Question about Pentax ME Super 35mm SLR Camera
Pentax ME Super Shutter and Rapid Wind Button won't release
Found my Dad's old Pentax ME Super camera in great shape, but the shutter and the rapid wind button seem to be stuck. Inside the camera, the inside mirror stays up and makes things dark looking through the viewfinder. Are these potential deadly problems?? Don't remember him having any problems with it. Help. Scratching my head!
  • Anonymous Jan 10, 2009
    I have the Pentax ME and the mirror is stuck up, pressing the trigger does nothing. The canera has batteries in it and they are working as I can see the lights in the viewfinder. Still stuck on this one.
  • Pentax fan Jan 19, 2009
    Same problem, tried as per your instructions, still no good.
    Scholar:
  • 58 Answers
Common fault due to perished rubber parts. Can be usually be repaired, but do not try to force the camera, that may cause damage which can not.
Go to http:/www.mypentax.com for information on how to service this yourself. The author can also advise by mail, and can service these cameras too.
Posted on Jan 21, 2009
  • Gordon Stalker
    Gordon Stalker Jan 23, 2009
    This cammera does not require batteries for the shutter to fire. It can be operated at three speeds with no battery.
    These are 'B', 'X' (=1/125) and in auto mode it runs at 1/2000 with no battery fitted.
    Scholar:
  • 185 Answers
Must have batterys to work shutter. Put select off auto and the shutter will work equal to 1/60th sec. for flash setting. This is a very rugged fine camera,should last for many years if taken car of.
Posted on Dec 07, 2008
Pentax me super shutter won't open. won't wind, wont take a picture :(
Have you not used it in a while?
This could be one of two issues:
One, it could be the battteries. The ME super is not a fully mechanical camera like the mx, if the batteries are depleted then the shutter sticks open as it does not know how long to stay open. Turning the selection wheel to 125X usually unsticks it.
Two, the lubricant that pentax used in the 70's and 80's has a very bad tendecy to polymerise and turn sticky and solid. This turns the camera inoperable. Pentax repair service routinely provide cleaning for affected cameras.
Hope this helps, its a great camera
Jan 12, 2011 | Pentax ME Super 35mm SLR Camera
I have an old Asahi Pentax, release lever and shutter are stuck.
The Pentax is a easy fix, maybe.. If you feel comfortable removing the bottom cover, then remove the 3 cross point screws. The battery, if installed will be loose. Looking at the bottom section of the camera, locate the tripod socket. On on side is the battery compartment, the other an L shaped lever. Under the L shaped lever is a brass plate with a slot in it. In that slot is another lever that has a spring going through the end eyelet. Move that lever toward the front of the camera until it latches on the L shaped lever above. Then try the release.
The first thing to try on the X700 is fresh batteries. Clean the battery cap and contacts with a pencil eraser.
Jan 04, 2010 | Pentax K1000 35mm SLR Camera
The shutter continues to click in rapid concession Canon 20d
Check to make sure that you don't have it set on continuous. Check the lcd display and see if the shutter icon showing a mulitple as opposed to single frame image.
You should be able to choose between single, mulitiple and timed shutter releases...
Sep 08, 2009 | Canon EOS-20D Body only Digital Camera
Film won't advance
Pentax ME Super was one of my favorite camera, small and clean shutter release. But it has been about 25 years since it was manufactured. They happen to use rubber break within shutter unit and as any rubbers, it started to deteriorate and melt between the shutter-blades. This prevents the complete cycle of the shutter and jams the winding. You may be able to unjam the winding but eventually you have to overhaul the shutter unit. Overhaul charge is around $100 in US repair market. -James
Mar 31, 2009 | Pentax ME Super 35mm SLR Camera
Pentax ME Super Shutter and Rapid Wind Button...
anmolag,
it could be the rubber bumper next to the fresnel lens has become sticky. very gently ( after removing lens ) try to bring mirror down without forcing it. it should release easily.
if not, rotate the select knob off auto. open film door and check that the shutter is fully deployed, shutters should not be overlapping.
remove screws from bottom cover and remove cover, keep camera up side down so that re-wind button stays put. there is a locking lever under the take up spool ( gray ) . with a pin move lever toward film door and bring advance lever fully to the right , then let it go so it returns quickly.
the shutter should have fired. if not the camera will need to be repaired. get an estimate first as there are no new parts available.
Dec 24, 2008 | Pentax ME Super 35mm SLR Camera
Film advance broken.
Press the rewind button and wind the film advance lever, It will set to its place. Release the rewind button, press the shutter release button.Once again try wind the film.( provided your camera is not fitted with motor wind )
Mar 27, 2008 | Pentax ME Super 35mm SLR Camera
Film will not advance
Pressing the rewind button wind the film advance lever,if it is free It will set to its place. Release the rewind button, press the shutter release button.Once again try wind the film.( provided your camera is not fitted with motor wind )
Then your winding gears need cleaning
Jan 18, 2008 | Pentax ME Super 35mm SLR Camera
Wind up film button
This is a common problem with the older Pentax SLRs : shutter / mirror box needs servicing . The problem is caused by perished rubber parts. Although the problem is easy to fix, it has to be carried out by a pro because the mirror box has to be removed from the camera so that one can have access to the shutter and the side of the m-box where the problem is. Costs ? +- $150.
Nov 04, 2007 | Pentax ME Super 35mm SLR Camera
Light meter failure and shutter button sticking
Set your camera to B and release the shutter ( camera will work in this mode without batteries ) if you can wind ok and release shutter fine then all you need is new batteries. If however your camera is not working when set to B then it is either the shutter or the transport mechanism that need looking at. From experience ( have repaired 100s of Me-supers ) it is likely that your shutter needs attention : rubber components ( and foam rubber ) inside the shutter ( and the mirror box locking mechanism especially ) have perished and need replacing.
Sep 21, 2007 | Pentax ME Super 35mm SLR Camera
Film advance lever
Your camera is cocked but since the shutter is not working you cannot release it and hence your film advance mechanism does not work. ME-super will work without batteries in full manual mode so set your shutter to B and try to release it. If the shutter will not release in B mode then the shutter/mirror box will need servicing : rubber components in the mirror box mechanism have perished and need replacing. After that your camera will be fine for another couple of years.
Sep 18, 2007 | Pentax ME Super 35mm SLR Camera
Pentax ME Super 35mm SLR Camera Logo
759 people viewed this question
Top Pentax Photography Experts
pontelemon
pontelemon
Bill Eager
Greg Cann
Greg Cann
Are you a Pentax Photography Expert? Answer questions, earn points and help others
