Question about AudioBahn A8000T Car Audio Amplifier
Audiobahn a8000t problem
I need help hooking up a audiobahn a8000t amp';when i hooked it up the blue light on comes on and the fan as well but no power light is and the protection is on please tell me what i am doing wrong;and how do i hook up two audiobahn 10' to this amp and where do i run ground wire.
  • mikewelborn Feb 15, 2009
    power protect wont go off??
  • 631 Answers
If the protect LED is lit, the amp probably has shortedoutput transistors. To eliminate other possible causes, read throughthe following page:
Amp in Protect Mode - Troubleshooting
Let me know if you have any other questions.
Posted on Nov 25, 2008
Redlight keeps coming on
well you could be having several issues but it will most likely be one of two of these issues. there could be a cross or a loop in your setup, or you could have and over heating problem. do you have a capacitor hooked in to your system?
Nov 21, 2010 | AudioBahn A8000T Car Audio Amplifier
My A8000t amps red protection light is on checked
When ever the amp stays in RED protection mode with out any speakers hooked up to it, YOUR amp has internal damage some where. Can't tell you how much to fix, Could be cheap or not worth it. Talk to your local electronic repair, would be a good start.
May 14, 2010 | AudioBahn A8000T Car Audio Amplifier
AMP.... question
CFM is negotiable - as the higher RPMs the more air it moves. (also louder).
Audiobahn is out of business - and unless someone is willing to tear theirs apart for your info - get whatever they have in stock :)
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Dec 29, 2009 | AudioBahn A8000T Car Audio Amplifier
Where can I find a cooling fan for a Audiobahn a8000t amp?
Hello fornda,
The fan looks very similar to a 3" muffin fan. The fans from most computer cases would probably fit. You may have to modify how it mounts, and perhaps the connector, but the voltage is the same.
Here's an online retailer. I'd look for the highest CFM at the lowest fan speed to keep the noise down.
Hope this helps.
Aug 07, 2009 | AudioBahn A8000T Car Audio Amplifier
Amp keeps cutting off
Do you have heavy enough gauge wire supplying B+ to amp.Big amps draw a lot of current and require very heavy gauge wire. The longer the run the heavier the gauge needed.
Apr 20, 2009 | AudioBahn A8000T Car Audio Amplifier
I need a installation manual for audiobahn a8002t amp.
very simple run a ground from gnd on amp to a good ground spot on car run 12 volt power cable from back of fuse relay by battery to 12v+ on amp then splice blue wire on back of stereo splice in another wire about seven feet run that to remote on amp then hook up speakers its pretty simple to hook up an amp hope this helps
Apr 18, 2009 | AudioBahn A8002T Car Audio Amplifier
Amp has power, but nothing going to subs
did you check on the 'remote' terminal? It should have a +12 vdc to let the amp work. You can check this with a voltmeter. Or might be in 'protection mode' (speaker cut-off relay).
hope this helps
Oct 16, 2008 | AudioBahn A8000T Car Audio Amplifier
Audiobahn A2502DP amp is alive but wont talk to me
Your "bumpin" may have killed the amps "bumpin" Was the amp secure when you were sliding? So wires are ok, and lights and finas running. You have power but no output..Check the settings on the amp, also the fuse. Something might be earthing itself to the amp as well.
Feb 14, 2008 | AudioBahn A2502DP Car Audio Amplifier
AudioBahn A8000T Car Audio Amplifier Logo
303 people viewed this question
Top AudioBahn Car Audio & Video Experts
Tygh Duval
Tygh Duval
Nicholas Csorba Jr.
Colin Stickland
Colin Stickland
Are you an AudioBahn Car Audio and Video Expert? Answer questions, earn points and help others
