Question about Kenmore 61042 Top Freezer Refrigerator
Kenmore 61042 fan motor replacement
I replaced the fan motor and the new one barely turns the fan, barely cooling the refrigerator part. What could be wrong now?
  • 374 Answers
Hi! you mean there is ice on the part of evaporator or some in other part? its normally cool your refrigerator inside part.If ice is present your fan have insufficient air neede to frost free your evaporator its not the same with the origina you replace,beside your thermostat is not working have check this one.
Posted on Mar 17, 2009
Kenmore air conditioner fan noise
This can be due to faulty bearings on the fan motor or if the fan leaf is rubbing on the outer frame.
Remove the covers and manually turn the fan motor , if noise is heard then USE SOME LOW GRADE OIL ON THE BEARINGS , it will lessen the noise. If not replace the bearings/motor as the case is seen.
Jul 27, 2011 | Kenmore 70088 Air Conditioner
On my kenmore refrigerator mod number 25374879401 the freezer is cold and the bottom is not cooling.the condenser fan is running as well as the one in the freezer.any help would be appreciated
ck the back of freezer for ice build up there should be no ice . if so the defrost heater has failed or the drain is pluged . . thes units often need drain heater's to prevent the problem .. mm
Jul 29, 2010 | Kenmore 61042 Top Freezer Refrigerator
My Kenmore refrigerator model # 253.7419240p the freezer works perfect but the fridge part is very warm i had milk in it over night and it spoiled... what can i do to fix this i can not go without a fridge...
the fact that the freezer is still cold is a good thing as that means the compressor is still running, and probably at least the condensor fan also that is beneath the frig/freezer near the compressor.
check that the fan in the rear of the freezer is running when the compressor is on, if so then your issue may be a pluged or blocked air passageway that interconnects the freezer compartment with the frig to cool it. this will need to be chased down and located to remedy
if the fan is not running you will need to find out if there is power to the fan, if so the fan is shot and can be replaced, if not then we need to find out why. broken wire between the defrost timer is a possibility, even a bad connection through a moly plug could cause it.
hope this helps,
best of luck,
ttfn
Oct 25, 2009 | Kenmore 61042 Top Freezer Refrigerator
Freezer cold. Refrigerator very warmer.
Hi there. This should be a self defrosting unit. Check the defrost clock. It's usually behind the grill at bottom front of frig. or near the compressor. There is probably a little window on the clock motor where you can see it turn. You can manually advance the clock to put the unit into defrost mode. Check the defrost heating element. This is the usual problem. It is under shrouds where all the frost builds up. If element good, check defrost thermostat connected to element mechanically and in series electrically.
Thanks
Paul
Jul 12, 2009 | Kenmore 61042 Top Freezer Refrigerator
I have a Kenmore refrigerator (model 253.63732300) with freezer on top. The freezer section is cold but the lower section or the refrigerator section is not cold. It is warm. Any suggestion on why this is...
Hi, Check in the freezer section and see if there is frost building up on the rear panel. Notice if the evaporator fan motor is running. If there is frost, you need to repair the defrost cycle.
Please let me know if this what you find so I can assist you further.
Vic
Jun 14, 2009 | Kenmore 61042 Top Freezer Refrigerator
Refrigerator is not getting very cold
Hi, You can check and see if there is frost built up on the rear wall inside the freezer. If there is frost, you have a defrost problem.
Check and see if the evaporator fan motor is running in the freezer.
Check these out first and let me know so I can assist you further
Thanks
Vic
Jun 05, 2009 | Kenmore 61042 Top Freezer Refrigerator
The freezer is cold but not the fridge?
fan motor from freezer to fridge out. What this motor does is allow freezer temp to be used to cool fridge. Motor is located between the bottom panel of the freezer and the top panel of the fridge.
Apr 16, 2009 | Kenmore 61042 Top Freezer Refrigerator
Kenmore 61042 Top Freezer Refrigerator Logo
101 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
acrman404a
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
