Question about Lenovo ThinkPad T61 Notebook
The wireless function on my laptop works intermittently. Are there any special settings process I must follow? Please provide for set-up. The wireless switch is turned on and I have a strong wireless signal in my home. I wireless icon is not lit and I cannot see any wireless site.
I had to change the location profile to allow it to see my wireless router.
Posted on Nov 27, 2008
The blutooth stack is download and install but "i activate the keys the key is fn + f11 then where is a radio on off switch pls tell me where is radio on off switch ? pls".
nitin m patil,
Wireless Switch
Wireless Technology
  1. The Vostro 1510 system ships with a wireless feature called the wireless switch. It is located on the left side of the system next to the ExpressCard slot. This switch serves to dectivate or activate the wireless antenna.
Wireless Switch LED Settings
The LED (located on the Hinge Cover) on the wireless switch works only when the system is powered on. A user can activate the switch and have it scan for networks only after going through a complete boot process. The switch is used to detect only wireless signals. This setting is in the BIOS under the Wireless section.
The LED indicates the following functionality:
  • Solid Blue - The system has detected a wireless signal.
  • Off - The system failed to detect a wireless device installed.
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Aug 17, 2013 | Dell Vostro 1510 Laptop
I have sony vaio S. but the wirelees is not working no wireless host shown. how can i fix it?
Selecting the wireless function Follow the steps below to select the wireless function to be activated when you set the WIRELESS switch on your computer to on. Double-click (wireless switch icon) on the Notification area at the bottom right of the desktop.The Wireless Device Switch dialog box appears. Hints The appearance of the wireless switch icon changes depending on the selected wireless function. Point to the wireless switch icon to display the selected wireless function. Alternatively, you can right-click the wireless switch icon and select "show Wireless Device Switch settings" to display the Wireless Device Switch dialog box. Select the desired wireless function from "Wireless LAN" or "Bluetooth Device". Notes 5 GHz Wireless LAN is available on certain models only. You must select at least one wireless function to perform wireless communications. The 2.4 GHz and 5 GHz Wireless LAN functions employ different frequency bandwidths, thus are not compatible with each other. Checking the check box for both "Enable 2.4 GHz Wireless LAN" and "Enable Bluetooth Device" may cause poor communication performance or a connection loss due to electromagnetic interference. Click OK. The message "Setting up the wireless devices. Process may take several minutes. Please wait." appears first, then the Wireless Device Switch dialog box is closed, and finally the dialog box that describes what to do with the icon on the Notification area appears. Note While the message "Setting up the Wireless Devices. Process may take several minutes. Please wait." is displayed, do not: place your computer into power saving mode. turn off Windows or log off from the current user. turn on and off the WIRELESS switch. Confirm the settings and click OK. The dialog box about the icon on the Notification area closes. Hint If you check the "Don't show this dialog in the future" check box, the dialog box will not appear next time you close the Wireless Device Switch dialog. To analyze the network condition You can analyze the network condition if you select either or both of the wireless functions under "Wireless LAN" in step 2 above. Click the "Diagnose" button to start Windows Network Diagnostics. When the network analysis is complete, the result is displayed. If any problems are found, follow the on-screen instructions. Hint Windows Network Diagnostics is the function to identify problems the network has and present solutions to them.
Mar 01, 2011 | Sony Computers & Internet
I have somehow disabled the wireless capability. do you know the function key combination to enable it?
check on the edges of your laptop, there might be a slide switch to enable wireless connection.
set up a wireless connection by plugging in first the network cable.
select wireless or wlan connection
follow the process
reset your router
restart your computer
enjoy wireless networking
Jan 27, 2011 | Acer Aspire 6930-6771 Laptop
Create wireless security
1.Enter IP address http://192.168.1.1 (the factory-default IP address setting) to the URL web address location.
2. When the following dialog box appears, enter the user name and password to login to the main configuration window, the default username and password is “admin”.
3.Setup wizard is provided as part of the web configuration utility. User can simply follow the step-by-step process to get the wireless Router configuration ready to run in 6 easy steps by clicking on` the “Wizard” button on the function menu. The following screen will appear. Please click “Next” to continue.
4.Set Wireless LAN connection
Click “Enable” to enable Wireless LAN. If user enables the Wireless LAN, type the SSID in the text box and select a communications channel. The SSID and channel must be the same as wireless devices attempting to connect to the WLAN Router.
(When in FCC domain, you could chose ch1~ch11; in ETSI domain, you could chose ch1~ch13)
4. Click on Security.
5.Security
This function enables user to set authentication type for secure wireless communications. Open System allows public access to the router via wireless communications. Shared Key requires the user to set a WEP key to exchange data with other wireless clients that have the same WEP key. This router also supports WPA, WPA2 and WPA-PSK, WPA2-PSK.
6.Set the Security key and save the settings.
7. The Wireless is secured now.
You can find more information in the User Guide.
Here is the link: refer page #26,27,33 to get all the info.
http://www.encore-usa.com/us/sites/default/files/product_documents/ENHWI-N2_Manual_Cam.pdf
Jun 23, 2010 | Encore ENHWI-N2 802.11n Wireless Router...
My phone keeps saying there is aproblem connecting to gprs service in your registered home network
All phones need APN setting to make them work for gprs or data functions.
You can find the settings from your network operator and then you can follow this video guide on how to enter APN settings in any HTC phone.
This is a tutorial on how to add APN settings to HTC phones for your network providers. Example phone used is a HTC Hero but process is same for all HTC models.
APN and Data Settings Change for HTC Phones
  1. Go to settings -> wireless controls
  2. Go to Mobile Networks -> Access Point Names
  3. Click Menu and select New APN
  4. All you need to add for most networks is just the APN setting which can be obtained from your simcards network provider
  5. Press Menu and Save
  6. You are ready and have configured data connection settings.
Enjoy your HTC phones unlocked for Voice and Data for any network. see video below
May 14, 2010 | HTC HD2 Smartphone
Using a laptop I trying to connnect the WNR200 witreless router and all connections are correct but cannot process network information?
First install the latest wireless card driver in the laptop.
Next to secure and configure the Netgear wireless router and configure the wireless card in the laptop with the Netgear's wireless settings, please click on this link and follow my instructions :-
http://www.fixya.com/support/r3559128-wireless_router_security
Dec 31, 2009 | NetGear WNR2000 Wireless Router
Slow wireless internet connection for select PC's; fast for other
Make sure that your wireless mode is set to "mixed mode".
Intermittent Connectivity:
NOTE:
Before following the steps in this article, check if your wireless computers have stable connection when connected to other wireless networks (hotspots).
This article assumes that all wireless computers are experiencing intermittent wireless connection with the Linksys router.
Frequent wireless disconnection can be caused by different factors such as:
  1. Wireless interference within the network.
  2. Wireless settings of the Linksys router are still set to default.
  3. Firmware is corrupted.
Reducing Wireless Interference
If you are experiencing frequent disconnection from the wireless network, it helps if you check the following factors, all of which can greatly affect your wireless signals:
your cordless telephone system (or even your neighbors’), or other nearby equipment. Try to change your router’s channel to 1 or 11 (the default channel is 6) and restart the wireless computers.
Physical obstructions: Your router or wireless computers may be losing connectivity because of physical obstacles such as walls and floors. Try to move the equipment to different locations to find a better link.
Placement of the router: Linksys suggests that you place your router as high off the ground as possible. When placing the router in a high location, leave a distance of two feet between the router antenna tips, ceiling, and wall. If your signal passes through multiple floors, place the router on the upper-most floor and high up in the room.
  • Surroundings: Keep the router away from large metal objects, bodies of water (fish tanks, bathrooms), and any electrical equipment including television sets, microwaves, radios, etc.
Customizing Wireless Settings of the Router
Having default wireless settings on the Linksys router may cause conflict with other Linksys routers within your network range. Linksys suggests changing the SSID (network name) and the Wireless Channel of your router. Also, if it is possible, enable the Wireless Security of your router.
To change the router’s SSID or the wireless network’s name, click here.
To change the router’s channel, click here.
To enable the wireless security on the router, click here.
NOTE: If the wireless connection remains unstable after performing the steps above, upgrade the router’s firmware. For instructions, click here
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Apr 20, 2009 | Linksys Wireless-N WRT150N Router
I have a laptop run Vesta trying to set wireless connection to HP Potosmart C4385 print using ad hoc network setup. When selecting Ad Hoc connection in the printer setup it saids it can not find it or...
For this specific issue about installing the printer to a wireless connection. You need to install the software first as a usb connection. After the successful installation of the usb connection then you can add a device and it should work.
Step one: Gather the necessary hardware and information Follow the procedure below before obtaining your wireless network:
  1. Obtain your network SSID and WEP. To simplify this process, press the Wireless button on the all-in-one, and select Restore Network Defaults . This turns wireless off and sets the all-in-one's SSID to hpsetup .
  2. Press the Wireless button to turn wireless back on. Look for hpsetup when you select your network.
  3. Make sure that wireless is enabled on the all-in-one.
  4. Make sure that the computer that will be using the all-in-one has access to the router/access point.
You will need the following to set up the product on a wireless network:
  • A wireless 802.11 network that includes a wireless access point.
  • A desktop computer or laptop with wireless networking support or a network interface card (NIC).
  • Broadband Internet access is required for some features of the HP software to function. Cable Internet or DSL are examples of Broadband Internet access. NOTE: If you connect the unit on a wireless network that has Internet access, HP recommends that you use a wireless router (access point or base station) that uses Dynamic Host Configuration Protocol (DHCP).
  • The network name, or Service Set Identifier (SSID). NOTE: The SSID is obtained from the wireless router or access point using the embedded web server on the router. See the documentation provided with the access point for more information.
  • The Wired Equivalent Privacy (WEP) key or Wi-Fi Protected Access (WPA) passphrase, if needed. CAUTION: To prevent other users from accessing your wireless network, HP strongly recommends using a password or passphrase and a unique SSID to your access point. Your access point might have been shipped with a default SSID, which can be accessed by other users using the same default SSID. For more information on how to change the SSID, see the documentation that came with your access point. NOTE: The WEP key and WPA passphrase are obtained from the wireless router or access point using the embedded web server on the router. See the documentation provided with the access point for more information.Some access points provide more than one WEP key. Use the first WEP key (index 1) when setting up the wireless network.
  • If the network is set up with an Apple AirPort base station and you are using a password instead of WEP HEX or WEP ASCII to access this network, you need to get the equivalent WEP key. See the documentation that came with the Apple AirPort base station for more information.
  • If IP address filtering is set up, verify that the unit address is listed.
  • If MAC address filtering is set up, verify that the unit address is listed. NOTE: HP cannot set up or change the SSID, WEP key or WPA passphrase. This information is required before connecting the HP All-in-One to the wireless network.
Step two: Connect to an integrated wireless WLAN 802.11 network Follow the procedure to connect the unit to the wireless infrastructure network:
  1. Insert the software CD.
  2. Click Install .
  3. Click Next on the Please Allow All HP Install Wizard Processes screen.
  4. Select Easy Install on the Choose Easy Install or Advanced Install screen.
  5. Select Through the Network on the Connection Type screen. Figure 2: Connection Type screen c01160788.jpg
  6. When it doesn’t find your device, click Next . Figure 3: Using Network Setup c01164746.jpg
  7. Plug in your device via USB (it will tell you when to disconnect later). Figure 4: Making a connection to your all-in-one c01160790.jpg
  8. Select your network from the list, and click Next . Figure 5: Wireless Network Setup c01160791.jpg
  9. Enter your WEP key (if applicable). Figure 6: Specifying your network security settings c01160792.jpg
  10. Once it has completed connecting to the network, click Next . Figure 7: Network connecting completed c01160793.jpg
  11. Disconnect the USB cable from the computer and the All-in-One . Figure 8: Disconnecting the USB cable c01160794.jpg
  12. Click Finish to complete the software installation process. Figure 9: Software installation complete c01160795.jpg
Aug 04, 2008 | HP Office Equipment & Supplies
Wireless connection
There are three major steps to setting up a wireless router.
First set up WAN side access to the internet. For this you need information about your internet service provider. Please respond with your internet service provider's name or better yet a link to their help/support website.
I assume you already have access to configure the router at 192.168.2.1 if not please do the following. Open Internet explorer and enter 192.168.2.1 where you would enter fixya.com and press enter -- do web pages appear in your screen from the wired computer. If so we have manual access to configure the router. If not let me know.
Please reply with a response to this message.
Second we will test wireless connections to the router
Third we will secure the tested wireless connections to the router.
This process will require interaction and several iterations of instructions to complete. Please add a comment to this request with the necessary information if you with to proceed in this fashion.
Jan 01, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
D link Router & my laptop
Debugging the issue -- this is not a solution.
Have you plugged a computer into the router if possible using an ethernet connection? Did it successfully access the internet?
If not the ISP (modem?) side of your router is probably configured incorrectly for your ISP
If that works wireless routers and adapters operate different bands I know of A, B, G and N. Do both your router and adapter card have at least one of those bands in common?
At any time have you attempted on the laptop to connect with the router? When connecting do you see your router by name? has your router been set to a unique name so you aren't confused seeing one of your neighbor's routers?
Did you enable encryption (WEP or WPA) in either the router or the wireless adapter and not enable it in the other?
Do you have MAC filtering on in you router and forgot to enter the wireless cards MAC accress?
Please reply with as many answers as you know and we can step through the process to attempt to complete the connection.
Also please provide the manufacturer and model for each of the following
Your router, your laptop and your network adapter
Please provide the operating system installed on your laptop,
If the wired connection to the internet does not work please provide the name of your internet service provider.
Dec 18, 2007 | Computers & Internet
Lenovo ThinkPad T61 Notebook Logo
135 people viewed this question
Top Lenovo Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
