Question about HP Officejet Pro L7780 All-In-One InkJet Printer
HpL7780 wireless freezing up printer
Just bought this printer and was setting up the wireless wizard on it. I recognised the linksys system that I have, then said is was successful in setting up the wireless process then it freezes. the only solution to this that i have found is to plug out the printer power cord then reinsert it. The wireless does not work. It prints if connected via usb and it scans , havent tried the fax as yet. A number of persons online seem to have the same problem, some have solutions but these dont seem to work for me. HELP!!
  • 1 more comment
  • kris_campsmi Nov 23, 2008
    did this already still didnt work
  • teejack50 Dec 28, 2008
    The wireless connection work with my laptop as long as I am not connected to my verizon card. Can anyone tell me if this can be corrected?
  • magiles_me Dec 29, 2008
    I am experiencing the same problem. I am so frustrated, about ready to take it back to the store. Does anyone have any ideas at all.
  • 30 Answers
I have the same problem. But if the printer is close enough to the linksys wireless router, you can workaround it by connect it directly with a network cable.
Posted on Nov 23, 2008
  • timben Nov 23, 2008
    You will need to disable the wireless to undo the freeze. Follow the instruction on the HP site on how to disable the wireless.
    http://h10025.www1.hp.com/ewfrf/wc/docum...
I just bought linksys wireless router wrt120n but my labtop doesnt have cd driver hoe can i do the set up wizard with a cd?
Thank you for using FixYa
http://homesupport.cisco.com/en-us/wireless/lbc/WRT120N
you can download the installation application following the given link
Jul 20, 2011 | Linksys WRT120N Router
Connecting a brother hl2170 wirless printer to a linksys wrt54g
Take note all the wireless settings of the router first. Now go to the printer and Press Menu/Settings, look for wireless setup wizard. It should find the network, highlight it and connect. If it asks you for the network key, type your wireless network key. It only allows WPA-Personal(TKIP) and WEP. If you have WPA2 or AES, it will not connect
Sep 23, 2009 | Linksys Wireless-G WRT54G Router
I wanted to set up the printserver wirelessly but everytime my computer searches for the printer server, it only registers in the wizard if i connect the WPS54G to the router. If i do this, i am able to...
The printer and print server has to be connected to the wireless router by a network cable for you to print wirelessly from the laptop.
If possible connect a long network cable between the print server and the wireless router or move the router next to the print server and printer.
You maybe able to use a wireless repeater/extender but is it worth the added costs and complication. The extended range would invite hackers unless you secure your system.
Aug 01, 2009 | Linksys Wireless-G WPS54G Print Server
Problem with Linksys Wireless-G WPS54G Print, PS can't be found.
Check the settings on your wireless print server. And as well check your router.
Jul 26, 2009 | Linksys Wireless-G WPS54G Print Server
HP printer cannot find access point and I'm not sure what to do.
You must first connect your printer to the pc using usb cable, then run installation wizard that is on the CD that came with the printer.
Wizard will guide you through the setup orcess where you will provider your routers ssid (linksys) to your printer, and your printer will use that ssid to connect to your router.
After the Wizard setup is done, it will tell you to disconnect the usb cable and only then your printer will work on wireless.
Good luck,
Milan
Jun 01, 2009 | HP Office Equipment & Supplies
Appreciate any advice on how to set up Linksys Wireless G Router
here's a basic SoHo set-up.
But if your looking for manual, please provide me your e-mail address so that i can e-mail you.
Thanks.
Feb 09, 2009 | Linksys Wireless-G WRTP54G Router
Problem connecting my linksys WRT160N to pc.
Reset the router to factory defaults and reconfigure it. In case it doesn't work then try upgrading the firmware on the router. This should fix it.
Jan 31, 2009 | Linksys WRT160N Wireless Router
Conecting my Brother Wireless Printer
Hello....I'll try and help you make a start.
1. To find the settings you need to set up your printer, you will need to login to your router. Open a web browser, as if to view a web page, but instead type http://192.168.1.1 into the address bar at the top.
2. If successful, you are prompted for a username and password. If you have not changed these, leave username blank , and enter password: admin. Otherwise, please enter the password you have set.
3. If you log in successfully, you should see the Linksys router configuration screen.
Select the Wireless tab, and go to ‘Basic Wireless Settings’ > Wireless network. You should see here your SSID or Wireless Network Name, as required for your printer setup.
4. Go to ‘Wireless Security’. If the ‘Security Mode’ is set to ‘Disabled’, your system is Open or unsecured: your encryption type will be ‘None’.
If, however, it is set to WEP, your WEP key should be shown below. If it is set to WPA-Personal or similar, your WPA Shared Key should be shown below. This is the key described in your posting as the WPA2-PSK or Pre-Shared Key: it is also known as the network key, security key, or passphrase.
I think this covers all the settings mentioned in your posting. For further information, SecureEasySetup, AOSS and WPS/Wi-fi Protected Setup are shortcut methods to enable security on your router. Recent versions of your router model support SecureEasySetup.
You can download a copy of the manual for your router from the Linksys site: http://www.linksysbycisco.com/US/en/support/WRT54G/download
(You will need to check your router label for the correct version number.)
I hope this helps. This advice is based on the Linksys WRT54G user manual. However, please come back to Fixya if this is not clear or does not work for you.
Jan 18, 2009 | Linksys Wireless-G WRT54G Router
Linksys Wireless N adapter Missing Hardware.ID
Hi Kathy,
Please do this first. go to control panel>add/remove programs, uninstall the Linksys Wireless N adapter.DO NOT UNPLUG THE WIRELESS ADAPTER FROM THE PC. Insert the Linksys wireless N adapter cd(DO NOT RUN THE SET UP). If the set up wizard shows up CLICK exit or cancel.Restart the pc with the disc in and the wireless adapter connected. When the pc boots up you will see the found new hardware wizard. Continue with the wizard, Select No not this time, Select install software automatically. If this is successful, your pc should be able to detect your wireless network
Mar 10, 2008 | Linksys WRT300N Wireless Router
Trying to network xp pc to wireless laptop
Right click on the drive you want to share. Ex: C:\Vol-xx = name. In the pop up window click Sharing & Security. This needs done to all the drives you want access too. To share a printer. Everyone must have the printer drivers installed. The Pc that has a direct connection to the printer must also Share the printer on the network. Open Printer & Faxes, highlight the printer you want to share. Click File than click Sharing follow windows instructions.
Small suggestion regards to the wireless side of the network. Suggest you setup security so others close too you can not tap into your network. (common).
Feb 14, 2008 | Linksys Wireless-G WRT54G Router
HP Officejet Pro L7780 All-In-One InkJet Printer Logo
211 people viewed this question
Seeker5211
Seeker5211
