Question about Roper RS22AQXKQ Side by Side Refrigerator
Frigidaire FRT18HB5DW2 fridge not cooling
My Frigidaire is just 1 yr old and the fridge could not cool down since 2 days ago. temp keeps at about 55f., but the freezer (on top) is working good. Anyone can help? thanks1
  • fridge_prob Oct 25, 2008
    frost forming and preventing air circulation. unable to locate the defrost timer / breaker
  • jebeljelloud May 18, 2009
    fridge not cooling?
  • 237 Answers
Sounds like an air flow problem to the lower unit. Take the sheetmetal or plastic rear cover off the freezer back wall and make sure the coils are frosted up good and even but NOT a block of ice inches thick (air needs to circulate and a blocked coil won't let air move over it efficiently). Make sure the fan is running to move the air around. In the fridge area make sure the air dampers are letting the cold air from the freezer down to the fridge compartment. Depending on what you find will determine the next steps so let us know.
Posted on Dec 27, 2006
  • Marc Wilson
    Marc Wilson Dec 29, 2006
    Hey, what's with the "poor" rating. We asked you to investigate something and then let us know what you found so we could go from there????
SOURCE:
FRS26R4CB0-Freezer not freezing and Fridge not getting Cool
Hi Candi,
I don't know this model but most friges are the same,
Check on the bottom back, there should be a radiator with a small fan
installed.
If the fan is not working this maybe your problem,
It is not colling the gas.
You also may have a gas leak or the gas compressor is not working
or starting to work because of a faulty capcacitor.
Jan 11, 2014 | Frigidaire FRS26R4C Side by Side...
4 yr old Top Mount Frigidaire freezer is not freezing
Even after you had unplugged and started if the fridge is not cooling well then the compressor is not having the right pressure for the heat exchange. The possible problem can be fault in the compressor or lack of gas in the system. check if the compressor motor speed is fine and pumping well, need to use a current test witth a clamp tester. If not check on the contacter relay, the capapcitor. If ok the gas pressure must be checked or refilled. I hope you can follow this out and try. Good day,
Jul 27, 2010 | Frigidaire FRT21H8 Top Freezer...
Fridge side not cooling. freezer works. 6 yr old side by side
There is a little fan that blows air from the freezer side to cool the fridge side. Pull the plug on the refridgerator for over night, long enough to give it time to defrost if there is any, then plug it back in and see ifthe fan is running. If not then it probably needs to be replaced. If it keeps frosting up and stopping the fan then the defrost timer is probably bad and will need to be replaced.
Nov 14, 2009 | Frigidaire FRS26R4A Side by Side...
Does not cool
coils iced up. keep fridge unplugged and open for a while to defrost. dry up inside and possible puddle underneath. plug in, turn on, and leave empty for a day so it'll reach it's temp, then fill it up.
Jul 20, 2009 | Frigidaire Refrigerators
Servis frost free fridge freezer makin crackin noise afew tyms a day
this is not unusual on any make. the cracking noise is the cabinet creaking with change in temperatue. don't worry about it
Oct 18, 2008 | Engel Freezer 22 Qt. Fridge/Freezer
Not cooling or cold
The REFRIGERATOR WAS MOVED TO ANOTHER SITE. AND IT HAS NOT GOTTEN COLD SINCE MOVE, PLUB UP 2 DAYS AGO. iT WAS UNPLUG AND CLEAN 2 DAYS BEFORE MOVE. COULD IT NEED ANTI-FREEZE?
Aug 25, 2008 | Whirlpool ET1FHTXM Top Freezer...
Fridge Problems
what model and make is it
Oct 30, 2007 | Refrigerators
Roper RS22AQXKQ Side by Side Refrigerator Logo
315 people viewed this question
Top Roper Refrigerators Experts
Steve Allison
Steve Allison
Sal De
Bruce Denton
Are you a Roper Refrigerator Expert? Answer questions, earn points and help others
