I want to set up a wireless router and right now my cable modem is connected to the netgear prosecure box and my computers are connected to the netgear prosecure box
Connect a LAN cable from the Netgear to the LAN port on yourcomputer, open a browser and enter the Netgear configuration URL -
http://192.168.0.1
The default login = admin
The default PW = passwordYou can now change the default admin password and configurethe wireless settings.
Go to the wireless configuration and set up the SSID and WPA or WPA2encryption.
Apply these settings to the wireless card in your laptop/computer.
To secure your wireless network from unauthorized access, please click on thislink and follow my instructions :-http://www.fixya.com/support/r3559128-wireless_router_security
SOURCE: NetGear wireless router model wpn 824 v2
SOURCE: Netgear 108 Mbps Router WGT624 v3
As you say that, you are able to go online with the modem, connect your modem- router and laptop witha cable and check if you are able to go online with the router wired first, if yes, then the w/ls settings has to be checked..open your w/ls network connection, remove your preferred wireless network and then try to reconnect again and check.. if you are not able to gon online wired with the router, disconnect power cables from modem- router , wait for 10 sec, and reconnect it , wait till all the lights come up and then reconnect, check if you are able to go online if not your router has to be reconfigured,,
plz check and revert back in case of any issues
SOURCE: quit working. shut off modem, router and
what we can do in this case to hard reset the router and then re-configure it.
steps for re-setting the router:-
a)You will find the very small/tiny circular pin hole on the rear panel of the device very close to the power
b)Use the paper clip or a pin to reset the device and keep holding the reset button for at least 30-35s.
c)Then , While holding the paper clip take the power cable out from the device , wait for 10-15s and then plug the power cable back to the device while holding the paper clip.
d)Wait for another 10-15s and then release the paper clip.
e)Once we have all the lights back on to the device then take the power chord out and plug it back within 30s.
5)Once we follow the instructions the router will be reset to the default setting's and the internet connection will be terminated
6)Open the IE page and in the address bar type the url:-http://www.routerlogin.com and then press enter key
7)A small window will prompt up which will ask you to type the user name and password which will be
user name:-admin
password:-password
and then left click on log-in.
8)Once you will left click on log-in it will navigate you to the router's administrator page which will be netgear smart wizard page from where you can configure the router's setting's.
Testimonial: "Awesome instructions and solution was spot on the first time I tried it. Thank you very much!!!!!"
SOURCE: PS3 and Netgear WGR614 V7 Router
Basically the PS3 wireless settings needs to be configures with the Netgear wireless router settings.
To test if the modem is connects to the Internet, connect a computer into the modem, if it works then the modem is configured correctly. If it doesn't work, then contact your ISP and get them to test your modem connection.
For details on how to configure the PS3 click on the WEB link :-
wii.php">http://fixhomenetwork.com/xbox-play-station-wii.php
SOURCE: Belkin 54g Router won't connect to internet.
If you can access the configuration page of your belkin router you have to copy the MAC address of your computer to the router. The router has the capability to clone the MAC address. It's because if you have a cable internet connection the MAC address is registered in the server.
