Question about HP Pavilion ze4300 Notebook
Charging problems with HPlaptop
I just bought a used hp pavillion ze4400 laptop. the guy told me there was a chaging problem,but now it's impossable. Ihave to have it plugged in constanly,and the plug seems to be faulty,meaning you have to move around or hold the adaptor plug constantly. not a lot of money to fix it. I'mwondering if it's the battery, the adaptor or maybe both. what shold I try 1st? Lisa
  • Anonymous Feb 19, 2009
    My laptop power plug was also faulty (broken) , I've since repaired it (epoxy) and it still doesn't work consistantly. I'd love to try a new battery but at over 100 bucks it may be cheaper to replace this old used latop
My brother hit the reset button on the bottom of our HP Pavillion ZE4400 now, a screen comes up and says "operatins system not found" what do i do
you have to insert the system software installation disc that came with your laptop, or go buy one or order it for free online. You reset everything now the laptop has no operating system to run off.
Feb 24, 2011 | Computers & Internet
My charging circuit was not functional when I bought my computer from a store. The computer is used how do I fix the circuit?
If the AC power cord is the problem. you can just buy that from any computer store but if the problem is inside of the laptops charging circuit it the mainboard of the laptop needs to replaced. you can call HP for parts replacements.thanks
Jan 02, 2011 | HP Pavilion ze4400 Notebook
Need a bios password for a hp pavilion ze4400
You will have to reset your BIOS password. To reset the BIOS read the information from this link
In case of your HP laptop the easiest method would be using software from Hiren's Boot CD as it's pretty hard to open it up and reach for the CMOS battery or the jumper.
Dec 17, 2010 | HP Pavilion ze4400 Notebook
Intalled vista basic on my Hp pavillion ze4400 my
You will need to go to HP.com and download your VISTA drivers for video.
And you should check your device manager for flags, as you may need to get other drivers as well.
Oct 25, 2009 | HP Pavilion ze4400 Notebook
New hp laptop battery will not charge w/plugged in AC and turned
You probally have a dead motherboard port that charges the battery.
Sep 26, 2009 | Dell Latitude D600 Notebook
HP Pavillion ze4400 can this laptop use an external mouse & keyboard ?
Any external USB mouse can be connected to the system. As well as USB keyboard. Or specifically if you go through HP, the mouse part number is: NR152AA, and keyboard is GM321AA. As far as non-HP products you will need to check on compatibility on each. Hope this helps you in this question.
Jul 29, 2009 | Computers & Internet
HP Pavillion ZV6000 - Charging Problems
hi
It seems that your laptop is not charging so in that case you must take your laptop to your vendor.For more support you can visit---------http://robs-tech.blogspot.com/2009/06/free-solution-regarding-computer.html
Jun 22, 2009 | HP Pavillion ZV6000 Notebook
Ze4400 will not see harddrive
some hp computer dont like a drive running in cable select the should be a tiny jumper make sure the drive is set a master thius should fix your problem. i am sure you not mixing up ide and sata they wont plug in to the same commector at all. Just check the jumper dell like to use the cabel select setting. i can tell you the drive are all the same. john@johnslaptops.com
Feb 20, 2009 | HP Pavilion ze4400 Notebook
HP PAVILLION DV6000 REPORTS BATTERY NOT CHARGING
fixed it ( it is bios problem) but besure to down load the fix before formating or use win 98 to fix it
Jul 07, 2008 | HP 530i (Q6750A) DVD±RW Dual Layer...
HP Pavilion ze4300 Notebook Logo
75 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
