it, probably cannot supply the power needed to open the tape deck. If it makes a little Ding sound when you press the eject button, that means it is trying to eject the tape. Hope this helps!
Jan 25, 2009 | Sony Handycam CCD-TRV318 Camcorder
Sony Handycam DCR-HC32 Not Working, Not Ejecting Tape, LCD Flicker
DCR-HC32 need new tape mechanism as shown in below exploded view.
Its part number is as follows..
A-1082-424-A MD (Z210) SUB ASSY
Nov 06, 2008 | Sony Handycam DCR-HC32 Mini DV Digital...
Can not eject tape
I had same problem, while transferring media from TRV-16 to DVD, tape would not play, then would not eject. This after transferring several tapes to DVD. I tried several things over the last couple months that did not work before finally getting it open today. It did me no good to remove several of the outer panels that were each held by two "tiny" phillips head screws each. Went to the internet, found your post, also found a post that referred me back to SONY page which follows.......
Follow this procedure to troubleshoot if the cassette compartment will not open or the tape is stuck and will not eject.
IMPORTANT: If your camcorder model has a RESET button, first try pressing this button. If there is no RESET button, or pressing the button does not resolve the issue, continue with the troubleshooting steps below.
  1. Turn off the camcorder.
  2. Remove the battery from the camera.
  3. Remove the AC power supply from the camera.
  4. Slide the power switch on the camera to the VTR , VCR or CAMERA mode for 15 seconds.
  5. Slide the power switch back to the OFF position.
  6. Connect the AC power supply to the camera.
  7. Attempt to open the cassette compartment.
"NOTE: If the issue is still unresolved after completing all of the troubleshooting steps, service may be required."
After I did this, I could hear a whirring sound when I hit eject, although nothing came out. While the whirring was going on, I pulled up and out with constant pressure and the cassette holder opened. The tape had jammed apparently as the little protective plastic tape guard was jammed partially open when I pulled the cassette out. Good Luck and don't be afraid to put a little pressure on the door if you can hear the door trying to open.
Now I turn to recovering the tape, but having grown up with cassette decks, don't believe it will be a problem.
Oct 14, 2008 | Sony Handycam CCD-TR416 Camcorder
Sony Handycam CCD-TRV37 Error code C:32:20
1. I removed the battery. 2. With the power switch On position and holding the tape ejected I inserted the battery back on & it ejected the stuck tape.
Jul 24, 2008 | Sony Handycam CCD-TRV37 Camcorder
Poblem with camcorder
i had the same code. so i went to the sony web site and thier is a reset function i tried and it works so far . first i toke the battery out then went to camara mode held the red button for 15 sec then put the battery back in . so far so good .go t0 sony web site and look for troubleshooting for your model
Oct 21, 2006 | Sony Handycam CCD-TRV318 Camcorder
Video Cameras Logo
181 people viewed this question
Top Video Cameras Experts
Are you a Video Camera Expert? Answer questions, earn points and help others
