Question about Cartier Roadster W62016V3 Wrist Watch
Arnette watch band
I have a arnette diving watch and I need a rubber watch band for it, It is model AR1006 It's a stainless steel arnette chronograph with a rotating bezel and black rubber band.
  • 1 more comment
  • Anonymous Dec 23, 2008
    I have a arnette watch and I need a rubber watch band for it, It
    is model AR2029 It's a stainless steel arnette with black rubber band
  • Kenneth Koop
    Kenneth Koop Feb 15, 2009
    I also have a 1006 and need a new watch band keeper (rectangular rubber loop to hold the free end of the watch band).
  • jimi k Apr 07, 2009
    I have a arnette niner watch and need a new thick black leather band, i can't find anyone that has them. model number AR01501
escapement
  • 2334 Answers
SOURCE: stainless steel band won't snap into my watch
Stainless steel bracelet ends (so called wings) must be curved flush to the watch case.
Another way is to use curved spring lugs (pins).
Posted on Dec 17, 2008
  • 51 Answers
SOURCE: Watch band sizing
OK, I make an attempt:
I saw on other pictures on the web that the links have small holes at the side. There should be some links with arrows r another marking. These are usually the links that can be removed to shorten the strap.
If there is a small arrow on the link, it means that you can push out the pin inside the hole in the direction of the arrow. Then the link can be detached.
You can push it out with a blunt sewing needle (break off the tip).
Remove links on both sides of the watch when resizing it.
Hope that helps.
Critter
Posted on Dec 27, 2008
escapement
  • 2334 Answers
SOURCE: stainless steel band adjustment
You may or may not have arrows inside bracelet. Arrows are pointing the way the pins must come out.
First you have to find out what sort of pins or even screws are used to keep links together.
Examine both bracelet sides and find the side where pin ends have a groove.
Start with a tiny screwdriver and unscrew one of the screws. If it turns, but doesn't come out, that means you have a pins instead.
For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it.
Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well.
NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer!!!
Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows.
After a few blows check if the split end is coming out and when you see that the end is long enough to grab it with pliers, pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting.
After shortening the bracelet or adding extra link(s) make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet.
It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin.
Make sure that pin ends are flush with bracelet. If needed- hit few more times.
Job done!
If you do not want to do it yourself, any jeweler will do it in a matter of few minutes.
Don't forget to rate, please.
Posted on Mar 19, 2009
escapement
  • 2334 Answers
SOURCE: Adjust watch band for Seiko 7T94 Stanless Steel Band
Job done!
Posted on Apr 04, 2009
  • 183 Answers
SOURCE: appraise Bulova N2 10K R.G.P. Bezel Stainless steel back
I have seen this watch sale in mint condition for as much as $40 but this is an inexpensive piece.
Posted on Sep 18, 2009
Is the fossil fs4813 waterproof
yes, to 50 metres
Fossil Men's FS4813 Grant Stainless Steel Watch with Leather Band ...
https://www.amazon.ca/Fossil-FS4813-Grant-Stainless-Leather/dp/B00AFTTQ8I
Rating: 4.5 - ‎50 reviews
Tang clasp. Water resistant at 50 meters / 165 feet. Casual watch style. Fossil Grant Chronograph Black Dial Brown Leather Mens Watch FS4813.
Grant Chronograph Brown Leather Watch - Fossil
https://www.fossil.com/us/.../grant-chronograph-brown-leather-watch-sku-fs4813p.ht... Rating: 4.6 - ‎91 reviews - ‎US$115.00 - ‎In stock
PRODUCT DETAILS. Collection: Grant. Movement Type: Quartz Chronograph. Case Size: 44mm. Strap Material: Genuine Leather. Water Resistant: 5 ATM ...
Water Resistant Watches, 10 ATM Watches ' FOSSIL
https://www.fossil.com/us/en/******/10-atm-watch.html Water Resistant Watches up to 10 ATM. Fossil Hybrid Smartwatch - Q Nate Dark Brown Leather Ftw1114. Quick Look. Fossil Hybrid Smartwatch
Is the fossil fs4813 waterproof Google Search
Aug 16, 2017 | Fossil Watches
How to change watch band on invicta angel stainless steel band
Turn the watch over and you will see that the band is attached to the watch with spring loaded pins. There is room to put a spring removal tool in the available slot and depress the spring which will allow you to twist the band away from the watch. Be careful to not loose the spring loaded pin as you may need it to install another band. Almost every watch uses this method of band removal. Those that don't usually have a long screw that is accessible from the side of the watch.
Feb 19, 2013 | Invicta Reserve Subaqua Venom Swiss Quartz...
Extra link 823a
This person wasn't asking for advice about buying a rubber wrist strap for a diving watch, but rather was asking about where to get an extra link for the watches stainless steel bracelet1
Jun 12, 2012 | Breitling Aeromarine Colt Auto / Colt...
How do I remove watch band links from m Stainless Steel Nautica Watch? Model #A45001G
I've got a great article that helped me out with this same problem! I thought this article explained things pretty well. http://hubpages.com/hub/How-to-Size-a-Watch
May 21, 2010 | Nautica Blue Dail Yacht Chronograph Watch...
Adjust the band
Click on my profile (escapement), then click on Tips and Tricks. There you will find tip how to add or remove watch bracelet links. Rate me, please
Mar 10, 2010 | Invicta Sea Spider Chronograph...
Swiss Legend Chronograph Stainless Steel Case- how to change the battery
Take your watch to your nearest watch shop and ask them to do it for you.
You can get into difficulty replacing batteries and it is not worth the risk for the small cost saving in doing it yours
Feb 24, 2010 | Swiss Legend Chronograph Stainless Steel...
Swiss g10-211 movement doesnt keep time runs when it wants to
This movement wasn't meant to be repaired, so replacement is your only option. These pop up new on eBay from time to time for around $30 shipped. Make sure you get one with the date in the correct orientation/position (e.g. date at 3 o'clock or date at 4 o'clock). Best to enlist the services of a watchmaker if you haven't removed and replaced hands on a watch before (particularly a chronograph).
Feb 25, 2009 | Swiss Legend Chronograph Stainless Steel...
Replacement band for the Invicta 2307
SORRY but FIXYA sells nothing .check with your dive shop
Aug 17, 2017 | Invicta Watches
Cartier Roadster W62016V3 Wrist Watch Logo
1,194 people viewed this question
Top Cartier Watches Experts
Jimmy Accardi
ray gallant
Are you a Cartier Watch Expert? Answer questions, earn points and help others
