Question about SanDisk Sansa e250 MP3 Player
Wont work i turn on my player and then it continually goes to the black sandisk screen then it fades goes to a white screen and then the sandisk bit loads and continually does it over and over again
I have this same player and have not had this problem but i know how it happens, there is a problem with the boot loader. You have 1 option, deal with sansa support and have them send you the fix file via e-mail, putting it in recovery mode (turn on, switch to hold and hold REC. button) transfering the file they sent you and following the instructions on the screen.
Yo prevent this i recomend loading rockbox, it vertually partitions your sansa to boot into the rockbox os wich plays everything that the sansa played and all open source media (audio). instructuions in detail are at www.rockbox.org
Posted on Jun 07, 2008
Im also having this problem...i cant seem to find a solution although holding power down does switch it off when this happens
Posted on May 17, 2007
You need to hold power down for 15seconds then try turning it on again. mine only works after holding power down for 3sec then if it fails i need to reset a g a i n for 15sec. most of the time i need to try 3 or 4 times before it comes on.
I took out the battery and put it back in. It then worked.
Posted on Apr 28, 2007
Thats it.. the only solution is to charge it FULLY then see what happens. if that doesnt work.. .THEN IM GETTING AN EXCHANGE!
Posted on Feb 26, 2007
You'll Have to return it. It is a glitch with the software
Posted on Feb 25, 2007
Hopefully you find an answer, because i am having the exact same problem, please post your answer
SOURCE:
Sansa problems!!!
i recommend that you open it up and see if any connections are loose
May 07, 2008 | SanDisk Sansa E280 MP3 Player
Sansa wont work
Download the Sansa firmware upgrader and install it first. Then, hold in the volume + button on your Sansa player and connect the Sansa to your computer (while it is in the OFF position). The computer will recognize the player after you continue holding the volume + button for 5-50 seconds. Restart your computer. You will lose all files stored on the Sansa, but it will work again.
Mar 29, 2008 | SanDisk Sansa E280 MP3 Player
Wont work..
I would recommend you to go to the sandisk site to update the firmware on your device or you can contact sandisk to they can help you with updating the firmware on your device..Please follow the link below to get the firmware
http://www.sandisk.com/Retail/Default.aspx?CatID=1376
Should you have any problems after you update the firmware let me know and I will be more than happy to help you...
The number for sandisk is 1-866-726-3475
Please rate accordingly
Thank you
Computerrep
Bright White Screen
just turn of the player pressing the power button for 15 seconds, then turn the hold button on and off; turn it on and it's ready to continue watching
Jan 19, 2008 | SanDisk Sansa e250 MP3 Player
Screen black
Try to get a firmware upgrade done..once you have that done you should be able to use the device without having any problems..
Dec 30, 2007 | SanDisk Sansa e260 MP3 Player
Power goes out
easy fix my friend its temporary firmware problem . ok now to fix it plug the sansa in your pc ,just doing so can fix the problem if not ,unplug it from the pc the unit should have stayed on (the blue LED's of the wheel r on but no screen backlight) push the ON button on the side and hold it push for a good 20 secon then releass it that will make the unit do a soft reset and then turn it back on again it may chow the low bat simbol just plug it back in your pc the screen will show the turning arrow the backlight of the screen will work, let it recharge and there you go fix.
Dec 29, 2007 | SanDisk Sansa View 8GB MP3 Player - Black
My sansa wont boot up
Re - Format Your sansa drive
Dec 13, 2007 | SanDisk Sansa e260 MP3 Player
The best results that I have had were to hold the power button for about 15 seconds. ( if you only hold it for 3 seconds it goes into sleep mode). This shuts the device off. Then restart it.
Dec 12, 2007 | SanDisk Sansa e250 MP3 Player
Black screen
people have been having a lot of trouble with rhapsody i think you could have a bug in your system.
Oct 25, 2007 | SanDisk Sansa e260 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
59 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Joe Negus
Joe Negus
Gyula Lacz
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
