Have a 2001 yamaha 1600 roadstar. I replaced the starter relay and when i did, i touched the two leds from the battery and now there is no power when i turn on the key. I checked the fuses and nothing. is there a master fuse that is not in the fuse box?
SOURCE: 1994 Toyota Tercel Starter Problems
sounds to me that you have an igniton problem not a starter problem and or if you have or had an alarm system could be cause if u do give me feedback and i will explain but seems that your starter is fine from what u say but if you think in terms of the elemts to start a vehicle batery gives pwoer to ignition which sends to starter which gives spark etc i would check you ignition system something is causeing a short and not alowing starter to function
SOURCE: no power to starter 2004 chevy tahoe
Hi
It could be your neutral safety switch. It could be the starter relay which is located in the fuse panel box. It could be the smaller wire going to the starter could be loose or corroded.
SOURCE: turn on key no electrial,
Hi and welcome to FixYa,
There is a master fuse. It is 30 amps and is located at the side of the starter motor relay. To determine the location of this relay, follow the wire from the + terminal of the battery. The main fuse is responsible for supplying all the electrical power of the bike except for the starter itself.
Good luck and thank you for using FixYa
SOURCE: Intermittent fuel pump engagement when turning key - 2001 Taurus
try cleaning the connector that goes to the fuel pump, sometimes they corrode on inside. If that does not fix, test the wires feeding fuel pump with a multi meter until the condition shows itself again, if voltage drops to zero or very low then wiring problem, if voltage is unchanged with problem and fuel pump is not working and connectors are all clean, try replacement of fuel pump.
SOURCE: My 1998 bmw 528i won't start , I got dash light ,
all those problem have to do with modules on the vehicle have the car electronically scann and it will tell you where and what
