Question about Maytag Neptune MDE5500AY Electric Dryer
Maytag ele dryer only gets warm
Ducts are clean, thermostat good, if fuse ther is blown will it even get warm? its getting warm, checked plug ,ok, all elements are not getting hot. Whats wrong? should i replace heating elements? I may have to call the maytag man. help me bro
  • Anonymous Mar 26, 2014
    Dryer gets warm but doesn't get hot thermostats are good
  • 833 Answers
You have two breakers that control the heating elements.  Check both by turning off then on.  If one is open, the motor will still turn.
Posted on Nov 23, 2008
Maytag dryer temperature fluctuates. replaced the thermal fuse 2 weeks ago. this fixed the problem but the dryer now gets a lot hotter and cooler than before. all the clothing is coming out wrinkled.
change the cycling thermostat and when was the last time you cleaned out the dryer and vent line?if it's gas it should be done at least once a year electric every 16 to 20 months because you don't have an open flame in there like a gas dryer but you either have bad air movement or the cycling t-stat is bad and if you had to change out the thermal fuse is a definite sign of this,if your clothes have been taking longer to dry you have a block somewhere,you can try removing the vent line from the back of dryer and run it to see if it helps and check the duct that the lint filter slides down into for lint buildup,all a dryer does is spin,heat and move air if it's blocked it will pop the thermal fuse.
Nov 26, 2017 | Maytag Dryers
My Maytag Performa dryer is not heating at all .What should i do? Everything else works it just doesnt heat.
Hi
Replace the thermal fuse, and if possible test the heating group (thermostats and element or gas heater). You can replace the fuse straight away, or you can first test it using a multimeter set on OHMS. If the multimeter reads Ohms infinity when you touch the fuse contacts with its probes, then the fuse is gone.
If the fuse is OK, then you can have a defective thermostat or heating element (electric models), with gas models you test coils, thermostats and ignitor (flame sensor rarely fails).
After fixing the problem clean lint from air ducts, if the thermal fuse or thermostat has blown it means that there had been overheating.
May 09, 2011 | Maytag Dryers
Dryer was running and then suddenly stopped. I have checked the power breaker and it is fine, light is on in the machine, and there are no issues with the plug. When I opened the door it was very warm...
check and see if it has blown either of the 30 amp fuses supplying the 220 volts. More likely the duct heater sensor. Small sensor connected by small wires on the air duct found after you remove the front panel.
Oct 16, 2010 | Maytag Atlantis MDE7400AY Electric Dryer
Will not get hot
Check the blown fuses and home’s circuit breaker tripped. Dryer use 2 household Fuses or a circuit breakers, Replace the Fuses or reset the circuit breaker. Make sure that the lint filter and exhaust duct is clean.
Another common cause of a dryer failing to heat is a faulty heating element. You will need to replace it.
Good Luck and have a nice day.
Rating the solution is highly appreciated
Jun 30, 2010 | Maytag SDE3606A Electric Dryer
Maytag performa Keeps blowing Thermal Fuse. Vents are clean. Cleaned entire system. Seems to heat up as soon as dryer cuts off.Changed control thermostat as well. Can get one load and replace fuse.
something is still plugged with lint,if the vent line is long blow it out with a leaf blower to clean it out,you have to clean out the duct that the lint filter slides into,if the filter is on top remove the vent line,remove the back panel,remove the lint filter and the two screws in front of it and remove the four screws and clean out the duct,if the filter is in front take off the bottom panel,remove the filter and clean the duct,also vac out the inside of dryer where the motor is,when the dryer gets to hot the thermal fuse pops as a safety so you still have a block somewhere
Mar 19, 2010 | Maytag PYE2300AY Electric Dryer
My dryer turns, but it doesn't dry my clothes. After drying several time they are still damp
, your vent duct is probably obstructed (it happens over time). If your model is the type where you could feel air if you removed the lint trap, do so and turn the dryer on. If you get warm air there... you know it is in the ducting, in the back of the machine, or at the wall vent. Pull off your duct, and give it a good cleaning. Clean out the back of the machine, and the wall vent. When you reinstall the ducting, minimize any twists and turns possible.
If the coils are good, but you get no heat, the problem may be the thermostat or the motor switch.
Aug 11, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Maytag portable dryer DE50, no power. Does this
Make sure there's power getting to the dryer. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power with a voltmeter or by plugging something else in.
If there is power available for the unit, thsi will lead to a busted thermal fuse.
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Note: It is recommended by most dryer manufacturers to replace a hi-limit thermostat when replacing a thermal fuse.
Jul 22, 2009 | Dryers
No power to machine.
HI, check the following to address this issue.
1. No power to the dryer
2. Door switch / Door switch actuator lever
The dryer would not start with a broken door switch. Replace the door switch if found defective.
Most dryers have a door switch actuator lever - when you close a dryer door, it presses against the lever, which actuates the door switch. If the lever is broken, the switch would not activate and the dryer would not start. Replace the lever, if broken.
Note: Door switch actuator lever usually comes with the door switch assembly and it is recommended to get the whole assembly since there is almost no price difference between the door switch assembly and just the lever. Check your model for more details.
3. Thermal fuse
4. Timer
Replace if defective (note: uncommon problem).
**The most common issue here will be a defective Thermal fuse
Jul 12, 2009 | Maytag Atlantis MDE6400AY Electric Dryer
Maytag Ele. Dryer Model # lde7334a
There's no heat If your dryer doesn't heat, check these:
Power from the house
Heating element
Thermal fuse
Wiring
Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Mar 31, 2009 | Dryers
Dryer will run in cool down mode,but not in any other.
Hi!
Please check the following---
Heating element
Thermal fuse
Wiring
Please accept this solution and ask for any clarification.
Thanks
Rylee
Mar 22, 2009 | Maytag Atlantis MDG7400AW Gas Dryer
Maytag Neptune MDE5500AY Electric Dryer Logo
179 people viewed this question
Top Maytag Dryers Experts
Tim Whalen
Marvin
Marvin
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
