Question about Motorola Talkabout FRS 250 (14 Channels) 2-Way Radio
Range dropped and eventually radio is dead
Radios were great when new. I actually recovered and repaired one that was run over by a car! At some point the range decreased to a few hundred feet so we stopped using them. Recently I got them out to troubleshoot, and they were just plain dead. No corrosion inside, no loose parts. Would like to find someone who is willing to repair them. Not many user-serviceable parts inside, so I wouldn't mind finding someone more qualified.
  • Moolant Lim Jan 02, 2007
    I guess now the question is whether or not these radios are worth sending out for repair. Does Motorola support the original Talkabout Plus anymore? I still see them around. They look more sturdy than the new ones, but maybe I should just replace.
  • 123 Answers
There is not much that can be done for this radios, a service Qualified for two way radios will be expensive. Check the battery contacts and verify that all the conections are correct, if one conection is missin the radio wont turn on. Good luck
Posted on Jan 02, 2007
  • Ernesto  Garcia
    Ernesto Garcia Jan 02, 2007
    I think you should better replace them, The talkabout series are unserviciables.
SOURCE:
How far is a two mile range reach
I suspect this question is not about Cars and trucks but about small low-powered radio transmitters.
The radiation from a transmitter is not predictable and can be affected by many local conditions. As far as low-powered hand-held type radios is concerned, the quoted range is likely to be the maximum range under ideal conditions, ie. in open and flat country away from all buildings and man-made structures.
The actual range of a pair of two-way radios stated as having a range of up to two miles could be as little as a hundred yards, depending on where they are being used.
Much also depends on the cost of the radios, the operating frequency and power output, whether digital and whether amplitude modulated (am) or frequency modulated (fm) and of course the effectiveness of the antennas.
If the police and other authorities could communicate just as well with 2-way kiddy radios from Walmart there would be no reason for the taxpayers to buy each of them a radio costing hundreds of dollars.
I suggest you test your 2-way radios (with fresh batteries) in flat open country and if the effective range falls far short of 2 miles it will be time to have a meaningful discussion with the retailer where you bought them.
Oct 01, 2016 | Cars & Trucks
I cant get my baofeng to scan
I don't generally like Chinese radios but baofeng makes a great radio and I find it hard to believe it has anything wrong. have you dropped or pressed heavily on the scan button on this radio? how long have you had it? do you have a copy of the manual? what model is it?if you could answer my questions I may be able to help you, I have been using baofeng radios for years and prefer them to my yaesu radios. on the off chance that you have a bad unit, I have encountered 2 in five years and baofeng repaired both without question free of charge.
Sep 29, 2014 | Radio Communications
What's the range
A quick google search yielded a theoretical range of 2 miles. This range is as the crow flies, and assumes an unobstructed open area, with no interference. In practicality, the radios will reach from one side of a side to another maybe a bit further. When Outside on a clear day in a city a football field or two will probably be the max. The range greatly depends on where you are located; buildings, power lines, and cars will interfere with the signal.
Oct 18, 2012 | Bell Northwestern Phones - 14 Channel...
Uniden Gmr3040
These radios don't use repeaters as far as I'm aware, but they put out a hefty 25 watts of RF power, but like all radios, this is based on LINE OF SIGHT, in other words as long as you don't have obstructions, buildings, hills, trees and the like between you and the recieving station, all should work well, on the other hand, if there is terrain and/or other obsticles, then this greatly impacts on the radio signal being transmitted.
Best solution is to get to a high vantage point, i.e,. on top of a tall building or hill and Tx away.
I hope this has been of help to you.
Regards,
Peter
Jul 21, 2012 | Uniden Gmr3040-2Ckhs 30-Mile Range 2-Way...
For any reason these radios lost communication in the floor near a range of 60 feet open area, employees have to move to a range of 40 feet in the center of the area to get good signal. Batteries are good...
Loss of range usually indicates a programming problem, such as having the radios on a near, but not exact frequency; or issues with the antennas. Check your programming and see that the frequencies/PL codes match one another, and that the users are on the same channel as one another when using the radios. Also check the power output setting (if it is visible to you in the programming software). These radios even on low wattage should be able to talk line-of-sight up to 2 mi. However, with VHF any obstacles greatly reduce the range.
If the radios worked fine in the beginning, and are failing now, you have to think back to what might have changed along the way. If you feel no changes have been made by you or the users, then you may have a bad radio in the mix, and it needs repair. (Flat rate usually around $85 USD)
It is doubtful their is anything external effecting the range. If you had radio interference, you'd likely have problems with static, general noise, and your radio's receiver opening up even when no one is transmitting.
Best regards.
May 06, 2011 | Motorola RDV5100 Two Way Radio
Mower runs great, problem is battery goes dead, its a new battery, i recharged it, measured the voltage at 13.41, started it, it measured 14.47 volts then drops a few decimals every minute like 14.42 after...
Try disconnecting the battery and note if the voltage drops.
If it does, the battery is not holding a charge.
If it keeps its voltage, the problem lies in a minor short in the mower.
You have to determine which item has the problem first.
Is this helpful?
Gary
Feb 28, 2011 | Cub Cadet Op's Manual Model Lt1042 Lt1045...
I have a Bose Wave radio which seems to be dead, no sound, Displa
There's a line fuse inside the radio, mounted on a PC board. CAUTION: disconnect the set from power before opening the case or poking around inside. The fuse could be bad, but these sets are notorious for losing the power transformer. If the fuse is ok then you are looking at a $100 repair fee from Bose. You might want to check out the new HD radios -- better sound, MUCH lower price.
Bill B.
Mar 28, 2009 | Bose Wave Radio II
Wanting to know how far this radio will communicate
In reality, handheld radios will talk line-of-sight up to 2 miles. When talking in and around buildings, the range can be reduced to as low as 1/4 to 1/2 mile. For optimal range, be certain to hold your radio with the antenna pointing straight up (perpendicular) to the ground. Height and placement of antenna determines range.
All that being said, many radio manufactures make claims of 5, 10, 18, 25 miles. These claims would be true if one radio can see another, such as talking from a mountain top to a valley. In the real world, we deal with curvature of the earth, hills, buildings, etc.
TalkAbout radios and the other FRS radios operate on 1/2 watt FRS, and 1-2 watt GMRS frequencies. Business radios on the other hand operate on up to 4 to 5 watts of power. The power does not always equate into extra range, it does however, provide much greater clarity in the fringe areas.
Hope this answers your question.
Jan 19, 2009 | Motorola Talkabout T5720 (7 Channels)...
Motorola T5000 Two Pack 2-Way Radio
Could be due to air blowing the mic or something but please remember that usually transmissions are fuzzy,
Sep 27, 2008 | Motorola T5000 Two Pack 2-Way Radios with...
Motorola Talkabout FRS 250 (14 Channels) 2-Way Radio Logo
54 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
Damen Wong
Damen Wong
Gene Pitts
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
