Question about Frigidaire Refrigerators
How to install a frigidaire relay overload combination
2 Suggested Answers
aasc
  • 1606 Answers
SOURCE: bad overload relay
Do not go with the 3 in 1 start kit ! This is only a temporary " fix " . The part number you need , is 61006186 . This is the direct replacement , for the overload / relay , on your refrig .
Posted on Dec 17, 2009
Supco PRO 41 relay/overload combination. Where do blue wire and black wire connect?
before you suffer electrocution and toasted relay / overload accessory , better consult someone familiar with such intricate connections. there ' s supposed an accompanying diagram for the connection. thanks .
Oct 11, 2015 | LG LSC27921SB Side by Side Refrigerator
What rewiring is needed to replace the overload relay with a universal kit, on an upright freezer? Kelvinator model VA16 W. There are two relays that connect to the compressor that need to be replaced....
The two pieces are Relay and Overload.
If you are using a supco relay/overload combination that has three wires with terminals and two wires with stripped ends the wiring is as such.
Red-Run Terminal, White-Start Terminal, Black-Common Terminal (Overload was wired to this)
Stripped wires are connected to line cord along with condenser fan wires.
Nov 19, 2010 | Frigidaire Freezers
HOW DO YOU REPLACE A START RELAY SWITCH ON A FRIGIDAIRE SIDE BY SIDE MODLE FRU26SA
Power off i.e unplugged
Open the back
Remove retaining clip on wiring side of compressor plastic cover.
NOTE wiring connections to terminals on the OLD relay. 1, 2 4 4 ect... make a simple wite color to terminal number sketch.
PULL off PTC relay WITH terminals by pulling HORIZONTALLY (Usually to the left / 9 O'clock position)
NOTE the thermal overload comes off WITH the PTC relay.
Remove wire from Thermal overload terminal and transfer the thermal overload to the new PTC relay.
Slide NEW PTC relay onto compressor terminals
Transfer remaining wires from OLD PTC to the correct terminal on the new PTC relay.
TEST compressor start before installing cover... PLUG in unit
After the test unplug the unit... reinstall the plastic cover and wire clip.
Reinstall back panel
Return unit to service.
Thanks for choosing FixYa
Kelly
NOTE the thermal overload will s akl
Sep 19, 2010 | Frigidaire Side by Side 26.0 Cubic Foot...
Have upright Frigidaire freezer, about 2 yrs old, that quit running. Local repair guy replaced part with "3 n/1 Start" solid state relay overload capacitor combination. Worked great for 2 weeks then...
Good day,
That's a no-no. Your compressor carries a 5 year warranty from the factory. However, if anything is altered on it the warranty is voided. You've got an issue with this guy.
Jun 04, 2010 | Frigidaire 20.6 cu. ft. / 583 liter...
My refridgerater went out Saturday and now my freezer went out last night. what do you think it would be?
The overload relays at the side of the compressor have gone bad. Not an expensive repair and not hard to do. Replace the overloads and you're back in business.
Feb 01, 2010 | Frigidaire 20.6 cu. ft. Top Freezer...
Refrigerator and freezer will not cool
Compressor is cutting on/off on overload,some are located on the side of the compressor,some inside the compressor.My advice is to install a start kit on the compressor.It is a combination overload/start relay/capacitor.You can get these at an appliance repair shop,just follow the instructions.Hope this helps.If I can be more help,write. Gregg
May 28, 2009 | Frigidaire FRS3R4EQ 33" 22.6 Cu. Ft....
No cooling,compressor comes on and shuts off quickly
All refrigerators compresors have a relay and a overload thermal protector ,both are located on the side of the compresor behind a black plastic cover atached to the compresor with a metal clip(or just the cover snaps in on the compresor).Unplugged the fridge ,pullout the cover and you'll see the relay and the overload replaced them (no more than $30).If this doesn't solve the problem you have a bad compresor, wich is a much more expensive job.
Apr 19, 2009 | Frigidaire FRS-26DR7D Side by Side...
Buzzing compressor
heres a part number for the overload relay assy 5304468029.. its mounted on the side of compressor. its a tricky one, usually my experience has been the noise comes from a bad compressor( which you should have 5 year full warr from manufacture). sometimes the overload relay does go bad preventing compressor from starting,the n ew compressor will come with a new overload relay
Nov 19, 2008 | Frigidaire 20.6 cu. ft. / 583 liter...
Unit isn't cooling
check the relay/overload that "gurgling" could be a compressor trying to start.
you can replace the old relay/overload with a supco combination relay/overload
Apr 25, 2008 | Refrigerators
NOT cooling and NOT freezing
ok check if fans go on
you probably have an defective compressor relay/overload
you can buy an replacement at an appliance store.
supco make them just ask for an relay overload combination for 1/4 1/3 hp anyone with some electric knowledge can help install it if it dosent start up, well bad compressor hope that this helps
Apr 19, 2008 | Kenmore 44103 Side by Side Refrigerator
Refrigerators Logo
172 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
