Question about Sony Walkman NWZ-B105F MP3 Player
Being Able to Use the Mp3 Player
I turn it on and it works but then if I try to go to the music library or fm it immediately powers off. Any ideas on how to fix it?
  • katonxD Dec 04, 2008
    I have a similar problem although I doubt firmware can fix it. [I tried but.. well here's my problem]. I noticed that one of my songs played only a mere 20 secs or so before it pauses and stops. I try it again and it repeats. So I figure it was the file that was corrupted or something. I plug it into my computer to replace the corrupt file with my backup--guess what? I plug it in, the device manager pops up for oh, 6 secs tops? Then the media player turns off (by itself! the screen blanks!) and less than 2 secs later it turns back on... and the vicious cycle repeats.
    I tried firmware. but its not good if I can't gain access into the media player long enough before it turns off one me. gah... I'm so very desperate for my music. Please, any suggestions will be appreciated.
  • 3 Answers
Downlaod the new sony firmware (version 1.1) Once you load it, it should do the trick. I just ran into this problem today and that solved my problem.
Posted on Nov 30, 2008
How do I download music to my COBY MP3 Player?
Does it show up as a USB drive in windows explorer? If not you may need to see if there is a menu option some where in its settings to change it to a mass storage device. It should then show up in windows explorer where you can drag mp3s to the music folder or copy and paste them.
Jan 02, 2015 | Super Talent MP620-2GBK Coby Mp620 2gb...
What do I do to Eclipse fix mp3 when it diplays "Disk Error!" upon attempting to play music?
Presumably the error is caused by a hard disk drive? In which case the hard disk will need to be checked. If there are options to do this use them. Otherwise the drive might need to be replaced.
If you bypassed the normal way of putting music onto the drive, then it might have corrupted the drive.
If there is an option to reformat the drive that might work. Or if there is a factory reset, that might correct it.
If you have music stored on the drive, which is not found anywhere else, then I think it will have been lost for good.
May 27, 2017 | Eclipse Audio Players & Recorders
What should I do when Elcipse mp3 displays "Disk Error!" upon trying to play music?
The players laser reader has burned out, your best option is to replace the deck.
Apr 05, 2017 | Eclipse Audio Players & Recorders
How do you erase the music library from a MuVo2 FM MP3 player?
To delete,Open media player* plug in mp3/4* highlight song/s* right click mouse and choose delete
certain models let you remove songs directly from the mp3 player but some dont if you plug it in to the computer a file in My Computer should show up called removable disk E where you can treat the mp3 player like any other folder if you right click on the icon for a specific song it will delete it from the mp3 player but it wont show up in the recycle bin because it was never actually on the computers hadrive
Thank you
Mar 14, 2010 | Creative Labs Nomad MuVo2 FM MP3 Player
My fm radio stopped working on my creative zen vision, and the display is all messed up. It also freezes for about 20 minutes when I turn it on. After 20 minutes, it will play normal, but it freezes...
Support for Zen Vision M on this site:
One of the Knowledgebase Solutions for "freezing" gives this answer:
Solution ID: 64087
dot-clear.gifSolution ID # 64087 -->dot-clear.gifdot-clear.gif -->
Player is Freezing
Keywords / Key Phrases: freeze, freezes, freezing, hang, hanging, freezes at creative logo, at docked screen, rebuilding library screen, playing audio files, switching to other functions or menus while shutting down, freezes at recovery mode, freezing at music playing now screen
  1. Gently push the end of a thin object (such as a pin or straightened paperclip) into the Reset hole.
    The reset button for your player is located at the bottom of the player, to the left of the sync adapter port.
  2. Refer to the article below to access the recovery mode and perform a Clean Up.
    SID 64088: Accessing the Recovery/Rescue Mode of your Player
    1. Clean Up scans a player\'s hard disk/memory card and removes any invalid links from the music library. It does not affect the working music files at all. It is recommended that you perform "Clean Up" first before formatting or reloading the player\'s firmware.
    2. It is advisable for you to clean up your player regularly if you are frequently transferring files from you computer to your player or vice versa.
Last updated: June 16th, 2009
Aug 08, 2009 | Creative Labs ZEN Vision:M Digital Media...
My 3110c phone's music player isn't working .
Open the music player. Press the left selection button and select Music library. Scroll down to select Update library. This will update the MP3 files to the library. If there is any MP3 file deleted or missing, it will be removed from the list from the music player.
Just select one of the MP3 file in your memory card and open it. It should work with media player. If it works with media player then the problem will be with the music player.
If this happens, go to Settings and select Restore factory settings and it will ask a password. Type 12345, and it will restore the settings to default. Then open the music player and update the library and it should work.
Thank you,
Jul 09, 2009 | Nokia 3110 Cellular Phone
Keeps power off when i want to play a song or use the fm function
    Please find reset button and reset it.It will start working.
Thanks for using fix ya.
Oct 08, 2008 | Sony NWZ-B103FBLK MP3 Player
Downloading music.
hi there gurdy!
Sony mp3 players are great mp3 players, except with one problem. You need to get Sonicstage, the mother program for their mp3 player, to put music in their. So, one way is to go here first:
download the Sonicstage program, and install it into your computer. (WARNING! First install the Sonicstage, then connect the mp3 player to the computer, otherwise it might not work.)
When you are done installing it, and you plugged the mp3 player, open up Sonicstage. It should open up with a screen saying many things such as My Library, Transfer, Music...
From there, go to add music (top left corner button next to My Library, next to it) and three choices should come out, saying add files, add folder, or import CD. From there just add files from your computer.
Then, click the Transfer button. There you should have a split screen, half My library half Transfer aka mp3 player space. Choose the songs you want to import and click the arrow pointing right (in the middle).
Give it a few minutes to download into the mp3 player.
After it is all done, either exit the program or just pull out the mp3 player and wha la music to your ears!
It's a nice mp3 player.
Hopefully this solution helped out.
Please contact or reply if you have anymore problems.
this is where you can read the manual and all the information about it.
Nov 23, 2007 | Sony NW-E002 MP3 Player
No music library content
try downloading the MP3 player recovery tool from Creative's website (the tool contains the latest firmware update available -- 1.15.03). Plug your ZV+ into your PC, run the program and let it update the firmware. Then format, reload your music and try it.
May 13, 2007 | Creative Labs Zen Touch MP3 Player
Zen middle side buttons not opening Music Library or any of the other sections
If pressing the Reset button doesn't work, you should probably try reloading the firmware (this would be a good time to update your firmware anyways). You can get the latest firmware off the Creative site under "Support". Just be sure you select the right player, as there are several on the list that look similar.
Mar 20, 2007 | Creative Labs ZEN Vision:M Digital Media...
Sony Walkman NWZ-B105F MP3 Player Logo
56 people viewed this question
Top Sony Audio Players & Recorders Experts
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
