Question about Rockford Fosgate Punch 700S Car Audio Amplifier
Ohms load i have a rockford fosgate 700, I just want to know if it's ok to use these in 12"JLw7-3, 3ohms? please let me know and thankyou very much!
  • 113 Answers
U should be able to just dont wire the subs sown to 1/2 or 1 ohm I believe these amps can handle 2 ohms and above
Posted on Sep 09, 2009
Can I wire two p3 12 Rockford fosgate subs to a kicker 250.1 amp
It has two speaker terminals which allows you to wire muliple subs to the amp easier than trying to cram the wires all into one set of terminals. The two sets of terminals are wire in parallel internally on the amp, so it matters no which + or - you use on it. However, you need to remember they are already wired in parallel internally, so if you were to wire up two 2 ohm subs, the amp would see a 1 ohm load (which it's not stable at), not a 2 ohm.
May 04, 2015 | Rockford Fosgate Car Audio & Video
Can a rockford fosgate 500a2 run 1 ohm stable
yes, if you add a 1 ohm resistor to the negative terminal of speaker.
May 08, 2014 | Rockford Fosgate Punch 500a2 Car Audio...
How can i tell how many watts my fosgate 351m power amp is?
Specifications Dynamic Power Rating (measured at 14.4V):
  • 4-Ohm Load: 175 watts x 1
  • 2-Ohm Load: 350 watts x 1
Jan 29, 2013 | Rockford Fosgate Power 351M Car Audio...
Box specs for 1 fosgate hx2 12 for a jeep wrangler
go to the rockford fosgate site they will have info you need.
Oct 07, 2012 | Rockford Fosgate Punch HX2 RFD1212 Car...
Can I buy a rebuild kit for a rockford fosgate t1 12 d4vc
try going to rockford's website. http://www.rockfordfosgate.com/support/rftech.aspx
Feb 29, 2012 | Rockford Fosgate Car Audio & Video
Where's the fuse located in a Fosgate p300-1 amp?
It is just to the right on the rear of the amp next to the 12 V + - RTO +
Here is a link to a picture:
http://www.crutchfield.com/S-mj0Klw5sfLm/p_575P3001/Rockford-Fosgate-Punch-P3001.html
Feb 14, 2012 | Rockford Fosgate Car Audio & Video
Im looking at this rockford fosgate p700-1bd amp brand new for $300 it comes with a birth sheet it says 750 rms on a 1ohm load. i cant find any reviews about it 225 rms x 1 @ 4-Ohms 450 rms x 1 @ 2-Ohms...
You can't go wrong with Rockford, in my opinion. Everything they make is well built and high quality. I personally have two Rockford p500-1bd amps hooked up to four 12 inch subs in my car and those amps make those subs slam. I have them wired down to 1 ohm and the specs say that they should be pushing 500 rms a piece at 1 ohm so that p700-1bd amp really packs a punch. Depending on what you're hooking up to that amp I would defenitely recommend it to you. - Ryan in Alaska
Feb 15, 2011 | Rockford Fosgate P7001BD Car Amp
I have two 12" kenwood KFC-W3003 (svc) 4 ohm 600 watts max 160 watts RMS subwoofers and two 12" Rockford Fosgate Punch RFP-4812 (svc) 8 ohm 400 watts max 200 watts RMS. I was wanting to know how i...
It can't be done unless you choose to include some power resistors in your circuit for impedance matching. The problem with that would be some of your power will be lost in the form of heat across the resistors without the benefit of contributing any sound.
Also, the amplifier's damping factor will be compromised, so you may notice a loss in sound clarity. It's possible that you might not easily tell with subwoofers, depending on the enclosures they're mounted in, and whether they're isolated in a trunk vs being in the same airspace with you (hatchback, SUV, or pickup truck).
Nov 13, 2017 | Rockford Fosgate Car Audio & Video
Rockford Fosgate Punch 700S Car Audio Amplifier Logo
110 people viewed this question
Top Rockford Fosgate Car Audio & Video Experts
seankane89
Level 1 Expert
hoyzee1
Tygh Duval
Tygh Duval
Are you a Rockford Fosgate Car Audio and Video Expert? Answer questions, earn points and help others
