Question about Cozy (W352E) Heater
Cozy wall furnace - unattached wire, won't turn on
Taking off the door at the bottom of the wall heater, there are
are 2 blue wires (heavier weight than the pilot/themostat wires) coming from above. One plugs (with a plastic sheath) into the front of the hardware that the pilot & thermostat wires are attached to.
The other one has come unattached and it is not clear where it goes. The pilot and themostat wires are attached. The heater won't go on when turned on.
Where does the loose blue wire attach and can I do this myself?
Thanks
  • twocold1s Dec 03, 2008
    hi i have simalar problem. pilot is lit, limit is closed, 150 mv, model#w355er, tstat ok but main burner no working. 2yrs old
  • 306 Answers
Sounds like one of your limit switches lost it's wire. Look for a disc like device no more bigger then a 50 piece. You will see two wires going to that and if the wire broke take off the insulation and install new plastic sheath and re-attach. Let me know it that is helpful. ken
Posted on Nov 26, 2008
Pilot lamp is lit but the Cozy Thermostat will not operate the furnace valve to turn on. Is there a test to check whether it is the thermostat or valve inop?
pull the 2 wires off of stat and twist together if unit come on its the stat if not go to the gas valve and jump out to see if the valve will come, the 2 th terminals.
Oct 31, 2010 | Cozy (W352E) Heater
My wall unit cozy heater goes on when I turn on the thermostalt but it goes out one minute later. What is the cause?
by pass the wall stat, pull the 2 wires off stat and twist together and if unit runs ok it is the stat if it does the same thing by pass the stat wire by disconnecting the stat wires from the valve a put a jumper wire between the (th) terminals.
Oct 10, 2010 | Cozy (W352E) Heater
Cozy wall furnace (propane) does not respond to thermostat. The pilot is lit. Furnace is 3 yrs. old and rarely works. The wire to thermostat is 20 feet.
Try jumping the two thermostat wires together to see if the heater starts. If so, replace your thermostat. If not, jump the two terminals where the thermosta twires attach to the furnace. If it starts, you have a bad thermostat wire or connection.
Jan 30, 2010 | Cozy (W352E) Heater
What is easy way to replace the thermostate in
Hi, that thermostat should be a wall mount. This heater has only 2 wires and any "Heat only", "millivolt" thermostat will work. Remove the old T-Stat and mount the new one on the wall, only 2 wires and less than a volt so no shock danger, doesn't even matter which wire goes where. Good luck and comment back if you need any help.
Jan 09, 2010 | Cozy Heating & Cooling
Is there an air filter for my ''Cozy'' Counter Flow Wall Furnace
Cozy most generally doesn't provide a place for a filter in its wall furnaces. I have seen people secure a typical house filter to the outside grill where to return air enters. It's cheesy but works.
Mar 15, 2009 | Cozy CFR Utility Heater
Cozy wall heater lights fine then goes out after 3 or 4 minutes
Make sure all the wire connections are good and tight. Next lift off the cover and look for a little thermal disc mounted up by top of the heat exchanger. Most have a re-set button but not all. If you have this ,by-pass it ,see if that solves the problem, if so it may be defective, or doing its job and you have a venting problem. If you don't have this and have changed the thermocouple (was it a copper tube with a fitting that screwed into the gas valve, or did it have 2 wires, that is a pilot generator, kind of same thing) make sure the probe is set correct, with the pilot flame heating the top 1/3rd of the probe. The only thing left is the gas valve.
Dec 19, 2007 | Cozy (W352E) Heater
Cozy one sided wall furnace (no blower motor)
This is a weird one, but make sure all the wire connections are in the correct place. I accidentally miss wired a heater like this and it did the same thing.
Nov 27, 2007 | Cozy (W352E) Heater
Cozy (W352E) Heater Logo
710 people viewed this question
Top Cozy Heating & Cooling Experts
Paul Carew
vance jones
Tim Whalen
Are you a Cozy Heating and Cooling Expert? Answer questions, earn points and help others
