I have a H-P Compaq Presario A900 Notebook PC and it came with a Canon Pixma MX310 all in one printer. It has windows vista 2007 on it (computer) and one of the instructions says to open the vista program and I don't understand what that means. Also the printer did'nt come with a usb cable. I have wireless internet if that matters. I don't understand how to hook it up to the computer and I followed the instructions. Help
  • 33 Answers
To install the printer do this:
When installing a new printer with the Add Printer Wizard, you can choose between adding a local printer (one that's directly cabled to your computer through one of the ports) or a network printer (a printer that's connected to your network with an Ethernet connection, just as your computer is connected to the LAN).
To install a new local printer with the Add Printer Wizard, follow these steps:
1. Click the Start button on the Windows taskbar and then click Control Panel on the right side of the Start menu.
2. Click the Printers and Other Hardware hyperlink if the Control Panel window is in Category View.
Otherwise, double-click the Printers and Faxes icon if the Control Panel window is in Classic View.
3. Click the Add a Printer hyperlink in the Printers and Other Hardware window to start the Add Printer Wizard and then click the Next button, or press Enter to advance to the Local Printer or Printer Connection dialog box.
4. Make sure that the Add Printer Wizard selects the Local Printer radio button, and the Automatically Detect and Install my Plug and Play Printer check box beneath this radio button before you click the Next button.
5. If the wizard is unable to detect your printer in the New Printer Detection dialog box, click Next to install the printer manually.
6. Select the port for the printer to use in the Use the Following Port drop-down list box in the Select a Printer Port dialog box and then click the Next button.
7. Click the manufacturer and the model of the printer in the Manufacturers and Printers list boxes, respectively, of the Install Printer Software dialog box.
If you have a disk with the software for the printer, put it into your floppy or CD-ROM drive and then click the Have Disk button: Select the drive that contains this disk in the Copy Manufacturer's Files drop-down list box and then click OK.
8. Click the Next button to advance to the Name Your Printer dialog box.
If you want, edit the name for the printer in the Printer Name text box. If you want to make the printer that you're installing the default printer that is automatically used whenever you print from Windows or from within a Windows program, leave the Yes radio button selected beneath the heading, Do you want your Windows-based programs to use this printer as the default printer?
9. Click the Next button to advance to the Printer Sharing dialog box.
If you want to share this printer with other users on the network, click the Share Name radio button and then, if you want, edit the share name (this is the name that the other users on the network see when they go to select this printer for printing their documents) that the wizard gives the printer in the Share Name text box.
10. To print a test page from your newly installed printer, click the Yes radio button selected beneath the heading, Would you like to print a test page? in the Print Test Page dialog box.
11. Click the Next button to advance to the Completing the Add Printer Wizard dialog box, where you can review the settings for your new printer before you click the Finish button or press Enter to finish installing the new printer.
To use the Add Printer Wizard to install a printer that's available through your Local Area Network, you follow just slightly different steps:
2. Click the Printers and Other Hardware hyperlink if the Control Panel window is in Category View. Otherwise, double-click the Printers and Faxes icon if the Control Panel window is in Classic View.
3. Click the Add a Printer hyperlink in the Printers and Other Hardware window to start the Add Printer Wizard and then click the Next button or press Enter to advance to the Local or Network Printer dialog box.
4. Click the A Network Printer or a Printer Attached to Another Computer radio button in the Local or Network Printer dialog box and then click the Next button or press Enter to the Specify a Printer dialog box.
5. If you know the name of the network printer, click the Connect to This Printer (or to Browse for a Printer, Select this Option and click Next) radio button and then enter the network path in the Name text box.
If your network printer is on a network that uses an Internet address and you know this URL address, click the Connect to a Printer on the Internet or on a Home or Office Network radio button and then enter the address in the URL text box. If you know neither of these pieces of information, leave the Browse for a Printer radio button selected and then click Next to advance to the Browse for Printer dialog box.
6. In the Browse for Printer dialog box, locate the printer in the Shared Printers list box by clicking the network icons until you expand the outline sufficiently to display the printer icon.
When you click the printer icon in this outline, the wizard adds the path to the Printer text box above.
7. Click the Next button to advance the Default Printer dialog box.
8. Click the Next button to advance to the Completing the Add Printer Wizard dialog box, where you can review the settings for your new printer before you click the Finish button or press Enter to finish installing the new printer.
After you add a printer to your computer, you can start using it when printing with programs such as Word 2002 and Excel 2002, or when printing from Windows itself.
Posted on Nov 23, 2008
I need a manual for my canon mx310 please
Canon U.S.A. : Windows 7 : PIXMA MX310
www.usa.canon.com > ... > Multifunction Printers > Inkjet
Canon Inc.File Name: MyImageGarden_V3.2_Mac_EN_V01.pdf. Language: English. This file is the exclusive manual for My Image Garden. It contains the usage of My ...
[PDF]Quick Start Guide
gdlp01.c-wss.com/gds/7/0300000437/01/mx310_qsg_us_v1.pdf
Sep 1, 2007 - Canon PIXMA MX310 series Office All-In-One Quick Start Guide. Copyright. This manual is ..... Refer to the instruction manual supplied with the ...
Nov 13, 2015 | Canon PIXMA MX310 All-In-One Printer
Tip
Drivers and Manuals for PIXMA MX310 Windows and MAC OS
Here I will show you where to find drivers and manuals for the Canon Pixma MX310 Office all in one printer.
Drivers for this printer are available for Windows 98, windows ME, windows Xp, Windows Vista, windows vista 64bit editions, windows 7 and windows 7 64bit editions.
On the Mac side drivers are available for Mac OS X 10.2/10.3/10.4/10.5/10.6
A full on screen manual, quick start guide and other instructions are also available.
To download these drivers and or documentation for your printer please visit
THIS PAGE
Note that the picture below reads mp730 but the actual page linked will be for Mx310
1. Click on Drivers & downloads
2. Select your OS ( Operating system, windows, mac etc )
3. All available drivers, documents etc will be available below.
For some of the documents a PDF reader may be required to open and read / print them.
To obtain a PDF reader, read this page
PDF Documents. Pdf reader(s)
Thank you for reading and I hope your printer is up and running again.
-Ekse
on Mar 11, 2010 | Canon PIXMA MX310 All-In-One Printer
Canon mx310 printer is offline and won't print from computer
Hi Harry,
Try re-installing the printer again.Disconnect the printer completely from your PC.Uninstall the printers software from your PC and then reboot it.
Insert the installation disk and run setup to install a fresh the printers driver.If you don't have the installing discs,download the drivers from this canon support site.Select the driver that corresponds with your Operating System[Windows XP,Vista etc].
Hope this helps.Thanks!
Please rate this answer.
Nov 20, 2011 | Canon PIXMA MX310 All-In-One Printer
I can't connetc mx310 to my new computer. The computer is running windows vista. Do I need to download a seperate software ?
The printer drives varies with OS, even if the printer is of the same model. So goto canon website and specify your printer model and OS, download appropriate drivers and install it in Vista. Then you are good to go.
Mar 28, 2010 | Canon PIXMA MX310 All-In-One Printer
How do I send a fax with the mx320. can't find my instruction booklet
From the Canon Website, here are some manual and publications.
Guides and Manuals File Name and Description Version File Size Date Posted MX310 series On-screen Manual (Windows 7/7 x64/Vista/Vista64/XP/XP x64/2000) mx310sosmwin110us.exe 1.10 11.17 MB 11/09/2007 MX310 series On-screen Manual (Mac OS X 10.2/10.3/10.4/10.5/10.6) mx310sosmosx110aus.dmg 1.10a 16.24 MB 01/21/2010 MX310 series Quick Start Guide mx310_qsg_us_v1.pdf V1 5.02 MB 10/04/2007 MX310 series Easy Setup Instructions mx310_esi_us_v2.pdf V2 2.96 MB 10/04/2007 dot_line_sm.gif
Brochures File Name and Description Version File Size Date Posted Multifunction Brochure MX310.pdf 1.0 1.14 MB 05/11/2009 spacer.gif
good luck
Feb 18, 2010 | Canon PIXMA MX310 All-In-One Printer
Is compaq presario laptop A900 compatible with window 7??
Theoretically yes, since it has vista drivers. Practically, if you can't find compatible drivers from another hp laptops with the same hardware, no.
Jan 22, 2010 | HP Compaq Presario CQ50-140US NoteBook
134 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
