Question about Maytag PYE2300AY Electric Dryer
DE 412 Overheats
Our 20 year old Maytag DE 412 occasionally overheats, even with a minimal load - a few towels and a set of sheets.
This only happens occasionally and I have checked to ensure that the filter screen is clean and free of lint and that there is no blockage in the external exhaust vent piping. We shut off the dryer for 10 minutes to cool down after running for about 20 minutes and we would never leave this running while we are away from our residence.
Any ideas? All suggestions are appreciated.
Thanks!
Bob
  • 1 more comment
  • bobsheelah Nov 23, 2008
    I have the same problem with a 25-yearold DE410, even on air fluff the clothes are burning my hands!
    I have the same problem with a 25-year-old DE410, even on air fluff the clothes burn my hands!
  • rjhooper Nov 23, 2008
    Thanks,
    I think I will start with the replacement of the cycling thermostat, a relatively inexpensive part ans something I can easily change myself. I don't think that the cycling thermostat is cutting off when it should and it causes the element to overheat.
    I'll let you know the outcome once I have located the replacement part and installed. It may take a few days only because of some out of town work commitments this week.
    Bob
  • 706 Answers
Folks,
In most cases, the heating element is provided power via a relay and that relay is controlled by the electronics. On older dryers, you probably have a small motor driven dial that rotates and is basically a timer. If that motor fails to rotate or is slower than it should be ( due to age or worn gears) you may experience over-temp conditions. You should still have over-temp 'snap switches' that sense the over-temp condition and 'should' de-energize the relay that provides power to your heater element. If that relay is sticking in the "ON: postion, then regardless of what the controller says, the heater will remain powered up.. So in essence you have a few components that are suspect.. IT may or may not be worthwhile removing and replacing them in a 'shotgun' manner to determine the the root cause but if you do... be sure to disable power from the system BEFORE any service takes place.
Also: the temp control may bve dictated by power resistors that are switched in series with the heating element itself to limit current through that element ( and reduce the overall drying temp). If any of those power resistors have changed value over time or are not switched into the circuit via the controlsm the symptoms will be similar. AS painful as this may sound, 20 - 25 years of service from any appliance is considered above and beyond the normal life span so consider yourselves lucky that you got that kind of mileage out of them. The cost to diagnose and repair may make it impractical at this point and you may be better off just replacing with newer more energy efficient models. Your call.. Hope this helps..
Regards,
Rick
Posted on Nov 23, 2008
Overheating radiator
You may need to replace the radiator even if your Dodge only overheats occasionally
Jun 23, 2013 | Dodge Dynasty Cars & Trucks
Acer Extensa 4420 overheating
The laptop must be dismantled to access the motherboard, buy a can of compressed air attach straw. Now remove fan and the heatsink, blow out all open ports and fins on the heatsink and fan, next! remove thermal grease from the processor and heatsink with rubbing alcohol and a paper towel, now! apply fresh thermal grease to the processor and heatsink, "small thin layer evenly spread" now assemble, "solves most heat related issues"
Apr 19, 2012 | Acer Extensa 5630-6806 Notebook
Overheats sometimes not always
Let me guess, a 4cyl engine. They were notorious for headgasket issues even occasionally in the 6cyl models.
May 18, 2009 | 1993 Dodge Shadow
Dryer cuts off before clothes are dry.
Might be the thermal protector in the motor that is shutting down the dryer, if motor overheats this is what will happen. Make sure there is no lint build up around the motor, if not the motor is bad. does the dryer start right away after shutting off or do you have to wait? If you have to wait the motor is bad.
Jan 13, 2009 | Kenmore Elite HE4 Electric Dryer
Hello: I have a Maytag, do not know model # as I inherited the 5 year old model when I purchased a condo and it is now 7 years old. The front of it states Maytag - Dependable Use, Heavy Dtuty - Large...
I ALWAYS START WITH VENTING WHEN CALLED WITH LONG DRYING TIMES BUT I HAVE SEEN WHERE ONLY HALF OF THE HEATING ELEMENT IS WORKING, WHICH IS PRETTY RARE. A NORMAL LOAD WOULD BE WHATEVER THE WASHER HAD IN IT WHICH WOULD BE LOOSLY FILLED TO THE TOP ROW OF HOLES IN THE WASHER TUB. THE ONLY OTHER QUESTION I WOULD ASK IS IF THE WASHER SEEMS TO BE SPINNING OUT PROPERLY AND IF THE CLOTHES ARE GOING INTO THE DRYER TOO WET.
Jan 10, 2009 | Maytag LSE7806A Top Load Stacked...
Maytag dryer will not start completely.
replace motor it would hold a load and is kicking out on over load switch
Dec 08, 2007 | Maytag Neptune MDE5500AY Electric Dryer
Maytag PYE2300AY Electric Dryer Logo
148 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
