Question about LG 42PC3D 42 in. Plasma Television
Plasma TV How do I get a good signal on a plasma TV, the screen often goes blank with the sign saying 'no signal' does it need a specific aerial & pole height? It is conected to a co-axil cable but fragments & loses signal, any ideas?
  • helga22 Nov 23, 2008
    Thanks for taking the time to reply, your hints will be put into effect ASAP for a better signal.
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
To get a good signal on all TV units, the source must be good and strong. The source could be an aerial antenna or connection to your local cable provider. The message "No Signal" indicates that the TV cold not receive a decent TV signal. With this in mind, possible solution wouold then be to increase/improve the incoming TV signal:
  • if you are using an aerial, 'height is might' to overcome any line-of-sight obstruction. Additionally, there are antennas with higher gain, meaning they could receive better than other antennas. Another option is installing a pre-amp or commonly called booster;
  • if you are hooked to a cable provider then it may be to your advantage to bring this concern to their attention. They could try transferring you tap off point to a better distribution box, replace your coaxial cable with low loss or even in some cases, install an inline booster;
  • possible RFI (radio frequency interference) which could come from wireless phones, garage door openers, WiFi, electronic dimmers, electronic ballasts of high density lamps and others. If any are present or within the immediate vicinity, pls try to relocate or reposition.
Just a start, do postback how things turned up or should you need additional information. Good luck and Thank you for using FixYa.
Posted on Nov 23, 2008
Will not tune in channels on auto store
Well, there's your answer then. You have poor aerial signal so the TV cannot lock on when tuning. You need to sort out the reason why there's "Poor or No Signal" You need to fix the aerial, not the TV. I would have thought that was self-evident, surely?
What kind of aerial are you using. Do you know it works? Check out the aerial cables for breaks or badly fitted connector plugs.
Sep 15, 2014 | Samsung PS42B430 42 in. Plasma TV
Cannot get a good signal for Channel 5 or Channel 5 etc. However signal for BBC is excllent. Help
I would try the tv on another known aerial and then re install on the new aerial. as what you describe sound like a signal fault.
Mar 11, 2011 | Panasonic Viera TH-50PZ80U Plasma TV
Horizontal thin coloured lines on screen, whilst still getting sound
Check the inteference,by other electronic devices such as radio and television and keep electronic ,magnetic devices away from the tv.
Does your aerial need more boost?
If you have a digital aerial inside your roof this can affect the signal.
Oct 26, 2009 | LG 42PX5D 42 in. Plasma HDTV
Samsung 50 inch plasma tv screen goes blank temporarily
This could be caused by a loss of video signal either from the connection or from the source. The TV may have detected an error which caused the screen to go blank. If this occurs again, check the cable connections and see if having the TV unplugged overnight resets the TV and eliminates the problem.
Jul 18, 2009 | Televison & Video
Plasma tv makes loud static noise screen goes blank and shuts off
Take the back off and try to isolate where the sound is coming from.
Nov 24, 2017 | Philips 42PF7320A 42 in. Plasma HDTV
Nec plasma, PXT-42SV1 intermittant picture goes to blank screen.
blank screen do you mean a blue screen or does it go dark
Jun 11, 2008 | Televison & Video
Projectile motion
Dear Sir,
I have NEC 42vR5 HW Plasma monitor, this plasma goes off with in 1 Minute, pls. give solution
thanks
pramod
Feb 24, 2008 | NEC - 42" Commercial Plasma Screen ****(no...
Screen frozen
Un plug the power to the Plasma Screen and also to the Media Receiver for ten minutes. Disconnect the off the air antennas both A and B. After ten minutes plug in the plasma screen then the media receiver and turn on wi the remote control. You should now be back in operation. I was.
Also It may not be a bad digital tuner. The TV Guide feature is active even when the zip code is set to all 0s so if you have an over the air antenna attached the TV will look for the TV Guide info and if it can not find it because of a weak signal or the chanel it is tuned to does not carry that information the TV thinks that tuner does not work which triggers the 12 flashes. Also on power up the gray box with the waring message "Plasma Display Starting Up, Please Wait" appears and the screen is blank.
Dec 29, 2007 | Pioneer PDP-5060HD 50 in. Plasma...
Plasma TV
If you mean the picture froze or formed fuzzy pixelated picture and crackling, this will be due to a poor aerial signal to the tv, but if you mean the screen rolls with pink/white patchwork type squares and shows the picture in the background, all be it fuzzy, then that's the same fault as I am getting and have had to report the fault to LG as I am on my second TV. If it is the problem mentioned in the first sentence, it is happening to our friends in OS and they have been told by specialist aerial fitters, the signal is too weak for the tv.
Mar 16, 2007 | LG 50PX4DR 50 in. Plasma TV
LG 42PC3D 42 in. Plasma Television Logo
166 people viewed this question
Computer Repairing
Computer Repairing
