Question about Reddy Heater RLP100 Portable Forced Air Propane Heater with Variable Heat Ouput
Do I need to vent my propane heater and if so how?
I was given a Magic Chef free standing propane heater,the cabnet is steel and is medium metallic brown,about 30'' high,24'' deep and 36'' across,access door on the left side where pilot is, two burrners inside.A fan is mounted in a housing on the back right side.It has a rectangle housing centered on the backside that is open on the top,possibly for a vent but I don't know.I can't find any information about this unit. Magic Chef,Model BA 5002,serial # 10265,window below wouldn't accept the model # or serial #.
SOURCE: empire corcho ventless propane wall heater 15000 btu
I suspect that this problem may have to do with your regulator. Only a guess though.
Posted on Oct 31, 2008
Accurate Joe
  • 61 Answers
SOURCE: Reddy propane heater RLP100
Try a little longer, sometimes it takes a full minute to heat the thermocouple. Check and make sure thermocouple is in flame. If all this is ok. then your going to have to change the valve.
Posted on Nov 30, 2008
tinytrees
  • 92 Answers
SOURCE: propane reddy heater shuts off
Either a bad ignitor or gloplug.
Posted on Jan 23, 2009
tbugger
  • 232 Answers
SOURCE: reddy heater r155d look-a-like--uses same motor and pump?
155 heaters use one of 2 motors. Either 097308-06 or 102001-30 (now 102001-33), depending on your model. They do not interchange or swap betewwn heaters. Go to www.reddyparts.com . Look up each number. Your motor will have a part number printed on it. Search that model and see if there is a replacement.
1/2" Rotor = HA3004
Posted on Feb 06, 2009
zonaluver
  • 7 Answers
SOURCE: Torpedo heater wont stay lit.
Do you have the serial number or the manufacture date? There are some design changes and I would need to know the year of manufacture to assist accurately. Usually it is a relay or the thermocouple connection that will affect the unit staying lit.
Posted on Mar 29, 2009
We were given an 87" stainless steel propane patio heater. Our deck ceiling is 96". Will that be enough clearance?
Had a look at the manual on a BFX750 patio heater and the distance required is 50cm above (18") and 60cm to the side (24"). If its the same type with around 13kw or 44,000BTU/h of power then this is the clearance is needed for air and heat.
Dec 31, 2012 | Stainless Garden Sun Steel Propane Patio...
I need a thermocouple for a dyna glo natural gas wall heater
Billy here's a link to A & B Sales. They have what you're looking for. Whether your heater is Natural Gas or Propane makes no difference when it comes to thermocouples.However the length of the tubing does when it's a wall or stand type vent-free heater.
http://www.aandbsales.com/2.html
Hope this helps you & thanks for choosing FixYa.
Sep 21, 2011 | Rinnai Desa Vent-Free Infrared Gas Heater:...
I have a vanguard vn1800e natural gas would like to convert it to propane is this possible
Sorry, but no vent-free gas heating appliances can be converted from one gas type to another. There are no conversion kits available for any vent-free gas heating appliances.
Wish I had better news for you.
Mar 14, 2011 | Vanguard International Infra Red - Medium...
I have an magic chef mvp V microwave and have just put in new cabinets. Do i need to cut an air vent in my cabinets or does it vent through the front?
Consult your installation instructions for that information.
For more help from Magic Chef / Ewave see here or their contact page or order parts here.
You can download owner's manuals for many Magic Chef models here.
We're happy to help you with free
advice and we'd appreciate your thoughtful rating of our answer.
Jun 05, 2009 | Microwave Ovens
Where can I find magic chef wine cooler compressor for MCWC52B
My Name is Mike. I have the same unit. The compressor is not bad. Replace the start relay& overload on compressor.
Mar 31, 2009 | Magic Chef MCWC45A Wine Cooler
Vent fan high comes on automatically with cooking
Right, that would be MCO10UW and the owner's manual is here.
The owner's manual does say this, of course,
"To prevent overheating from taking place, the exhaust
fan is designed to automatically turn on at a low speed if
excessive temperatures occur. Should this happen, the
fan cannot be manually turned off, but it will
automatically turn off when the internal parts have
cooled. The fan may stay on for up to an hour after the
range and microwave oven controls have been turned
off."
That;'s standard on microwaves.
But these models do have a separate internal cooling fan (which should run any time you microwave) plus the hood vent exhaust fan, which should only run when you select it, or if there is an excessive stovetop or under-hood temperature.
So if it comes on whenever you microwave, that is incorrect.
When that happens, it's usually a defective vent thermal switch (a.k.a. hood TCO).
But since it's brand new, I would certainly contact Magic Chef about this. If it's in need of repair, they will fix it free, assuming the oven wasn't physically damaged.
For more help from Magic Chef / Ewave see here or their contact page.
For Magic Chef in Canada call 866.587.2002
Jan 08, 2009 | Magic Chef CMV1000B Microwave Oven
I dont know how to hook the vent fan for outside on the Magic Chef CMV1000B?
Dec 05, 2008 | Magic Chef CMV1000B Microwave Oven
We are switching from Propane to natural gas and the stove didn't come with orifices and a manufacturer said that it didn't need them that they could be adjusted. they didn't tell us how. Its on a Magic...
Hello dradon,
Welcome,
You said,we are switching from Propane to natural gas and the stove didn't come with orifices and a manufacturer said that it didn't need them that they could be adjusted. they didn't tell us how. Its on a Magic Chef 3110PRW
I am glad you asked us before attempting to do this change!!!!
This is something that should be done by a qualified gas technician due to safety concerns.
Here is a number that you can call to see if there is a kit available for your model.
Magic Chef
Customer Experience Center US 1-800-688-9900 Canada 1-800-688-2002 or Consumer Parts Dept 877-232-6771
I'm glad I caught you before you started.
I know of some tragedies from this!
Huuum
Oct 16, 2008 | Magic Chef Kitchen Ranges
Heating & Cooling Logo
64 people viewed this question
Top Reddy Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
T bone 1963
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
