Question about LaCie d2 Extreme 250GB External with Triple Interface USB 2.0/Firewire 400/800 - 300790U ... Hard Drive
A lacie d2 extreme 250gig triple won't mount anymore
System profilers on all 3 of my macs only recognize that there is an unidentified device attached to the port (i've tried them all, fw400 800
& usb 2) with a data rate of (whatever port it's on). It seems hopeful that this is not a problem with the actual hard disk, but with either drive or cage electronics. (I'm trying to keep optimistic here as it's been having to do duty as the media scratch drive for a macbook pro so stuffed with apps, app-support, plug-ins, beta builds and extras that there simply was no way it could handle the raw media libraries. If you just have a pointer as far as what direction to look to learn more, that'd be fine. Or, anything really. I'm just looking for a starting point.
    Top Expert:
  • LaCie Master
  • 49,128 Answers
Try deleting /uninstalling everything that is not absolutely necessary to free up ram space and see if it improves the situation
Posted on Mar 25, 2017
fire sine
  • 382 Answers
SOURCE: bought a new LaCie drive; isn't recognized by mac or pc
Lacie Porsche drives in my experience or infamous for not having the most durable bridge boards. The bridge board is a chip that has a chipset on it which take the SATA or PATA connection and send it to the USB and or Firewire ports on the enclosure. If the drive is powered up, you should get a small red or orange light on the front. When connected to either mac or pc ( porsches are MS_DOS formatted out the box ), if it does not mount or does not appear in DISK UTILTY, then it is a high probability that the enclosure/bridge board has failed and the drive ( if not making grinding, buzzing, clicking or beeping sounds) will have to be extracted and placed into a more stable enclosure. Hope this helps.
Posted on Oct 02, 2007
fire sine
  • 382 Answers
SOURCE: Lacie Drive making awful noise!
Lacie D2 drives in my experience are infamous for not having the most durable bridge boards. The bridge board is a chip that has a chipset on it which take the SATA or PATA connection and send it to the USB and or Firewire ports on the enclosure. If the drive is powered up, you should get a blue light on the front. When connected to either mac or pc ( porsches are MS_DOS formatted out the box ), if it does not mount or does not appear in DISK UTILTY, then it is a high probability that the enclosure/bridge board has failed and the drive ( if not making grinding, buzzing, clicking or beeping sounds) will have to be extracted and placed into a more stable enclosure. If the drive is grinding like you say, most likely the disk is physically damaged. If this is something you experience often, maybe you should consider power conditioners. if the drive is being moved around alot, you should be gentle with it in transit. Drive enclosures, look rugged and have flashy lights and metal enclosures, but should be treated like babies. Drives are feircely sensitive. They should be padded, kept away from magnets, and treated like laptops. Hope this helps.
  • 556 Answers
SOURCE: Don't get it
I notice that you had issues initially installing the drive. Is it possible hat your actions as noted in the link corrupted the HFS+ formatting that was shipped on the drive?
Review this link
If as you noted THIS WAS THE FIRST TIME YOU USED THE DRIVE, you have no data on the drive to loose or recover.
Especially if you believe your actions may have corrupted the formatting of the drive, reformatting may be the appropriate response and could yield a working drive eliminating many return headaches. However if this does not seam reasonable contact with LaCie as to why the drive did not work directly out of the box may be appropriate. (I did confirm in the drive specs that the drive should have been formatted correctly for an apple computer -- windows users need to reformat the drive before they can use it )
I hope this helps
Posted on Dec 14, 2007
  • 242 Answers
SOURCE: How to format the LaCie 500GB d2 Quadra for Windows XP??
This way it should work...
Connect your drive to the computer...
Go to: Start > Control Panel > Administrative Tools > Computer management.
A new window will appear...
Select Storage > Disk management on the left of the window.
Now you will see the different drives that are connected or part of your system.
One of the drives listed there is your LaCie, i think you'll recognize it by name...
Right-click on it, and select 'format'
In the new window, select the new volume label (as you like it), the file system (use NTFS), and set allocation unit size to default.
Make sure 'Perform a quick format' is not checked...
Then click OK. Your drive will be formatted now... Don't interrupt the process
Posted on Mar 31, 2008
SOURCE: la cie hard drive mount issues
I had the same problem and surprisingly, after many attempts to get the drive to mount with different connections, etc., the problem turned out to be the power adapter. If you've got the same kind of adapter on another drive, switch it out and see if your drive shows up. Good luck.
Posted on Jan 22, 2009
Will not mount on a Mac Book Pro 17"
try to connect lacie to windows base computer if it work, there a problem, with your mac book check if device manager recognize lacie drive if not check for the fire wire port.
Apr 10, 2010 | LaCie 1TB D2 HD Quadra FireWire 400 Hard...
Lacie 300790 that my Mac won't recognize
the Mac may not recognize it if it is formatted with NTFS. I believ most Macs can read FAT32 and other formats but not NTFS. You could hook the drive up to a modern PC, transfer the files there for a while, format the external drive to FAT32 and copy the files back to the drive. The Mac shold read them now,
Sep 21, 2009 | LaCie d2 Extreme (300790U) 250 GB Hard...
Deference Lacie d2 Quadra1TB/Lacie big disk ?
It's all about the interfaces.
The Quadra has four interfaces: • eSATA • FW 400 • FW 800 • USB 2.0
The triple has all but the eSATA interface listed above.
For doing video work you want a big drive with a fast interface. If you have eSATA available then that's the fastest. If you don't then you're just as well off to go with the triple interface. The FW 800 would be the next fastest, then the USB 2.0, then the FW 400.
Because of the way that data is transferred I believe that when doing video work you would be best served by the FW 400 instead of the USB 2.0 even though the USB is faster I don't believe it is a full duplex communication so the FW 400 is actually better for video.
Apr 03, 2009 | LaCie Big Disk Extreme with Triple...
Cannot find the lacie driver on my mac
Chances are the drive is bad. Try taking it to another computer- if it doesn't work there, then the prognosis is poor. Data recovery services are available, but pricey.
Feb 05, 2009 | LaCie d2 Extreme (301033) (301033A) 160 GB...
Vista (32) will not recognize my lacie d2 external harddisk
solved: after referring to the userguide, I found that I formated my drive with a OS format, which can not be recognized by VISTA >> formated to FAT32 and now it works...
Jan 03, 2009 | LaCie d2 Extreme 250GB External with...
Just bought a lacie d2 dvd +/- rw, store bought dvd movies don't mount and therefore don't play
Disconnect the Lacie dvd drive, then reconnect it and open "system profiler" to see if the drive is now recognized under "firewire" or USB depending on your connection. If that doesn't work disconnect all peripherals and turn off your mac for 5 minutes. Start reconnecting your devices one by one.
Dec 16, 2008 | LaCie 16x LightScribe DL DVDRW (LAC300786)...
Lacie 1tb hd
You can try to boot up with Linux LIVE cd and plug on the external HDD.
Apr 24, 2008 | LaCie d2 Extreme 250GB External with...
Computers & Internet Logo
141 people viewed this question
Top LaCie Computers & Internet Experts
Raj Patel
Tony
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
