Question about Kitchen Ranges
High pitched noise with oven use
RE: KitchenAid Electric Range ProLine Series and Architect Series KESA907
Purchased 5/2005
The oven makes a high-pitched whining noise during use and for about 10-15 minutes after use, on both the regular and the convection setting.  It is loud enough that I sometimes mistake it for the hood vent fan, though in reality it is not quite as loud.  Using the stovetop does not cause this sound.
We did not purchase this, it was in the apartment that we moved into in September 2008 and has always made this annoying noise at least since then.
Everything else seems to work fine.
  • writeway Nov 29, 2008
    I've noticed this only over the last two days, when I was using the oven a lot. There's a high-pitched whining sound (almost like a hearing aid turned up too high) emanating from the oven dial. It's seems to cycle on and off when the heating element fires up. This is a GE ceramic top range purchased in 1998. The only major repair I've had since purchase is replacement of the broiler element two years ago.
bigg t
  • 640 Answers
SOURCE: Dishwasher Making Loud High Pitched Noise.
How deep do you want to get into this?It sounds like the wash pump motor bearings that are worn.You can pull the unit out flip it over and wd40 the bearings in the motor or you can replace the bearings.Try to lube them first.
Posted on Feb 24, 2008
  • 2651 Answers
debris caught iside pump assy is what it sounds like
  • 26 Answers
SOURCE: Electric Oven not getting hot enough
Sir, I think the top oelement is for broiling ONLY. It should not turn on when baking. The clicking may be the oven heating up.
How far apart were the oven temp instrument and the digital?
Don't expect them to match...they are inaccurate.
1. Heat water until it boils. Place digital therm in boiling water until it comes up to 212deg. If it is not at 212 in boiling water, record the error.(this gives a rough calibration to the digital)
2 Turn on oven, set to 350 deg, place digital therm on rack. Wait until oven reaches 350 (on stove) and read the digital. Note the difference between the two
Posted on Mar 30, 2008
  • 11 Answers
A loud high pitch whine while running the dishwasher means that there is something caught in the chopper assembly. To get to the chopper assembly you need to take the racks out and take the pump apart from the inside of the dishwasher. The chopper assembly looks like a metal grate with holes in it. And it might not even be stuck in the grate but somewhere in the pump area due to the water being pumped out, so the best idea is to take the whole thing apart and clean everywhere. However I do not recommend doing this unless you are completely certain you will remember where the screws and gaskets go, otherwise you risk damaging your pump or house from a leak or improper installation. You have been warned.
Posted on Jan 15, 2009
  • 1214 Answers
SOURCE: LG Electric Range Oven Keeps Shutting Off
When you say "Just shut off" do you mean the circuit breakers would trip, or fuses would blow? If so, I would have an electrician check that the circuit is properly fused/breakered and wire sized for the amount of power required by the oven. If the installation directions say it needs a 50 amp service, it better be a 50 amp service.
If shutting off is just something within the oven, then get LG back out again, and let us know of what they say is wrong.
Posted on Jan 24, 2009
Fault code F2E0
Your key pad is shorted.Replace the electronic range control clock.
Mar 17, 2012 | KitchenAid Architect Series KEBC107KSS...
Springs make a horrendous noise when you open the door. what is the best lube to use on them. grease or wd40?
The best repair is to replace the hinges and springs. If you do want to lubricate them do NOT use grease or wd40, these are flammable and do not mix well with heat.
Look up an appliance parts store in your city and pick up some high temperature copper or graphite based lubricant those are safe for use on oven hinges.
Jul 19, 2010 | KitchenAid Architect Series KEBC107KSS...
Kitchenaid Architect Electric range model KESA907PWW02 Error F2E0 STUCK KEY. Can't get rid of this error. Have shut off breaker for several hours -problem comes right back.Any ideas? Thanks M.S.
Thanks for using FixYa. Error F2-E0 on your kitchen aid means that the keypad is shorted and to resolve this issue you’ll have to replace the electronic range control/clock (ERC). Please do rate the solution if the issue is resolved or post a comment for further assistance.
Jul 03, 2010 | KitchenAid Architect Series KEMC308KSS...
Lower oven will not heat up
check the ignitor and the oven thermostat. the ignitor may glow but not get to a high enough temp for the oven gas valve to open. not specified whether elec. or gas.
Jun 18, 2010 | KitchenAid Architect Series KEMC308KSS...
Kitchenaid oven KESA907. Ran the self-cleaning cycle...
Cycling the power off and then on again will sometimes reset it...often you will have to call the customer service number to get the steps to take to unlock that...
Also check out this tip...
Apr 27, 2010 | KitchenAid KESA907PSS Electric Kitchen...
KitchenAid Architect Series KEBC278KSS Electric Double Oven displ
Our fan on our oven is super loud. Always has been. We have to keep the door open so that it will cool off asap because it is so loud. What's wrong?
Mar 11, 2009 | KitchenAid Architect Series KEBC278KSS...
KERS907 series electric ranges.
any high tech range or any appliance for that matter that is high tech has a greater risk of repairs, the smart solution is to purchase an extended warranty on the appliance so if it does need to be repaired it will not cost you any additional expense
btw kitchenaid makes a fine range
Apr 16, 2008 | KitchenAid KERA807P Electric Kitchen Range
Kitchen Ranges Logo
831 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
