Question about HP Computers & Internet
Hp Director for HP PSC1310 not loading - HP Computers & Internet
    Novelist:
    Scholar:
  • 141 Answers
I've had this problem myself before. You just need to un install the HP printer software and reinstall it again. Try not to have to go to the HP web site. Seems to have alot of 3rd party involved.
Posted on Nov 23, 2008
Hi There! I am having problem opening my hp director program
  1. Open HP Director using one of the following methods:
    • From the desktop : On your computer's desktop, look for the HP Director icon (c01425509.gif), and then double-click it.
    • From the Windows taskbar : Click Start , click All Programs , click the HP orHewlett-Packard folder, and then click HP Director .
    Although HP Director does not appear to be open , it is open and loaded into the computer's memory, but it does not open in a new window as usual.
  2. Without navigating to another open window, press Alt and Space bar at the same time. The Shortcut menu displays near the top-left corner of the computer. Figure 1: Shortcut menuc00833293.gif If the Shortcut menu does not open, repeat steps 1 and 2 until it does.
  3. Select Minimize from the Shortcut menu.HP Director displays (minimizes) as an item on the taskbar (the row of open software programs that appears at the bottom of the desktop screen). If HP Director does not minimize, click Minimize again until it does.
  4. Click the HP Director icon on the taskbar . The software opens and functions normally.
Dec 08, 2009 | Microsoft Windows XP Home Edition
Hp director does not open when i click on the icon
After installing (MS IE 7 or MS IE 8) browser on the computer that is connected to the HP product,This issue occurs on some HP products. The MS IE 7 or 8 browsers might be incompatible with HP Director
Follow these steps to use a workaround to open HP Director each time you use the software. These steps must be repeated each time you use HP Director.
1-Open HP Director using one of the following methods:
From the desktop : On your computer's desktop, look for the HP Director icon ( ), and then double-click it.
From the Windows taskbar : Click Start , click All Programs , click the HP or Hewlett-Packard folder, and then click HP Director .
2-Without navigating to another open window, press Alt and Space bar at the same time.
3-Select Minimize from the Shortcut menu.
4-Click the HP Director icon on the taskbar ( ). The software opens and functions normally. NOTE: The HP Director window and icons might appear larger than normal, but the software is functional.
5-Repeat Steps 1 through 4 every time you use HP Directo
Thanks,
Nov 30, 2009 | Computers & Internet
Attempting to scan several documents, when loaded in top of printer...says original loaded, then I hit scan and it says no scan options
see if you have hp solution center or hp director software updated. look for the dim on your lower right corner of the screen (if not there--click on start--all programs--start up--hp digital imaging)
update front panel list from the hp solution center or hp director
Oct 02, 2009 | HP Officejet 4315v All-In-One InkJet...
No longer have HP Director to control my scan/prints
It's most likely located somewhere around "C:\Program Files\HP\Digital Imaging\" and look for hpqdirec.exe
Nov 18, 2008 | HP PSC 1210 All-In-One InkJet Printer
Hp 6110 all in one hp director not working.
try to do the following:
1. Double-click the HP Director icon to load the program into the memory. You will not see HP Director open at this step. Do not click anything else on the screen until Step 2 is completed.
2. Press the Alt key and the Space bar together, and then
select Minimize from the menu that displays in the upper left corner of the window. If necessary, click it again until HP Director minimizes.
The HP Director software now appears as an item on the Task Bar .
3. Click HP Director on the Task Bar . The software opens and displays normally.
4. Repeat Steps 1 through 3 every time the HP Director software is used.
or
  1. Go to the HP Software Download Page .
  2. In the Enter a product number text box, type the printer model, and then press Enter .
  3. Under Product search results , select the printer model.
  4. Select the operating system.
  5. Under Update , click Critical update to resolve an issue with HP Director after installing Internet Explorer 7 .
  6. Follow the instructions that display on the screen to install the update.
Cause:
In October 2006, Microsoft released Internet Explorer 7. The HP Director software that shipped with some HP products introduced between 2002 and 2004 may not be compatible with Internet Explorer 7. The HP Solution Center software, which replaced HP Director software, does not exhibit this issue with Internet Explorer 7.
Sep 02, 2008 | HP OfficeJet 6110 All-In-One InkJet...
HP Director won't open. I am on XP and IE7
HP Director has a flaw and is not compatible with IE7
I have a psc 1100 and I had to update my software from HP
CHECK THIS OUT
Go to HP, this link, type in your printer model #.
It still may fail to show...if it does not show HP recommends this
work around.
Workaround: Open HP Director each time you use it If the update to HP Director is not available, or if you have installed the update and the HP Director window still fails to open, try this workaround.
  1. From desktop, double-click the HP Director icon to load the program into the memory. HP Director will not open at this step. Do not click anything else on the screen until Step 2 is completed.
  2. Press the Alt key and the Space bar together, and then select Minimize from the menu that appears at the upper left corner of the window. If necessary, click it again until HP Director minimizes. HP Director software displays as an item on the task bar (the row of open software programs that appears at the bottom of the desktop screen).
  3. Click HP Director on the task bar. The software opens and displays normally.
  4. Repeat Steps 1 through 3 every time you use HP Director.
    NOTE: The HP Director window might appear larger than normal, but the software is functional.
Cause In October 2006, Microsoft released Internet Explorer 7. The HP Director software that shipped with some HP products introduced between 2002 and 2004 may not be compatible with Internet Explorer 7. The HP Solution Center software, which replaced HP Director software on products introduced after 2004, is compatible with Internet Explorer 7 and does not exhibit this issue.
Apr 30, 2008 | Computers & Internet
HP PSC 1315
If the patch or the updates did not work on the link I sent you try this Workaround: Open HP Director each time you use it If the update to HP Director is not available, or if you have installed the update and the HP Director window still fails to open, try this workaround.
Mar 17, 2008 | HP PSC 1315 All-In-One InkJet Printer
Hp director
It could be about this: I had same problem until I found a review somewhere - even HP technical support was totally useless - until HP FINALLY decided to up date its drivers to account for my/many people's downloading of Internet Explorer 7. As this is now done, and you cannot easily uninstall IE7 and go back to IE6: try again (1) HP Director and if not (2) I think update drivers or (3) uninstall / reinstall. Hope it helps.
Apr 04, 2007 | HP PSC 2410 All-In-One InkJet Printer
Computers & Internet Logo
79 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
