Question about Philips Magnavox MRD510/17 Theater System
The difference between (+) and (-) on my speaker
I have a magnavox MRD510 with no manuel. i can't tell which of the two wires coming from the speakers is (+) or (-). or does that even really matter as long as i put them all the same. both wires are gray but one has a black stripe with spaces in between the black. which one is (+).
  • 33 Answers
The one with the black stripe is the negative.
Cheers!
Posted on Nov 23, 2008
I have a magnivox home theater model #mrd510 all my speekers quit working on the unit , how do i fix it ive reset the unit , checked to see, it is not on mute! i have also checked the speakers, its the...
Check the source cable is ok, replace with another if possible.
Also make sure the source is not putting out a standard the HTS does not understand (ie DTS or PCM).
Please dont forget to vote if you liked my answer
thanks
Feb 11, 2011 | Philips Magnavox MRD510/17 Theater System
How do I make all speakers to work?
check you settings . make sure you volums are up for each speaker, and see if you delay speaker settings are messed up , if that dont work switch speakers aroun see if its the speaker , if that dont work set system to defalt
Jan 27, 2011 | Philips Magnavox MRD510/17 Theater System
When i power it on,it flickers then shuts off...also the standby on light is always red
Serious power issue.
Generally speaking, an amp protects itself from heat, shorts and overloads.
Overloads can be from excessive periods of high output and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced hands-on tech.
Jan 21, 2011 | Philips Magnavox MRD510/17 Theater System
Why is the system shutting itself off?
Jan 16, 2011 | Philips Magnavox MRD510/17 Theater System
Need to acquire a Philips Magnavox MRD510/17 Theater System Remote control
Windows 7 has what type of sound drivers other then the usual are you talking about?
I’m happy to help further over the phone at https://www.6ya.com/expert/phillip_293d34ebcf028794
Jun 11, 2010 | Philips Magnavox MRD510/17 Theater System
Car audio
Here are the wire colors and what they do in the system. Please rate my help.
1994 Saturn SL Car Radio Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Orange
Car Radio Accessory Switched 12v+ Wire: Yellow
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Gray
Car Stereo Dimmer Wire: Brown
Car Stereo Antenna Trigger: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Jun 16, 2009 | 1994 Saturn Sl
Magnavox MRD-510- when I plug it in, it just makes a clicking noise and the power button keeps flashing. When I unplug this unit it continues to click for 5 seconds. Only owned for about 5 months and now...
Protect mode will kick in whenever a fault is detected.
You get the unit not powering up, and sometimes you hear a clicking noise, that is the protection switch that keeps shutting down the unit.
Causes that can start protect mode are:
Electrostatic harges on internal circuits.
Leave the unit unplugged for power for one hour or so, this will allow discharge.
Bad speaker wiring.
Check speaker wiring, try unplugging and plugging back, or start after removing one speaker at the time.
Internal fault.
Internal fault is the natural cause for protect mode. If all the above did not work, then the problem is a blown component or an internal fault. In this case the unit must be taken apart , tested and repaired by an experienced person.
If the unit is less than one year old, or if you want to get service, call Sony at the phone number listed on the product documentation.
Regards.
Nov 30, 2008 | Philips Magnavox MRD510/17 Theater System
No sound on Any Speaker
Magnavox would suggest the following as would I
  • Increase the speaker volume
  • Disconnect the headphones
  • Switch on the selected source or select another source
  • Reconnect the speakers
  • Change and play another disc
  • Swap speaker connections
Oct 12, 2008 | Philips Magnavox MRD20037 System
Lost installation guide for Magnavox MRD 510 Home Theater System
Download MRD-210 User Manual as it might help you to hook up video cables properly. Connections between Tv and Homer theater is not proper in your case.
Sep 11, 2008 | Philips Magnavox MRD510/17 Theater System
Philips Magnavox MRD510/17 Theater System Logo
79 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
