Back to:
Tags:
Kenmore 53603 / 53606 Stainless Steel Side by Side Refrigerator
Ice Machine (by 14 users)
posted by ACJetton on Dec 27, 2006
The ice machine is no longer making ice. It is "ON" and the water dispenser still works, but there is no ice being made. The freezer is still very cold and it is set to zero degrees. I've cleaned under it, it was somewhat dusty, but nothing major. Any help you can offer will be appreicated.
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
13 Other Users Have The Same Problem
Comment by swight77, posted on Aug 17, 2008
no ice being made
Comment by Guest, posted on Jun 11, 2008
my kenmore coldspot side by side refigerator isn't making ice not recieving water. water fountain working fine.model# 10550262993
Comment by Guest, posted on May 15, 2008
none
Comment by phil seaman, posted on May 11, 2008
Model JFC2089HEP
The ice maker was working fine, actually it made a little too much ice. One day I took the ice tray out to dump most of the ice into an ice chest. To get the tray out I raised the little wire bar, not knowing this would stop the ice making. I've since discovered the function and have put it down, BUT there is no ice being made.
I've tried the "speed ice" setting, but this doesn't appear to help either.
Help please!
Comment by Guest, posted on Apr 18, 2008
ice wont dispense from tray samsung 1 yr old
Best Solution
posted on Aug 11, 2007
FixYa! (100)
pilot30
Rank:Apprentice Apprentice
Rating: 98%, 6 votes
I have seen two issues in my experience that may or may not apply to your situation. In one instance the water feed tube or trough stooped the flow of water to the ice maker and this produce a small transient water leak initially and then it stopped working and leaking eventually as the blocked tube did not thaw.
The other issue was ice in the ice maker that lodged in the blades of the ejector and prevented ice production.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Ice Machine:
I don't want to Accept this solution
Solution #2
posted on Dec 27, 2006
Helpful (85)
HVACRH20
Rank:Guru Guru
Rating: 85%, 1242 votes
95% of ice maker problems are the motor module. See http://tinyurl.com/ykln8r for what it is and if it matches your fridge. Basically here's what ya need for ice... 17 degrees (F) or below, water fill solenoid working with water flow, t-stat on ice tray working OK and motor module turning.
Thank You!
Solution #3
posted on Feb 08, 2007
Thanks for Trying (70)
Guest
Rating: 0%, 0 votes
I had similar problems during the summer weeks.
Cleaning the dust in the componet and grill above the top door and then turning the freezer nob all the way down (coldest) seemed to do the trick.
Now it works fine during the winter. Hope this helps!
Thank You!
Solution #4
posted on Aug 25, 2008
Not Rated (0)
mmodestti
Rating: 0%, 0 votes
We had the same problem. The plastic dial on the motor module was broken. The repairman told us that the dial is not sold alone and the module costs between $70 and $90. We got a module out of another refrigerator which wasn't working and replaced it. The ice maker is doing great!
Thank You!
Solution #5
posted on Apr 14, 2008
Not Rated (0)
Guest
Rating: 0%, 0 votes
change the filter
Thank You!
Solution #6
posted on Mar 11, 2008
Not Rated (0)
Hoshizaki
Rating: 0%, 0 votes
Buy a Hoshizaki ice machine, they are the best on the market and rarely breakdown. call Carl At Hoshizaki 07866462588
Thank You!
Solution #7
posted on Sep 15, 2007
Not Rated (0)
Guest
Rating: 0%, 0 votes
I had the same problem and it was the motor module. I replaced the module and the ice started coming. It's not a very hard do-it-yourself job, either.
Thank You!
Solution #8
posted on Sep 03, 2007
Not Rated (0)
Guest
Rating: 0%, 0 votes
Happens to mine also. You will find lots of solutions to check that motor, try the switch, yada yada. Mine simply ices over in the tray and the Ice has issues releasing. I tap the old ice off the ice makers "fingers" and it starts creating ice again.
Thank You!
Solution #9
posted on Aug 20, 2007
Not Rated (0)
Guest
Rating: 0%, 0 votes
1) Vacuum the dust build-up from the coils every month. 2) Install a water softener or a 5 micron carbon type filter to remove limestone (scale) build-up, if using city water.
Thank You!
Solution #10
posted on Feb 22, 2007
Not Rated (0)
just
Rating: 90%, 3 votes
this works with a bouble solonoide make sure ther is voltage on the solonoide when the ice tray turns to fill up . if so replasce solonoide.if not replace micro sw and ,or, pcb
Thank You!
Solution #11
posted on Feb 07, 2007
Not Rated (0)
hpt66
Rating: 55%, 1 votes
He`s right.My ice maker made ice but didn`t drop it to the container. the technition replaced the electronics module it didnt help.
the motor module fixxed it for good.
Thank You!
Can you Help with these Refrigerators problems?
Refrigerators
ice maker instructions
Kenmore 53603 / 53606 Stainless Steel Side...
Hello- I recently emptied out the ice box of the ice maker...
someone told me that the water line has to be cleaned...
how old is this refrigerator?
I have an Ice Maker in the Freezer part and on the Ejector...
13 Other Users Have The Same Problem - Continued
Comment by Jud10, posted on Apr 17, 2008
refrig no water coming in solenoids appear to be goog
Comment by treece101, posted on Apr 15, 2008
I have a frigidaire refrigerator, I moved from one house to the other the first day the frig worked fine. The second day the ice started melting, and stop making ice. The freezer side and the frig. side was not getting cold. The freezer side started to get ice on the back panel. What could be the problem?
Comment by bshm, posted on Mar 16, 2008
My U-Line clear ice maker is also not making ice. The water is running but the unit is not cold. Ii have run the cleaning cycle and done all the maintenance required (vacuumning the coils, cleaning the intakes, ect.)
Comment by Guest, posted on Feb 11, 2008
i emptied my ice bucket, replaced it in the freezer compartment, made sure the wire signal arm is down and now there is no ice making. It would appear that the control for allowing the water solenoid to add water to the ice tray is not being signalled. Is there any history of a faultly switch in the front of the ice maker compartment. My fridge is one year ols, any suggestions please email me at itsmint69@aapt.net.au
Comment by RG496, posted on Dec 29, 2007
Same problem.
Comment by reaserhouse, posted on Dec 04, 2007
Maytag french door bottom freezer model number MF12568AEW - ice maker will not make ice.  You can get water out of the door so water line is working but the ice maker is not making ice.
Comment by Guest, posted on Dec 02, 2007
Same as described.
Comment by Guest, posted on Nov 11, 2007
ice machine leaking water
Loading problems.
Repair Service
Find Refrigerator Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
