Question about Bernina 2500DCET
The top needle is hitting the bobbin case Is the timing out?
The bobbin case is not lining up with the top needle
  • 192 Answers
SOURCE: Needle & Bobbin out of sync
This description sounds like the machine is out of time. The needle should match up with a cut out section in the bottom of the bobbin area. If it is hitting, the timing has slipped, probably from sewing on a fabric that was too heavy for the machine.
Posted on Nov 14, 2007
  • 1952 Answers
SOURCE: Needle is hitting something
tightng the needle bar . bobbin case screw is lose adjust the screw
needle portion is just adjust take bottam thread
Posted on Sep 04, 2008
  • 202 Answers
SOURCE: bobbin casing not in sync with needle.
When you have that hook drive gear back out turn the wheel until the needlebar is in its highest position. The bar with the teeth that the gear fits onto should be all the way to the right. Now slide the hook driver gear back on. You can lay the hook back in and slowly turn the wheel. Watch that the point of the hook on its upwards stroke is coming slightly above the eye of the needle. When it does this you will be in the correct position to put the screw back on.
Hope this helps. It may take a couple of tries but you will figure it out.
Posted on Nov 05, 2008
SOURCE: singer quantum cxl sewing machine needle hitting metal
Your needle is probably to long or you need to open it more
Posted on Apr 08, 2009
  • 128 Answers
SOURCE: Needle hitting bobbin case and breaking off
It sounds like the machine is out of time.. However, it is not an easy fix at home.
Posted on Apr 19, 2009
Needle hits bobbin casing.
Don't know if you have a manual or not. You can read the manual from the link below. I would look for the bobbin area in the manual. There should be a section showing the bobbin area for cleaning and oiling. It may as simple as removing and reassembling the bobbin case.
It could be the timing and would require a service repair technician.
Jul 11, 2017 | Riccar Sewing Machines
Needle hitting this and breaking. Pulling too ******* thread caught in bobbin case is the cause. How to fix or readjust?
breaking needles from hitting can be from several problems
1-- needle /hook timing is out
2--needle thread tension is too tight pulling needle side ways
thread caught around bobbin holder is top thread too loose
take it in for a service check as the needle /hook timing is complicated to adjust and the problem could be more complicated than suggested
Nov 23, 2016 | Sewing Machines
Needle Jams In Bobbin Case Area pfaff 1540
First, make sure there is no debris and scraps of thread in the bobbin area. I'm sure you did that already. I assume you also tried it with another thread just to be sure. I would suspect that the timing went out of whack. The machines depend on a synchronization between the needle motion and the bobbin action underneath. I once had a Singer that slipped and I had to reset the timing. If it is the timing synch problem then it would happen consistently and not work sometimes and then not work other times. G
Jan 27, 2014 | PfaFF Sewing Machines
I was sewing with elna machine and ran out of thread. This caused the thread to ball up underneath and "jam" the machine. I cleared it out and rethreaded it, but now the top thread doesn't catch the bobbin...
it is possible that the sewing machine has a timing problem, but check to see if the needle is inserted correctly into the needle holder
make sure the bobbin is inserted correctly into the bobbin case if the machine has a top loading bobbin
if the machine has a side or front loading bobbin also make sure the bobbin case is inserted correctly into the machine.
and also make sure the top thread has not come off the thread take up lever
Aug 20, 2013 | Brother XR-65t Mechanical Sewing Machine
Singer 2263 needle hitting something in bobbin area (loud thunk) and needle moves
try taking the bobbin out and putting it back in the bobbin
case if it's a top loading bobbin
if it's a side or front loading bobbin make sure the bobbin case is
inserted correctly
if the bobbin and bobbin case are inserted correctly then
it sounds like the sewing machine could have a timing
problem and needs to be checked at a sewing machine shop
Nov 12, 2012 | Singer 2263 Mechanical Sewing Machine
I took out parts of bobbin to clean and when put them back the needle hits the metal of the bobbin case and i cant sew. it doesnt seem to be properly aligned.
Perhaps remove the bobbin case and check that you have put it back correctly. Check with the sewing machine manual to see how it is done correctly. Make sure that the top of the bobbin case is at the top of the bobbin case holder and make sure you change the needle as it will probably be dull or bent from hitting the metal of the bobbin case.
Aug 27, 2010 | Bernina Activa 130
Needle hits bobbin case
If the needle hits the bobbin case the are only 2 things that could be wrong. Lets hope its the easy one, there are more than one length of needles, if the needle is to long or it is not all the way up in the neelde bar, the needle will hit the inside of the bobbin case. Now if that is not the problem then the machine is out of time. ALWAYS check the easy stuff FIRST.
May 20, 2010 | Sewing Machines
Needle hits the bobbin casing.
check to see the bobbin is in correctly first, is the needle in the centre?
Nov 23, 2009 | Sewing Machines
Singer Touch & Sew 7462 - Needle hits bottom of bobbin case
With the needle hitting the bobbin case , it sounds like it might be out of time. Which I am sorry to say is not an easy at-home fix.
Jan 17, 2009 | Singer 7462 Mechanical Sewing Machine
Sewing Machines Logo
60 people viewed this question
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
Level 1 Expert
Chris Wetmore
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
