Question about Canon PowerShot A640 Digital Camera
My canon powershot a640's flash isnt flashing.
I have Flash turned on and when I try to take a picture, all I get is a orange light and the flash icon blinks on the screen.
  • 1 more comment
  • Anonymous Dec 15, 2008
    Same thing...only 2 years old...sigh.
  • leanne_3020 Jan 08, 2009
    I turn my camera on AUOT and I try to take a picture with the flash on and the orange light comes on but it wont take a picture. When I turn the flash off it takes a picture. It will take pictures on certain settings and on other settings it wont! Cant figure it out.
  • Anonymous Jan 09, 2009
    my canon A640 will not turn on i put new batteries and not a thing happens.....
I can't believe I just managed to fix exactly this problem on my camera.  Warning - the process hurt somewhat, but it did work.
I dismantled the case very carefully:  After taking the shiny grey cover on the screen end off (3 screws, noting carefully where each screw was), I took the top cover off.
That was a case of unscrewing three screws at the bottom of the battery compartment (I left them in place, as it looked tricky to locate them again, subsequently working with the camera upside down), then gently prising the top off - there is an internal clip just next to the visual viewfinder, which you have to wiggle a bit - just use a fingernail to prise it open.  The top lifts off - dangling on with its cable.
Here is the unpleasant bit.  Quite accidentally, I shorted the flash capacitor, by touching its circuit board - and got the most surprising electric shock.
I looked around to see if there was anything else I would be able to do, felt there wasn't, so I put it all back together, in the hopes that it might have fixed my problem.
Hey presto, I now have a working camera with working flash!
Posted on Dec 20, 2008
  • webmail2011 Jan 05, 2011
    This solution does work! You don't need to take the top of the camera off completely, the clip by the viewfinder is very difficult to release so I just left *** unclipped. I literally poked a small screwdriver around into the cavities around the flash and poked the circuit boards, put everything back together, all screws back, and the flash worked again! Thanks for these posts, really helpful.
I read the posts by weisendesign and johnathan222 and thought that before I took my camera apart in hopes of fixing the flash I would try giving it a solid tap on my palm in hops of knocking things back in place. It is almost 4 years old and not much good to me with out the flash so I thought "Why not." Two solid taps and the orange light came on when it should and two more and the flash worked. Thank you for the info.
Posted on Nov 27, 2010
  • tsczarnik Jun 05, 2011
    I had this flash problem as well and tried the solid tap in the palmof my hand and it worked The problem has come and gone a few times prior to this but this time it seemed a bit more stubborn, but it has come back again (so far). Hopefully it doesn't fail in a critical moment.
I had the same problem and was not interested in paying more than a new camera would cost. i did what jonathan222 did above (but without the shocking part) and now my flash works. i didn't even do much of anything besides taking the side and top off and poking around.
one quick edit to his post: after loosening the screws inside the battery compartment (i agree, don't take them completely out) you have to remove one screw in the AV/OUT compartment in order to release the top piece.
good luck, i hope this works for somebody else.
Posted on Feb 09, 2010
  • 30 Answers
Hi there, You have 1 of 2 problems, or maybe both. The secondary fuse may be blown, or the capacitor in the flash unit is not taking a charge any more. In any case, to replace the flash unit would cost about $120.00 if you sent it to canon.
mr cicmo
Posted on Nov 23, 2008
I have canon a640 camera. I am getting problem regarding taking pictures as the flash is not working. I have tried it on Auto mode, Portrate, landscape and others the result is same. Please help me in...
make sure the dial at the top of the camera is set to AUTO or the green camera icon. When you are in position to take a picture, press the left button on the circle pad on the back of the camera; it should look like a SQUIGGLY ARROW this is the sign for flash. that button should turn it on, off, at automatic based on the current lighting.
Hope this helps!
Mar 14, 2011 | Canon PowerShot A640 Digital Camera
I have a canon powershot a640 but it only takes pictures if the flash is off. How do i fix this ?
Sounds like the flash capacitor is not charging. Usually the cause is a blown fuse. This is a hardware problem, not software, and the only solution is to take it apart and replace the fuse (it's a SMD fuse and it has to be soldered). Sometimes the problem is with the flash board. I'm afraid you will have to give it to a camera technician. I could help you with the repair, but I'm in Germany.
Tom
Mar 05, 2011 | Canon PowerShot A640 Digital Camera
My camera's flash is not working and the icon of flash keeps blinking every time i try to click a photo. Also the camera works fine when I switch off the flash.
If its blinking then it meas that it is not adequately charged. The flash indicator will turn to steady orange if its properly charged.
Nov 04, 2010 | Canon PowerShot A640 Digital Camera
Flash will not fire on Canon SD780 IS Elph
The flash circuit is defective. As it's only a couple weeks old, recommend just exchanging it for another from your place of purchase. You shouldn't be attempting repair while its under warranty.
Jul 04, 2009 | Canon PowerShot SD700 IS Digital ELPH /...
When ever i take a picture, the orange light turns on acting like its going to take a picutre but it doesnt. When i take it off flash, it takes the picture.
The orange light blinking means the flash is charging, once the light goes off you can go ahead take picture with flash. Your light keeps blinking because the flash is not ready.
Try with fully charged batteries. If it won’t work, you may have an open fuse or something wrong with the flash circuit.
Apr 05, 2009 | Canon PowerShot A550 Digital Camera
Falsh Problem with Power Shot a640
I had the exact same problem. You'll need to send it back to Canon. It'll cost you $87-94, but they'll clean it up, get the flash working, and make it new again. It's a good camera worth getting fixed.
Sep 14, 2008 | Canon PowerShot A640 Digital Camera
I have a canon powershot 750
An ideea would be pressing the button a little bit harder and a little bit longer.Most of the cameras have that orange light before the flash(that appears when you press harder on the button) to reduce the red-eye effect in the pictures.
If this doesn't work, look carefully in the manual or the settings of your camera and try to find an option that turns on the flash.Also the type of the picture(indoor, sunny, night etc) can automatically disable the flash.
As a last resort, here is the camera's manual
Sep 02, 2008 | Canon PowerShot SD550 / IXUS 750 Digital...
No flash in "P" mode
In all of modes you can use "up" key to toggle between "always on", "auto"  and "off" mode for flash. (in some mode there is only auto and off.) also the flash light icon on top right of screen shows th status of flash. I hope this helps...
Aug 02, 2008 | Canon PowerShot A640 Digital Camera
yes, the flash of your camera is not charging. needs repair.
Nov 03, 2006 | Canon PowerShot SD550 / IXUS 750 Digital...
Canon PowerShot A640 Digital Camera Logo
594 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
