Question about Daewoo DTQ-20U4SC 20" TV
Rolling lines a only a few stations
HELP!!!! I have tried everything. I have had this TV for about a year and I have rolling lines on about 5-7 channels (i.e. 25 (VS), 36 (TBS), 59, 62, etc...) I have checked cable wires and other TVs and the problem is only on this TV. Any suggestions?
Check for other appliances near t.v.
Posted on Jul 05, 2007
Timer light will not stop flashing. can't turn on TV
Unfortunately the first generation DLP's from Mitsubishi are prone to have Capacitor failure through out the chassis. Most likely that is what your set is experiencing. I would start by replaceing the suspect caps on the DM amd The Power boards. You can get the V26 Chassis DM/Power repair kit from www.tvrepairworld.com which also contains instructions.
Jun 21, 2010 | Mitsubishi WD-52725 52". Rear Projection...
My dlp samsung has slanted vertical lines on most stations but not all. what is causing the lines and is it something i can fix? tv is about 5 years old
Do you have cable ? and is it only on local stations ?
Call your cable company to check the lines. I had the same problem they came out and fixed it free of cost.
Dec 20, 2009 | Samsung DLP HL-P5663W 56" TV
Rolling lines on screen
Sounds like the power supply has a bad capacitor. This problem can inject excessive 60 hz from the AC line into the vertical stabilizing picture system. The hum also my come from the same reason, bad or leaking filter capacitors. Cheaper just to buy a new TV or borrow another TV and connected to your system to see if the problem still occurs.
Mar 16, 2009 | RCA F36668 36" TV
50 inch LG plasma model 50PX5D. Lost picture and sound
well it looks to me u need a new tv....all the details u give are pointing that ur picture tube is gone.....but call LG help and costumer line and ask them......u may get away from it to get a new tv
make sure when u get a new plasma to extend ur warren tie to a max o 3 to 5 years and if this would happend u get it repaires for free.......cost for a new screen app 1000 to 1500 dollars
Mar 12, 2009 | LG 42PC3D 42 in. Plasma Television
Rolling white lines
sometimes this can be caused by two connected devices being on the same av channel,try connecting one at a time,also check your tv is set for your region etc,pal or ntsc.and you could look in your tv settings menu and check your output ie rgb scart,forgot the other options,,hope this helps
May 25, 2008 | Hitachi 53UDX10B 53" Rear Projection...
According to your post you seem to only be having the problems on the UHF channels. I would need to know what your source is IE: Antenna or Cable.
May 01, 2008 | Televison & Video
Vertical rolling on Hitachi 60SBX78B
It ended up being the Verizon Fios box. We recycled it and the picture stopped rolling. Thank you for being here to help. If I have any future questions, I'll definitely use your site.
Mar 07, 2008 | Hitachi 60SBX78B 60" Rear Projection...
Local tv channels come in snowy
you have cable and the stations are still snowy? could be tuner do you have a box or directly hooked up to tv, try unhooking box if you have one and directly hook it up to tv if you havent already done so
Jan 21, 2008 | Zenith C32V37 32" TV
Thin vertical line
What you have described is definitely some form of Electrical Interference. Interference can come from a variety of causes. Is the Cable Inputting the Cable Box close to some High Voltage Electrical Lines? Or Are you located near some Electrical Power Station? Or A Police station, where the Radio Transmitter of the Police Station causing the Interference? As I said, there are a variety of reasons. Also, Try to check if the connector is loose at the rear of the Cable Box, or at the rear of the TV. You will have to eliminate every possibility reason. Wish i could help further.
Jan 21, 2007 | Mitsubishi CS-35405 TV
Daewoo DTQ-20U4SC 20" TV Logo
54 people viewed this question
Top Daewoo Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Daewoo Televison and Video Expert? Answer questions, earn points and help others
