Question about Nokia 6600
Nokia 6600 ''not charging''
Hi. my nokia 6600 is not charging. everytime i try charge it it says on screen "not charging" and when tries to charge while turned off it stops charging and restarts repeatedly.
i am sure of the battery and the charger, both are good.
plz help me with a simple solution, as the service refused to fix it, bcoz it is not a major problem which will be cheap.
the phone is working perfect other than the charging problem.
i have some soldering skills, but none in electronic parts.
i dont know how to disassemble the phone.
If anyone can help me fix it on my own, i will appreciate this, thanks
  • 1 more comment
  • happyyear Nov 23, 2008
    thanks man i will try it and tell you what happened, hope it works.
  • Anonymous Dec 25, 2008
    It comes On and Off repeatedly
  • Pilipino Piñon May 11, 2010
    Do you have a T6 screwdriver? It's easy disassemble a cellphone, remove you casing, there is 6 screws remove it, remove the lcd and the keypad. don't worry it's removable. check if some piece is detached coz you know how to solder so you know how to check bad soldered piece. check the place where the charger is connected. if you don't see anything, get a laquer thinner and a toothbrush, clean your phone. don't worry it dries fast. clean all the parts on the board but not the lcd. good luck.
    Brigadier General:
  • 7,752 Answers
You should try a new battery
Posted on Nov 23, 2008
When I power on nokia 6600 only white screen for 45 seconds and
CAUTION: if u have any valuable data on ur phone plz dont try this .
first charge ur battery until its full
next switch ur phone on while pressing the green key ,the 3 key and the * key.
hold these till a screen saying 'formatting' comes
allow it to format
it may take 5 mins
dont remove battery or phone system will bcome corrupted
Oct 19, 2009 | Nokia 6600
Menu button for Nokia 6600
try a manual format for your phone
hold call sign + # sign + number 3 and on button simultainously
wait for the "formatting" in the screen
then release all make sure it's full charge
Apr 27, 2009 | Nokia 6600
Hi name pawan's my handset nokia display is blanck.......... so help me..
first is your phone batery charged?
second if the batery is charged and you cant see anything try to dial a friend number that is with you, if the call is giong is meaning your phone is ok and you should replace your screen phone.
Apr 04, 2009 | Nokia 6600
Not charging for nokia 1100
good evening ! the problem of your phone is the resistor 100 try to chagne that , that`s located at the mother bord! R100 GOOD LUCK ....
Sep 08, 2008 | Nokia 6600
NOKIA 6600 wont charge and turn on
hey,
how about check your charger .. maybe there is a problem with your charger... try another nokia charger
Cheers
Aug 28, 2008 | Nokia 6600
Nokia 6600 Cellular Phone Problem
A. Blank screen phone unable to boot-up. B. Phone is only able to boot-up to “Nokia” screen (may flash “Nokia” 4 times also).
C. Install a program but unable to uninstall it.
D. Unable to delete certain files on C drive.
WARNING: This will ERASE EVERYTHING on your phone
If you have any files that are important to you, make backups.
1. Make sure you phone is fully charged.
2. Backup your contacts list and personal files to MMC memory card (if possible).
3. Switch-off your 6600 phone.
4. Press and hold these three keys together
-Green dial key,
-Star key (*)
-Three key (3)
then press the power on/off to swtich on the 6600 phone.
DO NOT let go the three keys until you see the “formatting” screen displayed
5. After a few minutes, the format will be complete. Your 6600 will now be at its original factory settings.
Disclaimer: I will not be held responsible for anything that happens to your phone as a result of following my guide. Use this guide at your own discretion and risk.
Low feed backs hurt my ratings and I tried my best to help you with your problem,Show your Appreciation by rating it:
email id-johny_inmexico@yahoo.co.in
May 10, 2008 | Nokia 6600
6600 nokia
try to reformat ur fone by hard format
Sep 24, 2007 | Nokia 6600
Nokia 6600 does not open
aapko apne cellular phone ka software update karna hoga
Sep 18, 2007 | Nokia 6600
Not formatting Nokia 6600 completely.
Hie jack_ridar , Try to charge your battery fully using another mobile or use a fullly recharged battery which is compatible with nokia 6600 and then try to format it again and i hope it will help. All the best. Thipa
Aug 31, 2007 | Nokia 6600
Nokia 6600 Logo
158 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
