Question about Kenmore 24032\24036 Top Load Washer
Washer will not fill
My sears washer, Model # 110/20912990, will not fill with water. The spin cycle works on all cycles, but no water. Is it the lid switch or the timer. This happened from one wash to the next. I finished a load of clothes and didn't try to use the washer again for 2 days. When I loaded it, tried to set timer to fill washer, nothing. No sound. Nothing. So I tried the rinse cycle. Still nothing. I tried the spin cycles on all settings. It seems to work fine.
  • smokeyjoe778 Nov 25, 2008
    I"m going to try the water valve first. Thanks
    Sergeant:
    Champion:
  • 291 Answers
Not your timer / if anything its eather the water valve or the water slector switch
Posted on Nov 24, 2008
I have a GE spave maker Laundry that fills up with water than stops!
GE Washer Not Agitating Repair Guide
www.appliance-repair-it.com/GE-washer.html
If your washer will not agitate or spin take a look at this page GE Washer Not ... If the washer fills up with water then doesn't do anything at all and you do not hear ... if this were the problem, the water would not stop running, over-filling the tub.
GE washer spin cycle not working - ApplianceBlog
www.applianceblog.com/.../217-GE-washer-spin-cycle-not-working
Mar 12, 2005 - 10 posts - ‎3 authors
I have a GE "Spacemaker Laundry" (Stackable) model number ... Today it filled withwater initially then stopped working all together when it ... Bad motor, something jammed/seized up holding the motor back from running?
Jan 10, 2016 | GE Spacemaker Washer and Dryer Electric...
Washer filled, stopped. no cycle will work. switch
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
Newer model Whirlpool / Kenmore washers use a Lid Switch as a safety device. Unless the switch senses that the lid on the washer is closed, the washer will neither agitate nor spin.
Older models only used the switch during the spin cycle.
Try to bypass the Lid Switch by removing the Console and jumping the two outermost pins on the switch.
This is a Whirlpool PDF on how these washers operate. It has a diagram on jumping the switch as well as a detailed section on how the transmission works.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
It also has a troubleshooting guide.
To bypass the switch, you only have to disconnect the power to the washer, tilt the console back, unplug the switch and using an short piece of insulated wire, jump the two outermost contacts on the connector coming from the console and plug the washer back in.
Following is a description of how to gain access to the console and how to remove the cabinet if necessary.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=913ba652cd504fb162f87d892bcb427b
With the jumper in place, try to re-start the washer.
If it works, the Lid Switch is a relatively inexpensive part and only requires you to access the console and remove the cabinet.
Jun 25, 2010 | Kenmore Washing Machines
Washing machine will not wash
Apr 22, 2010 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Machine will not wash or spin it fills up with water and that all it will do
First, try the washer on a different cycle.
If it works, the problem points to the timer.
If it still doesn't work, the initial problem points to the Lid Switch.
Following is a description of how to release the console for access to the pins.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
If it works, the Lid Switch is a relatively inexpensive part, see the Sears parts site.
Dec 15, 2009 | Kenmore Washing Machines
I have a Kenmore top loading washer model #110 and won't agitate
First, see the Sears parts site for your washer.
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?pop=true&modelNumber=110.23912100
Also see the Whirlpool (Kenmore) Service Manual for top load, direct drive washers.
The first thing I'd try is using a different cycle. If the washer works as it should, the problem points to the timer.
I'd also check to make sure that when replacing the switch, the connections to the timer haven't come loose.
Since you've replaced the Lid Switch, the motor has power for the drain and spin cycles.
These washers use a reversing motor. The motor turns one way for agitating and reverses for the drain and spin.
Since you cannot hear anything when it is supposed to be agitating, the problem does point to the timer or motor.
Nov 14, 2009 | Kenmore 22422 Top Load Washer
Washer stopped at the drain cycle Model LSR8233JQ1
Could be either a bad lid switch or a bad water valve.
Set the timer dial to SPIN and turn the machine on.
If it spins the lid switch is OK. If it does not spin the lid switch must be replaced.
Next,set the timer dial on a wash cycle and set the water temperature knob to COLD water. If it fills,the lid switch is bad. If it does not fill the water valve is bad or the cold screen filter is clogged.
If the COLD does not fill,turn off the cold water faucet. Remove the cold water hose from the machine water valve and check for a clooged screen.
If it does not fill with COLD water and the screen is clear,replace the water valve.
Oct 27, 2009 | Whirlpool LSR5132PQ Top Load Washer
Sears Kenmore 80 series will not rinse or drain
A washer that fills and doesn't do anything, or stops right after the wash cycle and then does not advance to the rinse cycle and drain is commonly caused by a lid switch malfunction. The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug. If you determine the switch to be defective, the following link explains how to replace one:
http://www.fixya.com/support/r385198-replacing_lid_switch
If the switch requires replacement, a new one can be purchased on line at searspartsdirect.com, pcappliancerepair.com, repairclinic.com, appliancepartspros.com. Just use your model number as your search criteria. All these sites offer competitive pricing, so shop all them for the best price.
Take note of your symptoms:
1. Washer fills, may or may not agitate, will not advance to the rinse cycle, and will NOT drain - lid switch.
2. Washer fills, does NOT agitate or spin, but WILL drain - motor coupling.
If you still have questions, please let me know. If the suggestions I have listed do not match your washer symptoms, please post back and elaborate more on what the washer is/is not doing. That way I can provide you with better assistance. I hope this information is helpful to you.
Jul 05, 2009 | Kenmore 24032\24036 Top Load Washer
Washer fills with water and just sets there spin cycle works
The timer is failed in this case.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Mar 17, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Won't spin or drain
Check to make sure your lid switch is working.
Nov 17, 2008 | Kenmore 22422 Top Load Washer
Washer fills/agitates and stops prior to draining
If pump works fine or still pumps out water, then it is a timer malfunction. Replace the timer and you should be fine. To locate a part number for your timer, refer to www3.sears.com with the model number off your washer.
Mar 14, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
240 people viewed this question
Sal De
fordexpert
Robert Rankin
