Question about Smeg S1100MFX5 Electric Single Oven
High pitched noise from KitchenAid Oven
RE: KitchenAid Electric Range ProLine Series and Architect Series KESA907Purchased 5/2005
The oven makes a high-pitched whining noise during use and for about 10-15 minutes after use, on both the regular and the convection setting.  It is loud enough that I sometimes mistake it for the hood vent fan, though in reality it is not quite as loud.  Using the stovetop does not cause this sound.
We did not purchase this, it was in the apartment that we moved into in September 2008 and has always made this annoying noise at least since then.
Everything else seems to work fine.  Thanks
  • nimadea00 Nov 23, 2008
    Please ignore, posted in the wrong section.
  • 1462 Answers
SOURCE: Oven light always on, no heat
probably the clock not set properly - you have the oven on automatic. switch off at mains, wait 5 mins and set the clock according to the manual. if the over-temp stat has operated, the oven goes dead
Posted on May 06, 2007
  • 1462 Answers
SOURCE: smeg electric oven
your neighbour is probably right. fan should work but if the element has disintegrated, bits of the element could be jamming the fan. take the rear panel off inside the oven and check
Posted on Jun 03, 2007
  • 4889 Answers
SOURCE: Smeg oven problem
The pop would usually mean a busted fuse. Turn off the oven, disconnect completely from the power supply and then take it apart. See if you can find any toasted fuse or roasted wires. Also the reason for tripping the mains off is due to the fact that the oven is draining more power than it should. I would recommend a thorough inspection of the oven by an electrician..
Posted on Jun 18, 2008
  • 1462 Answers
SOURCE: meaning of symbols on oven setting.
i would know them if i were looking at it but hope this helps
line at top - top element only
line at bottom - bottom element only
line at top and bottom - conventional oven ie top and bottom elements on
wavy line - grill element
pic of fan - fan only with no heat
pic of fan with a line as well - fan oven
youi may not have all of these depending on oven.
best to use i find is fan oven - i do a lot of cooking!
Posted on Nov 05, 2008
  • 197 Answers
SOURCE: Smeg Oven
Their will be two elements in the oven a bottom element and a fan element, sounds like the latter has blown!
Posted on Oct 09, 2009
Testimonial: "Thanks, that helps. Will it be easy to fix? can I do it myself? "
Will not turn on after using selfclean
Hey there, does it not turn on immediately after you use self clean? Or will it work once oven has cooled down? Due to very high temperature during self clean, oven may need to return to a safe temperature before next operation...
May 22, 2011 | KitchenAid Architect Series KBHC109JSS...
Springs make a horrendous noise when you open the door. what is the best lube to use on them. grease or wd40?
The best repair is to replace the hinges and springs. If you do want to lubricate them do NOT use grease or wd40, these are flammable and do not mix well with heat.
Look up an appliance parts store in your city and pick up some high temperature copper or graphite based lubricant those are safe for use on oven hinges.
Jul 19, 2010 | KitchenAid Architect Series KEBC107KSS...
Kitchenaid Architect Electric range model KESA907PWW02 Error F2E0 STUCK KEY. Can't get rid of this error. Have shut off breaker for several hours -problem comes right back.Any ideas? Thanks M.S.
Thanks for using FixYa. Error F2-E0 on your kitchen aid means that the keypad is shorted and to resolve this issue you’ll have to replace the electronic range control/clock (ERC). Please do rate the solution if the issue is resolved or post a comment for further assistance.
Jul 03, 2010 | KitchenAid Architect Series KEMC308KSS...
Lower oven will not heat up
check the ignitor and the oven thermostat. the ignitor may glow but not get to a high enough temp for the oven gas valve to open. not specified whether elec. or gas.
Jun 18, 2010 | KitchenAid Architect Series KEMC308KSS...
I have a two ear old Kitchenaid gas range (KGRS807). It all at once stopped lighting the oven. The top burners still work fine. When you do anything in the oven (Bake , Broil, Convection) the electric...
You will need a new igniter module. The igniter module is told to spark by the control panel. There is also a flame detection for electronic start and that could be bad too.
Apr 16, 2010 | KitchenAid Architect Series KEMC308KSS...
KitchenAid Architect Series KEBC278KSS Electric Double Oven displ
Our fan on our oven is super loud. Always has been. We have to keep the door open so that it will cool off asap because it is so loud. What's wrong?
Mar 11, 2009 | KitchenAid Architect Series KEBC278KSS...
Oven elements not working but rest of oven does
try reseting your breakers may be partially triped if that dont work turn off breaker pull range out and chek the rower cord where it connects to the range if its burned on oneside replace cord and terminal block can get at lowes oven is fine just means cord wasnt tifhtned good when installed
Sep 23, 2007 | KitchenAid Architect Series KEBC107KSS...
Smeg S1100MFX5 Electric Single Oven Logo
95 people viewed this question
Top Smeg Ovens Experts
Hjalmer Lamminen
Hjalmer Lamminen
Jason Harris
Jason Harris
Are you a Smeg Oven Expert? Answer questions, earn points and help others
