Question about Dell XPS One All-in-One TV Desktop with Intel Core 2 Duo Processor E4500 - (PRODUCT) RED
Thin vertical lines on screen
I have a dell xps one and my screen has thin vertical lines going all through it. I contacted dell and they sent a service tech to replace the motherboard and video card. The problem still persists. The dell tech said it's likely a software problem so I contacted dell support and they told me it was probably not a software problem but rather a hardware problem.
When the computer starts up, the lines do not appear in bios screen. I've already done a video monitor test in bios and everything came out fine. The lines only appear in windows. It even appears when the computer is running in safe mode. Dell is planning to send out another tech for the third time to solve the problem, but they haven't been able to find a solution yet. I thought I would check online to see if anyone had any suggestions.
Thanks in advance!
    Novelist:
    Scholar:
  • 85 Answers
You need a new LCD screen.
Thats a common problem with those panels
Or can be a hardware defect that occurs when the screen wasn't properly tested at the factroy
Posted on Dec 02, 2008
Thin red line running from top to bottom of screen
What is this thin red line that is on my screen whenever my ...
https://answers.yahoo.com/question/index?qid...
Sep 23, 2010 - There is a very thin red line going from the top of my computer screento the bottom, ... If it's a single-pixel-wide red line from top to bottom it's a failure in ....have thin red lines running down the screen??some are thicker than ...
Thin Vertical Red Line [Solved] - Acer - Displays - Tom's Hardware
www.tomshardware.com > Forum > Displays
Tom's Hardware Guide
Jul 12, 2013 - 5 posts - ‎2 authors
hi all i am having a Thin Vertical Red Line on my Acer LED moniter ... the screen is having a part fail(cable or the screen/control board it self.).
Why is there a straight vertical line going from top to bottom on ...
forums.androidcentral.com > ... > Samsung Galaxy S6 edge
Apr 15, 2015 - 7 posts - ‎4 authors
Just bought the Samsung Galaxy s6 edge yesterday. After I charged the cellphone for the first time and turned it back on there was this straight.
Jan 26, 2016 | Samsung UN60ES6100 60-inch LED TV
Why are there vertical colored lines all over screen?
Thin vertical lines cover screen on Samsung LCD - AVS Forum ' Home ...
www.avsforum.com/...lcd-flat-panel.../1127410-thin-vertical-lines-cover...
Mar 7, 2009 - 30 posts - ‎25 authors
I have read there could be ribbon cable connection issues so I plan to .... I have a VizioVW22LHD TV,I hooked it up using a HDMI cable to my Toshiba satellite laptop. ... If you have thin multi-colored vertical lines on your tv panel, that do ... my TV on the thin vertical lines come all over the screen and the TV ... my VIZIO E470i-A0 LED has vertical colored lines on ...
Nov 18, 2013
Vizio SV370XVT lines throughout entire display. Not ...
Aug 3, 2012
Thin vertical line on LCD tv
Dec 29, 2007
More results from www.avsforum.com
Vizio P50HDTV Display Problems - Colored Vertical Lines .
Dec 30, 2015 | Vizio Televison & Video
Horizontal Band of Thin Red and Blue Lines on Screen
Sound like your Y-Sustain board has one foot in the grave. The Y upper buffer and Y lower buffer boards go when the Y Sus Goes too...
Mar 22, 2014 | Panasonic TCP46C2 46 in Plasma TV
I have a dell monitor. Suddenly a thin vertical green line has appeared on my screen and its there permanently. kindly help in resolving it.
The fault is something related with its interface board between panel and its drive. In most cases, it will be irrepairable. Anyway, contact the authorized service center for Dell.
Aug 27, 2013 | Dell Computers & Internet
Thin vertical green line
Could you please specify what type of screen this is? Or any other information that could help identify what type of screen it is?
A thin vertical line in a screen could be a faulty cable, faulty graphics card or even that the screen is faulty itself. But with more information on the screen the problem would become clearer.
I have a thin horizontal line across my dell latitude laptop screen
If the thin line is always there, you have a set of pixels burned out. This usually occures vertically. There is easy fix, except to replace the screen. If the laptop is under warrenty, contact the manufacture for repair options.
Sorry could not be something easier for you.
Mar 19, 2012 | Dell Latitude D630 Notebook
Vertical lines appear permanently on the screen
your display is going out you can contact Dell for a replacement.
Nov 01, 2009 | Dell Inspiron 2200 Notebook
Vertical lines in my laptop screen
Try connecting an external monitor to the Dell Inspiron 9300 and see if the vertical line is also present on the monitor. If the monitor display is fine, then your laptop’s LCD display panel is defective. If the monitor also displays the vertical line, then your problem is with either the video card or motherboard located inside your laptop.
Not sure if the Compaq Presario has an external monitor plug, but if it does the above procedure can be applied to that one as well.
Your responses are intended to improve the level of service provided. Please rate your experience.
Thank You.
Oct 19, 2008 | Dell Inspiron 9300 Notebook
the lcd (liquid crystal display) is damaged at this time, nor the inverter, that is of course inside of your pc, im afraid you need to send this to a repair shop
cheers
Aug 12, 2008 | Dell Inspiron XPS M140 Notebook
No picture
a bright thin line in centre is called horizontal line. first of all do not keep tv on unless it is rectified. BUT If you want to put on tv keep brightness minimum to protect your screen for any demage. now solution your problem is in vertical section. 1 check vertical supply. 2 check parts in vertical section or loose contact. 3 yoke connrctor loose 4 ic defective It is not serious problem can be rectified easily
Sep 19, 2007 | Toshiba 32DF46 32" TV
Dell XPS One All-in-One TV Desktop with Intel Core 2 Duo Processor E4500 - (PRODUCT) RED Logo
461 people viewed this question
Alun Cox
