Question about Roper RAS8445KQ Top Load Washer
ROPER 5 CYCLE HEAVY DUTY. PART NUMBER 3952435
ROPER WASHING MACHINE WILL PUMP BUT WILL NOT WASH OR SPIN DRY
  • downunda800 Dec 06, 2008
    Drum won't spin, just pump water. Agitator not spinning.
    President:
  • Roper Master
  • 2,651 Answers
Sounds like you have a bad motor coupling(part number 285753a, this machine equivelint to a belt.you tube has a few videos to aid you in this repair, search:: motor coupling whirlpool washer
Posted on Dec 08, 2008
I HAVE A Roper heavy duty 8 cycle 2 speed combination water won't come into washer machine nor will it work on any wash cycle, but will spin
If u have no water I SUGGEST CHECKING WITH A METER UR INLET WATER VALVE THE COILS MAY HAVE GONE BAD
ALSO MAY WANT TO CHECK THE WATER PRESSURE SWITCH MAY BE STUCK OPEN
Jun 02, 2015 | Roper Washing Machines
Producing debris when in spin cycle
2.13.1 Scrud
If fabric softener is used regularly it will eventually cause a build up within the outer bowl. This can
result in black flakes present in the wash load that can stain garments. To remove scrud follow the
procedure below.
Step1: Add a full cup of a good quality dishwashing powder such as Active or a similar product
into the machine.
Step 2: Set the machine to a Heavy Duty cycle, select a Hot Wash temperature, High Water level
and allow the machine to agitate for 10 minutes.
Step 3: Leaving the lid closed, turn the machine off and allow to soak overnight.
Step 4: The following day, turn the machine on and advance to the spin cycle to drain the water
from the machine. After the water has drained, turn the machine off then back on again, and select
a Heavy Duty cycle, Hot wash, High Water level, and allow the machine to complete a full cycle to
ensure that all of the loose scrud and residual detergent has been flushed away.
Note: If there is an extremely heavy build up the bowl will have to be removed for pressure washing
Dec 15, 2012 | Fisher and Paykel GWL11 Top Load Washer
I have a Roper Heavy Duty Large capacity washer # RAB5232EW. during every spin cycle it is unbalanced and knocks like it will jump out of the wash room. Please Help!
when empty turn it upside down it should have three springs holding the washing machine to the frame
one mabe missing if that not the prob try leveling the load and make sure the leveling leggs are all
toutching the floor good luck
Oct 17, 2011 | Roper Washing Machines
Washer will not empyy water or spin or wash on any cycle
something caught in drain pump, clamp hoses and remove pump inspect repair or replace.
Apr 04, 2009 | Kenmore 22422 Top Load Washer
Roper washing machine
does it spin? drain pump is directly mounted on motor, works in spin. may need new pump. Whirlpool standard pump.
Jun 03, 2008 | Roper RAS8445KQ Top Load Washer
Washer will not pass wash cycle...Will not Drain
Nightshade, in most cases, no spin, no drain is a lid switch problem. If you advance the timer to the spin position does it spin? If the machine is agitating you can rule out the coupler. If you are sure that it is not a lid switch problem, then you are probably looking at a bad timer....Catriver..post back.
Nov 08, 2006 | Roper RAS8445KQ Top Load Washer
Roper RAS8445KQ Top Load Washer Logo
281 people viewed this question
Top Roper Washing Machines Experts
Marvin
Marvin
Mike
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
