Question about BenQ FP71E 17" LCD Monitor
I turn my monitor on and it displays BENQ and then goes to -No Signal Detected- Power light changes to orange..help?
When I tun my computer on the monitor displays BENQ and then goes black, saying Signal not detected....help?
  • 4 more comments
  • Steve P
    Steve P Jan 19, 2008
    Same as my FP71E 2+ years old work great up till Nov 2007 on Powerup BENQ splash screen then black and power swich indicates no signal.
  • Anonymous Jun 08, 2008
    new computer when turned on it displays no signal detected as above
  • Suzoo Dec 12, 2008
    I have
  • azacel Dec 25, 2008
    When i turn on it display BENQ splash and them turn black, i have 2 monitors conected, and the nvidia panel detects both, my dell 2405and my benq fp71e, but the benq still black...
  • Anonymous Jan 24, 2009
    when i turn de computer it showz de logo and again de lcd goes black
  • Anonymous Mar 25, 2014
    toshiba satellite p745 trying to connect to a vizio m220va using an hdmi cable but when i go to display settings it wont detect any other external displays is this a driver issue?? i need help finding a solution
IT MUST BE A DPI.IF UPPER THAN 60Hz THE PROBLEM WILL BE OCCUR AGAIN.I THINK
Posted on Oct 04, 2007
SOURCE:
I just replaced the ram on my pc but when I went to turn it back on it says no signal detected and goes. Black while the power light goes orange. I have checked and rechecked the physical connection over...
Your computer isn't starting up, no video is getting to the monitor, and that's why you see the "no signal" message and the power light goes orange. Make sure you've reconnected any internal cables you might have removed when you replaced the RAM. Also be sure you've seated the RAM properly into its socket. I've seen modules seated crooked so that contacts are shorted. The modules should fit properly into the sockets so the latches click into place.
Try reinstalling the original RAM and see if the computer starts properly. You might have a defective part which is keeping the board from starting up.
Since the trouble began after you replaced the RAM, that's where to start looking for the cause. Good luck, and thanks for using Fixya!
Oct 05, 2010 | BenQ T701 TFT 17" LCD Monitor
Power light on no screen shown
unplug from pc, turn on monitor. if there is a 'no signal' or any image displayed on the screen then the problem is not the monitor..
Nov 15, 2009 | BenQ FP737S-D 17" LCD Monitor
No signal detected
Check all of your cables - VGA / DVI mainly in the back of the monitor and the back of the PC.
Jun 09, 2009 | BenQ FP737S-D 17" LCD Monitor
BENQ FP737S Monitor shows "No Signal Detected" on startup
first problem could be the hdmi cable you are using is loose or broken.second, the display mode you selected was wrong, try to go to desktop and right click and choose nvdia control panel and choose the nview display mode to use,select the only use one display(single)and apply.
Jan 27, 2009 | BenQ FP71E 17" LCD Monitor
"No signal detected" when LCD connected with DVI-D Cable
Thank you for providing your configuration details.
You have failed to specify wheather or not your LCD Display is under Warrenty.
Perhaps these simple trouble shooting procedures will get the job done.
1. use the DVI to VGA adaptor that came with your card
Plug in a regular CRT monitor to the Primary Display Output Port using the DVI to VGA adaptor
( either port can be designated as the primary by you )
I like to use the Port nearest to the motherboard as the Primary
2. plug in the your LCD monitor on Secondary Display port using your DVI cable
At this point you should be able to see your desktop on the Primary CRT Display
3. Go to the display properties and use the Nvidia Dual Display Setup Wizard
set both desktops to CLONED at a resolution of 1024x768 and set the refresh to 60Hz
which is default for most LCD displays , some have higher refresh rates , consult your user manuel
If the display resolution and refresh are set incorrectly for your CRT or LCD you will see
Signal Out of Range ( if the display has the ability to display that error message )
At this stage both displays should be showing a Windows Desktop
If you now see your desktop on both displays , you can now put the LCD on the Primary Port
No Signal Detected ( this means the display device is not receiving a signal )
If your LCD display is still displaying the error message
"No Signal Detected" after performing the trouble shooting proceedures
You may need to read the user manuel about how to enable DVI signal input.
If you are certan you have done everything correctly but still see only "No Signal Detected"
Your LCD Display may need replacement
Loch Hime :-)
Sep 14, 2008 | BenQ FP71E 17" LCD Monitor
Can't find video signal
If screen says "Signal cable not connected " all the time till power led switches to Amber chances are monitor is ok and problem is with graphic card or cpu.Connect to Known working CPU and confirm that monitor is the problem.
If same problem persists on another working cpu after changing signal cable,the interface board in the monitor could be defective.
Samir
PLease rate solution and provide feedback.
Jun 09, 2008 | BenQ FP731 17" LCD Monitor
LCD monitor went blank
Which model is it?Does power led remain on?
Samir
Jan 22, 2008 | BenQ FP737S-D 17" LCD Monitor
Power ok but No Display
see this one
http://www.fixya.com/support/t155971-benq_t701_lcd_monitor
Sep 16, 2007 | BenQ T701 TFT 17" LCD Monitor
No display
if your monitor is not connected to a pc, then it cannot find a vga signal input and therefore go into power saving mode, which is indicated by the orange light, but as soon as you connect to the pc and power on the light will go green and the monitor will power up.
May 07, 2007 | BenQ T701 TFT 17" LCD Monitor
BenQ FP71E 17" LCD Monitor Logo
1,999 people viewed this question
Top BenQ Computers & Internet Experts
Steve Allison
Steve Allison
Tommmix
Level 1 Expert
Joaquim Martins
Are you a BenQ Computer and Internet Expert? Answer questions, earn points and help others
