Fault code showing for Ariston bs1400 front loader
1. I have a machine that has decided to not work and throw out a fault code of F18. The machine recently got wet during a storm and on inspection I found the plastic tray at the bottom of the machine full with water. The water submerged the lower two plugs on the circuit board in water. I removed the circuit board and cleaned all pins and allowed the circuit board to dry.
Note; there was no evidnce of burning or shorting on close inspection.
2. On refittment the machine runs up as normal and when selecting various wash settings cycles normally. The water is entering the machine and being cycled by the scavenge pump. After this initial cycle the macine then continues to operate the scavenge pump while displaying fault code F18. The machine can only be turned off at the power point.
3. Any attempt to turn the machine off through the normal display switches sees a continuous F18 code flash and no response from the machine.
After the machine is turned off it operates as discussed in paragraph 2.
Wtha is F 12 ????
Posted on Feb 04, 2009
Anyone now the fault light codes for this model---thank you
Flashing Lights & Error/Fault code - Repair
www.how-to-repair.com/.../washing-machine-with-all-the-lights-flashing...
Oct 25, 2014 - Now there may be some variances for older models, but there are 3 main types of board listed ... Tagged under: Ariston, Creda, error codes, flashinglights, Hotpoint, Indesit ... And can someone please enlighten me, thank you.
Identifying Hotpoint or Indesit Error Codes - YouTube
? 6:46
https://www.youtube.com/watch?v=aud14I0Zu9M
Aug 29, 2014 - Uploaded by eSpares
If your machine is stopping with flashing lights or a error code on the ... Lights on Washing Machine How to Repair Hotpoint,Ariston, Indesit ...
Flashing Lights on Washing Machine How to Repair ...
Dec 15, 2015 | Hotpoint Ariston Aquarius WD420 Front Load...
F12 error flashing on the display
Keyword Ranking Analysis for ARISTON OVEN FAULT ...
www.webstatschecker.net/stats/keyword/ariston_oven_fault_code_f12
Keyword Ranking Analysis for ARISTON OVEN FAULT CODE F12 ... fixya.com.Ariston Technologies Ariston AWD120WH - "F12 error code" issues
Aug 18, 2015 | Ariston Technologies Ovens
What does F09 mean mean for a whirlpool AW0 3561 front loader?
Washing Machine Fault Cod Fault
FH No Water Inlet
FA Aquastop Failure
FP Drain Failure
F5 NTC Failure
F6 Tachometer Failure (no motor movement detected)
F7 Triac Short Circuit detection
F8 Heating Element, Open Circuit
F9 Overflow Failure
F10 Motor control unit (Thermal)
F11 Communication failure
F12 Heating Element Short Circuit
F13 Dispenser Circuit Error
F14 EEPROM Failure
F15 Motor Control Unit Error
F16 Control Failure (Control Unit)
F18 Control Failure (Control Unit)
F20 Control Failure (Control Unit)
F21 Control Failure (User Board)
F22 Control Failure (User Board)
FDL Door Lock Error
FDU Door Unlock Error
Whirlpool Washing Machine Fault Codes
So the answer is Overflow Failure
Apr 13, 2015 | Whirlpool Washing Machines
Ariston dishwasher lkf 720 has a problem on/off, washing and end indicator lights are flashing
Reading the error code
The fault on the appliance is signalled via:
1. the continuous rotation of the selector knob
2. the action, for the first 4', of the electrovalve and the drain pump
3. the door becomes unlocked
4. the led flashes: the number of flashes indicates the fault code; the code should be read as follows:
· each fast flash (2/3 flashes of the led very close together) represents one code value
· the fault code is evaluated by counting the number of flashes occurring at 3/4" intervals from one another
· stop counting when the washing machine waits the equivalent of approximately 8/9" between flashes
· the procedure is repeated by the appliance cyclically
After you determine which the alarm code appeared we will able specifically to help you.
Dado
Sep 13, 2014 | Ariston Technologies Ariston AWD12 Front...
DESPERATE..... Displays fault code F18 frequently.Have cleaned the filter 3 times now recently(in the last 3 days) and is very clean but stopped again.Just emptied ll washing out of it and spun it to
I would check that the drain pipe is also clear.
You can actually get a build up of old soap powder in the pipework.
This pipe would be on the rear of the machine (grey in colour) and would connect to your waste pipe (perhaps under a sink)
If you can pull the machine forward and check to see if this pipe is indeed blocked, or even restricted.
I found this answer that may help you.
https://uk.answers.yahoo.com/question/index?qid=20120322120919AANhp8H
May 12, 2014 | Bosch Classixx WFL 2066 Front Load Washer
Hotpoint WMD960 F18 error code
I had the F18 fault.Nothing much worked except drain pump.
Simple solution for me was:
1)disconnect power 2)take off top of machine(2screws at rear) 3)locate the connector which fits on the rear of the main led display panel.4) Pull it off, squirt switch cleaner and replace with plenty of wiggling! 5) Put it back together and start washing !
Steve Brighton
Feb 24, 2012 | Hotpoint Washing Machines
Error code F18
F18 error code means that the filter is blocked.
Look around for a propeller shaped part, it should be able to spin freely. If not, remove the debris so that it is unblocked.
Hope this helps (remember to rate and comment this answer).
May 14, 2011 | Bosch Axxis+ WFR 2460 Front Load Washer
Ariston washing machine front loader model number BS1400 error message f-05 stops program and wont spin have unscrewed plug at bottom of machine to drain and started fine after that working for a little...
You could check the pump, open and drain, clear anything out of the pump, next turn off and unplug the mains cable, wait 40 secs and connect mains and turn back on.
Apr 11, 2008 | Washing Machines
Fault code F20 on kenmore he2t clothes washer
I have a brand new front loader that never fill with water but shows F20. How can I get this machine to wash clothes?
Dec 29, 2007 | Washing Machines
Wf860
may be the pressure switch, or the rubber tube up to the pressure switch blocked
Oct 21, 2007 | Hotpoint Ultima WF860 Front Load Washer
Washing Machines Logo
721 people viewed this question
Top Washing Machines Experts
