Question about HP Pavilion dv9000z Notebook
Large data transfer laptops, cable, or USB adapters DELL Lat-C
Want to transfer whole directories from one laptop to another, with
cable ( 9 GB of data or more) or at least large blocks of data.
I'm trying to avoid using flash-drive as a transfer medium, just
because a small sudirectory taken 5 hours just to transfer out.
1. from: DELL Latitude C series,
2. to: HP Pavilion ZE series
.... as both have only USB-1.0 port, and 25 pin ports.
I have also tried to use the USB-2.0 card bus (32 bit pc card)
model QFASCB, and made no difference.
Both laptops are 25 pins and USB-1.0.
Need your details (exact) how to cable (or other means) for
to transfer large blocks data between them, or need more
software; and tell me exactly, what that software is, where located,
to do this, and how to do this.
Appreciated, experts. Can I count on you?
The 25 pin port uses the printer. Any one knows how to keep
the ''25 pin printer'' (Cable ''pins''on the printer=HP LASER 2100), when it is performing so well, and use the USB at laptop, to print? A Very good printer, intent in keeping. Need ADAPTER or CABLE to adapt (printer 25 pin) to 'any' laptop (USB) port?
What cable, or, what adapter? (and...any software?)
Will this put a smile on your face?
  • diveonz Nov 23, 2008
    Why do I have to RE-ENTER my "problem-request" 5 times?
    Can you fix your computer, where ONE request entry is SUFFICIENT?
  • diveonz Dec 14, 2008
    What is PEER to PEER connection,
    How to construct such a cable called "PEER"?
  • 152 Answers
The system must surely have a ethernet port... why dont u try a peer to peer connection.... they can achieve very good speeds...
Posted on Nov 23, 2008
How I can transfer my files from a Acterna 5100E OTDR to my laptop? It only has a standard internal flash drive and 9 pin output. I have the original software.
This devices interface is extremely old technology the 9 pin connector is most likely a rs232 serial interface . If your laptop has a 9 pin rs232 interface you may need a DTE to DCE adapter .
if you do not have this old rs232 port on your laptop I think this device a usb to null modem rs232 DB9 Serial DCS Adapter Cable with FTDI.
from my reading of the manual a null modem may be needed
Nov 16, 2015 | Cell Phones
Trying to transfer data from an old harddrive i have (maxtor, diamondmax plus 9 80 GB ATA / 133 HDD) to My HP laptop
Install the hard drive into an USB hard drive adapter case the plug this USB hard drive into the USB port in your laptop. The laptop will see it as an external storage device, open the various folders and copy the files to your laptop.
You can delete any unwanted files off this external USB hard disk and use it for backups and file transfer.
Mar 14, 2013 | Computers & Internet
Iintend to change my sata hard drive to a SSD hard drive.How do I format before change
When you install Windows on your new SSD hard drive you can then transfer data from your old hard drive using an USB hard drive adapter or install the old hard drive into an USB hard drive adapter case and use it as an USB external hard drive after you have transferred your data to your laptop.
When you connect the USB hard drive adapter to the laptop, the laptop will see it as an external storage device, you can then open the various folders anf files and copy them to your new hard disk.
Apr 07, 2012 | Dell Computers & Internet
I have USB to USB data Transfer cable, lost the installation CD
Can't you use the cable with windows transfer wizard.Your PC should recognise the cable if it has plug an 'play.
Jul 12, 2010 | Computers & Internet
My laptop is broken and i want my data copy to my other pc
Maybe you need laptop drive enclosure? It can be powered by USB cable alone together with to and in data transfer.
Hope this helps.
Jan 18, 2010 | Hitachi HTS541612J9SA00 120 GB SATA Hard...
Dell Lat d600 laptop---9-Lock
Change the Location of the main memory , If it works then you have problems with the slot.
If it deosn't work then change your Memory!
Nov 03, 2009 | Computers & Internet
Can I put the harddrive of my dell 1525 laptop into the dell 1725
you can get an adapter that will allow you to connect your laptop hd to another pc through the usb port. Your hard drive is probably SATA so you would need a SATA to USB adapter cable.
Something like this cable would work.
Oct 05, 2009 | Dell Inspiron 1525 Notebook
USB data transfer from old to new computer
I answered you in another post, you need to network the computers via ethernet, not USB.
Jan 29, 2009 | Micro Innovations MCNCPQ5PHC USB PCI Card...
to print using a usb port to the printer install a network card which can be obtained from any printer repair shop
Nov 23, 2008 | Dell 5100cn Laser Printer
Data transfer
What I suggest you do is use the file transfer wizaed that is built n in WinXP OS's. From you old Dell go to start>Accs>System tools> file and Transfer wizard.....follow the prompts and save the file to your desktop. After the coolection and creation of the UMT2 folder copy it to a flash drive or use a cross cable between your old and new laptop and share the folder in th network s you can access it directly from your new laptop. Copy he whole folder to the desktop of your new Laptop. Run the same wizard on your new laptop.
May 21, 2008 | Lenovo ThinkPad T61 Notebook
HP Pavilion dv9000z Notebook Logo
160 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
