Question about Zebra P210i Thermal Printer
P210i card printer not printing clearly or like picture at all
Hi there! Well my problem is that my p210i card printer is not printing the way is should be printing. It prints out color, however the quality of the print is very low. I usually try to print membership cards for the gym I am about to open, but whenever I do the card always looks to horrible to even consider using. This goes for everything I try to print including images off of Google. I have a card printing software as well as photoshop7 however, it does not change anything. I recently increased the resolution of a print job to something like 1024x760 and it seemed to print just slightly better. Now my question is: can you help me solve this problem? Thank you very much I appreciate you taking the time to read this and hope to hear from you soon.
    Scholar:
  • 115 Answers
Their is really a few reasons for this.
1. Being the most Common. I can not stress enough How
important it is to CLEAN the print head. The surface the contacts the ribbon at the card. Swabs and Alcohol.
1. There may be dust or embedded dirt
on elements of the print head
2. Contrast and/or intensity colors for P310C
may be set to high values. Adjust contrast and
intensity values for in software or with
programming.
Now if photoshop. Ideal you would not print above 300dpi. Due to the printer limitation on dpi.
Some personal tips I can offer are.
To try playing with the advance color setting.
Re size the PSD to 600dpi then print. I will sometime s achieve good results.
When you DO the Black text. Leave it off for the color run. And
Send the card back thru with a black ribbon in the printer.
The thin about this series of printers is. The will not print like you and I hoped for.
See.. A state DL is printed onto a thin piece of plastic that is slightly Larger the a CR80 card. Then is it melted on the the blank card. Thus achieving the true EDGE to EDGE, Your printer and the several I have had. are not true edge. And they are not Hi-resolution printers like The ones at the DMV.
But with some practice and many. I mean many cards and ribbons. One can get close.
If this is the printer that has to work. And you can not get it to work.
Try this tip, But do not use excessive force. and Timing Is Critical.
AT your own RISK!
You have to have lid open.. Dis-sable the switch that stops the printer when the lid is up. Put the card in. and Print. As the card goes under the head. As soon as the head. Goes down to print. Apply some pressure on the top of the head near the front of the fan.
Now if is a CMY ribbon. You have to release pressure so it can let the card go backwards. When the head goes down. Apply Pressure. .
Hope this helps.......
No one has a NEW looking ID. In fact 9 out of 10 Id's are faded.....
Possible a faded look would work....
OUT
I actuall took time and wrote this out for you,,,,,, Hope it solved this question.
Posted on May 16, 2009
Why my Fargo ProL Printer is not printing my Card Back Clear?
Hi, Its not clear what you are saying.
First, what kind of ribbon are you using for printing, and what kind of lamination ribbon are you using?
what are you trying to print on the front and back?
Feb 17, 2015 | Fargo Pro L ID Thermal Printer
Zebra P210i Win7 Driver
Please take note P210 is not supported on Windows 7 yet at the moment.
Best regards
Mar 09, 2010 | Zebra P210i Thermal Card Printer
Problem with zebra p420i
Go in to control panel,
Printers. RT Click On p210i,
Properties, Device Settings Tools.
Send this Command using the Direct Commant
input Box. Just the First line..
1 +LC 0
Not This--
0
= Counter Value
Dec 16, 2008 | Zebra P210i Thermal Printer
Download
Hi
Most cameras do allow you to browse the memory card or built in storage when the camera is attached to your computer. I don't know your skill level with either, but from "My Computer" you should be able to see the camera once it is attached. You can then copy and paste the pictures back in the image folder on the memory card and should then be able to print from your printer dock.
Good luck
Thomas
Darntoothysam com
Oct 13, 2008 | Kodak EasyShare C613 Digital Camera
Eltron P210i printhead replacement and aligment
Usually with Eltron and Zebra printers all you have to do is turn the power off, change the print head, turn the power back on and re run your software to get the forms to reload. If you miss any of these steps you will run into trouble.
As long as the labels didn't get moved, it should work once you restart your computer and re run the software you print your labels with.
Aug 12, 2008 | Zebra P210i Thermal Printer
Loading the blank cards
email me at vicer@comcast.net and I will email you the user manual in pdf for the printer.
May 10, 2008 | Zebra P210i Thermal Card Printer
Printing problem
Try to clean the light sensor inside the printer, you will see a white led on the top part of the case, match it to the bottom you will see a small hole on a plastic peice, that is the hole for the sensor.
Oct 29, 2007 | Zebra P210i Thermal Printer
Printing problems
Sounds like the heat is set too high.
Aug 18, 2007 | Zebra P210i Thermal Printer
Zebra P210i Thermal Printer Logo
304 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Marvin
Marvin
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
