Question about Danby PHD DHCC6020 3-in-1 Home Comfort Unit Humidifier
Changed filter and need to know how to reset icon
The change filter icon came on and i changed the hepa filter and cleaned the other filter. how do I reset the icon to off?
Press the 'Timer' and 'increase button' simultaneously (3 seconds) to resume normal operation.
Posted on May 05, 2009
Replace filters light stays on even after changing wicks. How do I turn it off?
You didn't specify what brand/model of humidifier your using, but you can still try a couple of things. (Try the most logical first).
Try turning the control knob to the "test/reset" position & wait until the humidifier "on" light blinks; indicating it is resetting the timer & the change filter lamp will turn off.
I believe that you will need to do this while the furnace is calling for heat, if it isn't, turn up the thermostat and try it.
Jan 05, 2016 | Humidifiers
How do you reset the cf on essick humidifier
I just changed the filter and it started flashing CF. How do you reset this other than changing the filter?
Feb 04, 2013 | Essick Air Humidifiers
I have the MA0800 and I have a CF flashing on the display. How do I get rid of this code? If it requires a clean filter, then how do I reset this code once I have a clean filter?
Change the filter then unplug the unit from the electrical outlet and the code will be cleared. Just shutting the humidifier off won't clear the code, it has to be unplugged from the power to clear the flashing CF.
Jan 21, 2011 | Essick Air MA0800 Humidifier
What does the cf stand for
Found the answer in the original manual. CF means check filter, this displays every 7200 hours of operation. If the filter is OK just unplug the unit for 2 minutes and the display will reset.
Dec 26, 2010 | Essick Air Humidifiers
How do you set and or reset the "filter replacement"schedule on the April air #700 model?
The owner's manual reads "After the Water Panel is replaced, turn the Control knob to the “Test/Reset” position until the green “Humidifier ON” light flashes, to reset the Water Panel change timer."
Hope you find this to be very helpful.
Let me know if you have any questions. :-)
Mar 20, 2010 | Aprilaire 700 Humidifier
Changed filter and it still says "clean filter" on the gauge-?reset button
not sure if there is a reset button if not
I would say if the filter was bad enough some of the foreign materials (particles the filter should capture) may have went on down the line.
the "clean filter" indicator is most likely activated by the volume of flow. So when the filter is full the flow is reduced in turn the "clean filter" comes on.
so if filter has been replaced and there is no reset button try backflushing the lines. If the lines have built up blockage your flow will stay low and the "clean filter" will stay on.
on these lines there may be bends and turns most likely to have build up in these areas restricting your flow
clean lines (low air pressure may work easiest)
Mar 03, 2010 | Sunbeam 1117 Humidifier
How do I change the filter, (Holmes hm7204 Humidifier) Where does it go?
REPLACING THE FILTERS
Through normal use, waterborne minerals and sediment
become trapped in the wick filters. The harder your
water, the greater the amount of minerals in the water,
and the more often you will be able to monitor the life of
your filters in your humidifier.
You will be able to monitor the life of the filters in your
humidifier by checking the FilterCheck® Indicator. After
60 minutes of use, FilterCheck® Indicator will move and
indicate your filters condition. New filters will register in
the section reading Good filter. After frequent use of your
humidifier, the FilterCheck® Indicator will let you know
when the filters need to be changed, see Figure 2.
When the needle is in the CHANGE section, this means the
proper amount of moisture is not getting into your air due
to the excessive minerals and sediment that have become
trapped on your filters. At this point, you should replace your
filters. It is important to change your filters as
indicated to obtain stated performance level.
To replace the filter, follow the steps below:
1. Turn the unit off and disconnect from the electrical
outlet.
2. Remove the tank and main housing to access the base.
3. Remove the wick holder from the base of the humidifier.
4. Remove each individual wick and discard. Do not
remove rivet, replacement wicks come equipped with
rivets for easy replacement.
5. Follow the weekly cleaning instructions.
6. Insert new filters into each section of the wick holder
making sure the rivet attaches to the wick holder
securely.
7. Do not use wicks without rivets as this will not
produce the units intended output.
8. Replace the wick holder into the base and replace
main housing and then tank.
9. Repeat Operating Instructions.
It will take about 30 minutes for the humidifier to reach
maximum output.
Cheers!
Feb 14, 2010 | Holmes Products Cool Mist HM7204-U...
I have cleaned by humidifier and changes the filter. The red cleaning light comes on and i hold it down to indicate i have cleaned it and it shuts off and will not restart. It have never done this before...
First make sure the tank is properly installed rock it a bit toi see if it is secully placed.
Then Unplug it for a gfew minutes. ther replug and reset it before you start it.
Feb 05, 2010 | Air-O-Swiss 7133 Humidifier
I have a Venta VS370 humidifier which works fine immediately after I change the filter but after a few days the vapour stream diminishes significantly and it ceases to be effective: is this a malfunction?
Filters need to be changed regularly depending on environment may have to change more often.
These systems can be very troublesome. It is possible that you are having mineral buildup in your system from the water supply. You can try adding 1/4 cup vinegar to your water to help clean away deposits. See if that helps .
Mar 08, 2009 | Venta Airwasher VS370 2 Gallon Humidifier
Replacement HEPA filter for Danby DHCC6020?
We just ordered from Danby... call 1-800-26-danby... it's part number 6020.02
Nov 23, 2008 | Danby PHD DHCC6020 3-in-1 Home Comfort...
Danby PHD DHCC6020 3-in-1 Home Comfort Unit Humidifier Logo
222 people viewed this question
Top Danby Humidifiers Experts
Paul Carew
Dennis
Marvin
Marvin
Are you a Danby Humidifier Expert? Answer questions, earn points and help others
