My icemaker quit working, I have checked all the water valves and they are working poperly. it is not getting water, and I can't seem to figure out why. all the motors i have checked so far are ok. does anyone have a wiring diagram so that i can find the relays and check those.
Water despenser is working fine,but ice maker is not working
2 yr old maytag french door refridgerator
If the ice maker solenoid valve is letting water pass (check that for sure) then there is the high probability that the fill tube is frozen. Check this diagram out to follow the tubing. http://tinyurl.com/y6qyu4
Also check the bin full arm as the spring will jump off and not let the ice maker work.
Buy your wife a new refrigerator. She deserves it.
That happened to us--it turned out that we just needed to replace the water filter. The filter is expensive--around $40 every time you replace it.
SOURCE: Frozen ejector arm
sounds more like the heater in the ice maker is bad. The cycles of the ice maker are: 1. water comes in to fill ice maker. 2. water freezes in ice maker making. 3. heater comes on to help ice release. 4. motor comes on to eject the ice and start all over again. if the heater doesn't come on the ice will not eject. replacing the icemaker is typically what needs to be done in this case.
SOURCE: Kitchenaid Icemaker does nothing. Ref. Mod.kscs25Inssoo
This also happened after I changed the water filter. The small black rubber tube that fills the tray was plugged with ice. Instead of hot wash cloths I used a hair drier for a couple of minutes.
SOURCE: KitchenAid Superba KSCS25FKSS00 SideXSide Refrigerator
Manufacturer recall on door because the wiring was cut by use. Replaced free by certified repairman.
WATER DID NOT COME OUT AND ICE MAKER ALSO DID NOT WORK
No water coming into icemaker even though the water dispenser in door works.
Icemaker control light blinking. Nothing about it in (useless) manual.
I have a full freezer Kichenaid Model krff15msaly0 Ice maker that was working but we disconnected it and then reconnected it to find that it doesn't seem to be getting water.
ice maker quit working even though water is coming to water dispenser.
My arctica water dispenser is working fine but I'm not sure if the ice maker is getting water as it stopped filling up some time ago. I read that the solenoid might be a problem but is this so if I can get water?
I HAD no ice being made but I had water. I called into a radio on-air repair guy who told me it was probably the water inlet valve. I took the lower back of the fridge off and saw some device where the water source went in, then out to the filter, then back to the device, then into the fridge....and another line went to along the outside of the fridge into the freezer side of the fridge. I replaced this device for $55. I now have water (same as before) but instead of it shutting off quickly when you withdraw your glass, it dribbles on a half second or so. AND, I still have no ice.
With power on to the ice maker, I checked for Power-YES. I checked the Mold Heater - HEATER WAS OFF. I checked the Motor - MOTOR IS OFF. I checked the Thermostat - THERMOSTAT IS OPEN. I checked the Water Valve - WATER VALVE IS CLOSED.
So now what?
water is not coming out of the line....Also bottom of freezer is freezing up.
not making ice but water at dispenser
same problem. what is the problem
Water dispenser works but ice maker gets no water and light for ice maker near the on off switch is blinking.
the water valve is not stopping the water.
The ice maker is not receiving water but the water dispenser is. I can not seem to figure out why the water is not going to the ice maker but is going to the water dispenser - they are right next to each other. When I disconnect the hose for the ice maker and turn the water back on it does not come out of the ice maker's water valve, but of course the water dispenser still works fine. I am so frustrated. What is going on and how can I fix it?
Same thing, no water getting to the icemaker. I see the water just at the top of the line on the back of the refrigerator, but still not getting water to maker. Checked all the lines they are ok, checked power to valves, they are getting power. Icemaker motor seems to be working.
Kenmore ice maker isn't making ice.
ice maker in side by side amana SBD20NW fridge not getting water but water depenser works
this is the 2nd solenoid i hae had to replace... my little 3 year old keeeps sneking out a tnite to get snacks fromt the fridge and leaves the door open melts tehn it gets closed and refreezes jamming up the module.... could thi be why other wise i got no clue why the ice make side solenoid has gone out twice... checked it and it has infinite resistance so i know its shot...
