Question about JVC AV-27D303 27" TV
TV/Cable will only play after inserting DVD
My picture tube is fine, cable signal was tested by tech. The TV mode is sometimes fuzzy and sometimes just blue. I can play DVD's just fine. Sometimes I'll play a DVD and switch back to TV/Cable mode and I'll have a clear picture. I can then watch TV until I have turn it off. When I turn it back on, same problem. Has anyone ever seen this problem? Do I need service to fix it? I appreciate any assistance anyone can give. Thank you
    President:
  • 1,952 Answers
Ya service is better its lose connect the tv controlpower
Posted on Aug 24, 2008
SOURCE:
My tv sound is schreeching
OK sounds like you have problem on your cable box connection or signal..Try to play a dvd to test. If the sounds fine on DVD you definitely have cable box prob.
Dec 10, 2012 | Dell U2711 27 in LCD TV
We have a LG42lx6500. when you turn it on after being off for a few hours the picture colour is distorted for a couple of minutes before correcting. At times you can see the individual pixels. Sometimes...
Hello
Make sure TV is on the correct channel or input. Check the cables for correct routing from TV to any other devices. Check cables to ensure they are tight and secure.
An analog signal converted to high defintion resolution will cause lines, blurriness or fuzziness in the picture. Change the resolution to a lower or native setting using the media device (cable box, DVD,). This may be an issue that requires a service call to cable provider.
A problem on one channel may just be a error on that channel. If using an antenna, it might need to be adjusted in order to ensure good signal strength. For digtal channels, go into TV Menu. Check the DTV signal. Weak signal can cause picture distortion.
If another device is being used such as a cable box, DVD player or VCR switch between devices and test picture. Check routing of cables that are used to control the image. This should be a series of red, white and yellow cables.
If a VCR with a cable box, make sure the VCR and TV are set to the correct channels for video signal to pass through. If problem is still occuring, try another set of cables. bad cables can cause picture distortion.
Bad cables can cause picture distortion as well. Try another set of cables. If picture is better than when using the cables replaced, this was the issue. If cables are not an issue TV may require service.
Apr 26, 2011 | LG Televison & Video
Intermittant sound but the screen is fuzzy with a thick line running down the center of the screen. When playing dvd player picture is fine
this is a problem with the incoming signal of the TV. Check your antenna, set top box or the cable tv input. If the signal is OK then the tuner of the TV is spoilt
Jan 24, 2011 | Mitsubishi Televison & Video
Picture went completely fuzzy. What could the problem be?
The tv CRT( picture tube) have a radiaton posion infected in ur tv picture tube.This is how u discharge the CRT(picture tube) get the posion out.Take the tv back cover off.Take video board that connected to the CRT(picture tube) out.Plug it in,so u have a live current to the CRT(picture tube).Find a wire like an AV cable,should be find.One side of the metal,grounded to the metal frame somewhere.Take a long needle plier grab the other side of the AV cable wire,not the metal,(Caution high voltage live current).Come very close to the open CRT(picture tube).U will have a live current arc,than u,will hear a big "POP".U,just discharge the CRT(picture tube).The tv now the CRT(picture tube),now it good,it clear of posion infected in ur tv picture tube.Now,unplug ur tv.Put ur tv,back together.Hook up ur tv signal cable and plug in ur tv,now ur tv picture,will be clear,completely.I do this many times to dicharge fuzzy CRT(picture tube).When i was a tv Tech.for the SONY TV Corporation.
Oct 12, 2010 | Sanyo HT32546 TV
Cable picture is fuzzy
Call your cable company as there might be a problem with the drop line or aerial coming into your house. now another thing is if you have a signal splitter( ex: 2-way, 3-way, 4-way) before the cable box, that could be degrading the signal as each input may drop the signal significantly. remeber, don't use too many splitters as they will make the signal faded/fuzzy. also, make sure all the connectors are clean and are not badly bent or the ends frayed. If you can see wire insulation from the cable line then it's no good.
Apr 05, 2010 | Insignia 42" LCD Flat-Panel HDTV
My vizio tv works fine with the dvd and the wii, but when hooked up to the cable it is fuzzy and picture flashes. I unhooked cables and replaced all of them as well as replaced hdmi cable. The picture...
Ur Main Tuner signal board have problems,that cause of this.Tries Websites Shopjimmy.com,Ebay.com to buy a refurbish Main Tuner signal board for the replacement.
Mar 20, 2010 | Vizio VW42LF 42 in. LCD HDTV
Blue screen
bad connection but where need tech.
Nov 27, 2008 | JVC AV-27D302 27" TV
Mitsubishi 52 lcd 120 hz receiveing time warner digital cable via hdmi cable has fuzzy and pixelated picture even on digital and hd channels. Time warner techs are comming out this week to check it out,...
The tv is fine.We see so many problems with cable provided signal that it isn't funny.It usually stems from bad cable boxes and low signal coming into the house.
Mar 03, 2008 | Televison & Video
Fuzzy picture
does it look like this set?
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
Dec 11, 2007 | Toshiba 51H84 51" Rear Projection...
Dvd plays fine sound/picture...No sound or picture with cable input
John,
To answer your question no, there are no fuses associated with the tuner input - through the "F" connector jack.
You have there a V26 chassis which has, among other things, standard digital and analog signal inputs. If one works but not the other - and you've verified it's not the cable then the only alternative is the signal board, Mitsubishi p/n# 930b923002...
But don't rush out and buy this puppy, it's a fairly expensive board and there are alternatives to replacing it new or used - PTS Electronics can rebuild this board for half the cost of a new one and most techs use PTS for that reason.
My best advice is to have a qualified shop estimate the repair and if they decide that the signal board needs to be replaced and quotes you a price ask them then about having it rebuilt.
Also take the unit to them to save the pickup/delivery charges and ask for your estimate in writing...
Hope this helps!
Bill
Dec 06, 2007 | Mitsubishi WD-52525 52" Rear Projection...
JVC AV-27D303 27" TV Logo
93 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
