Question about Daewoo DVG-5200S DVD Player
No disc when disc is inside?
Hi, my grandpa's daewoo dvd player seems to be unable to read discs, no matter what dvd I put in it, it spends about 2 minutes "Loading..." then it says "No Disc" I'm not sure what the problem might be I tried spraying the inside with computer duster but it had no effect.
  • Anonymous May 02, 2008
    my daewoo dvd/dvg 5200S will note do anything, I put a dvd all it reads is loading, I let it run for 2 min. once and nothing. I think it just needs to be trashed and by anything other than a Daewoo.........
If the disk does not spin up, then it is the motor, which has a high fail rate, and can be replaced easily. It is available from MAT Electronics and others.
Posted on Sep 27, 2009
    Scholar:
  • 168 Answers
Open the cover of the unit, but be sure that it is unplugged. try cleaning the lens with a soft dry cotton swab. donot put any cleaning liquid on it. just dry cotton swab. also put the nozzle of the duster on the lower part of the lens assembly to remove the accumulated dust. if its still doesnt work have it check by a qualified service technician. good luck!
Posted on Jan 19, 2007
SOURCE:
Whenwe try to use dvd it reads bad disc used dvd
Hi did you try cleaning the washer that spins the cd they often get glazed and slip causing the cd to spin at a low rpm causing the bad disc error.
Feb 01, 2010 | Daewoo DV-6T955B DVD Player/VCR
Incorrect disc
The first thing i would suggest you to do is a hard reset by unpluging the the player for 30min and then try again.
If this does not solve your problem then please see if the player tries to read the disc.
Load a disc and listen.Does the player make squealing noises or is it totally quiet? Squealing noises may indicate that the player is trying to synchronize with the disc but can't due to an obstruction on the lens or in the laser path inside the pickup or a defect in the pickup. This can also be caused by an intermittent signal problem due to a faulty ribbon cable.
Totally silent means that the photo sensor is not getting any usable input from the laser at all, meaning that the pickup is "blind" for lack of a better word.
This can be caused by an obstruction of the beam by foreign matter on the lens or inside the pickup all the way to a marginal or failed laser diode and/or photosensor array. This can also be caused by a bad ribbon cable with one or more severed traces.
You could try to clean the optics. This is the most common malfunction as far as i know in all disc players. It would involve taking the cover off and finding a way to expose the lense, and then cleaning it with a very gentle brush. some players have a cover for the lense that swings to the side during playing, this greatly reduces the chance of dust accumulating, but its still worth the try.
If you actually see dust on the lense, then its just that simple. clean, close, play.
It may also be worth your while to check on the small shafting that guides the carriage of the laser pickup. Dirt, grome, dust and solidified lubricant can cause stoppage of the carriage and the laser eye then fails to read the next track. Please refer to the image below.
If the problem still persists then you will have to get it repaired and thats the only solution..
Goodluck..
Mar 17, 2008 | Toshiba DR4 DVD Recorder
Philips DVP5140 region-free DVD player: NO DISC
You could try cleaning the laser using a laser cleaning disk. Most of the time when it cant read a disk its just because the laser is dirty. If that doesn't work it could just be a faulty laser
Sep 21, 2009 | Philips DVP5140 DVD Player
No matter what DVD we put in, the player stays on "READ"
either the disc you inserted hasn't got a menu. the only thing DVD's do this is because there is no Menu provided in the DVD DISC. In the other case, where it remains "read" the disc might not be clean, scratched, dusty or simply incompatible with your DVD Player. Always clean discs before and after playing them in your DVD Player. Hope this helps, good luck!
Jun 20, 2009 | Goldstar GBV241 DVD Player/VCR
No valid disc error
these built in tv/dvd players have this problem the laser inside tends to burn out. being unable to read discs. it may be dirty and you can try to clean it with a laser disc cleaner or by blowing the dust out with compressed air . but more than likley the laser is damged and you will have to go into a repair shop.
Apr 26, 2009 | Televison & Video
Disc reading error
Hi, please browse through my solutions. You will find your answer there. Good luck.
Dec 03, 2008 | Pioneer AVIC-N2 Car DVD Player
Bad disc message
Did you try cleaning the eye i have had dvds that would not play because the eye was dirty
Mar 10, 2008 | GoVideo Go Video DVD/VCR Combo
Daewoo DV-6T955B DVD Player Problem
If your DVD is less than a year old, still under manufacturers warranty.
The problem you have "no Disk" is because the laser is not reading the DVDs.
Call the Main support number at 800-323-9668
Support FAX 973-384-9250
Email support service@e-daewoo.com
Mar 06, 2008 | Daewoo DV-6T955B DVD Player/VCR
Durabrad DUR-1700 - No Disc
turn on the power and open the dvd axcess door, inside where the dvd goes is a small little push down switch, push this down, it is in the upper right side. this will let you see if the laser is powering up,if you see no red light ,your laser is bad. hope this helps
Aug 06, 2007 | Durabrand DUR-1700 Portable DVD Player
Daewoo DVG-5200S DVD Player Logo
289 people viewed this question
Top Daewoo Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Daewoo Televison and Video Expert? Answer questions, earn points and help others
