SanDisk Sansa e250 MP3 Player Logo
liv johnson Posted on Dec 27, 2006
Can i use limewire?
I have limewire on my computer and i don't know how to get the songs from limewire to my sansa e250. can anyone help?
  • Anonymous Nov 10, 2007
    i want to copy songs from limewire to sansa e250
A
Anonymous
I just use WMP to sync files between my Sansa and my library.
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on May 17, 2007
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
65
Points
1)Here's what you do in the file that all of your music is in- make sure you highlightthat file 2)E.G if the files name is Audio or shared files 3) once its highlighted look the button that says explore once you do that a window will pop up with all your music4)Then right click the song you want and click add to playlist 5) if you made your own playlist then you put it in yours-- i put mines in johns playlist5 6) keep doing that with all the music you want. then open windows media player connect your sansa. and go to the sync button. 7) click edit playlist and then open the playlist that you put all the music into..................once your ready click start sync.................GOoD lUcK
A
Anonymous
Yeah you need to copy and paste them on the mp3.
Transfer of mp3 files from limewire
on some systems you have to give the music a destination,example,My Document,or My Music and if windows media player is the player on your system,then it should let youplayit or transfer it to yout mp3 player
SanDisk Sansa Clip
Use Windows Media Player to transfer the songs downloaded from Limewire to your Sansa. The first time you open Windows Media Player, it will search the "My Music" folder for songs - this may take a few minutes. Mkae sure you have Windows Media Player 10 or 11. You can either move or copy the Limewire songs to the folder called "My Music," or go into Windows Media Player and change Windows Media Player's configuration so that it can read the Limewire downloads folder.
-Tha Mp3 Doctor
2answers
How do i delete songs
1st plug your sansa into the computer then go to my computer and click on the sansa e 250 icon then click on the "media folder" and after that click on the songs folder then a bunch of folders will come up click on these and they hold your songs from there you can delete them.
My Mp3 player wont turn on
Mysify, I had a similar issue, one of the songs you added is likely unplayable by the player, here is what i did, I cleared all songs out and it will refresh, then just add 10 songs at a time until you get to the same problem, then remove then 10 and try adding them one by one, I know it's tedius but it worked well for me.
Cheers,
Nic
Sansa e250
There are two ways you can delete the songs...
First. you gotta connect it via usb to your pc, go to programs - accesories - windows explorer, find the SanDisk in my computer, go to media, music and delete them from there.
Second, go to my computer, click sansa e250, and just delete the songs, pics, albums, that you want to from there.
Hope this helps
Please rate accordingly
Thank you
Computerrep
2answers
Don"t know how to trans fer music i bought from itunes to sansa e200 2gb plae?r
Try downloading the Rhapsody Real player app, and import your Itunes file to the Rhapsody library. The files will be converted and will be able to be transferred to your mp3.
My sansa e200
-Plug in your mp3 player
-Go into 'Limewire', select a song and go 'Locate file/Open Containg Folder', you should be in your folder with all your songs. or go 'My Music' and find your music files.
-Either select all your songs, open them with 'Windows Media Player' and transfer them that way.
-Or 'Open My Computer' then open 'Sansa e200' and drag the songs from where your songs are located [My Music] to the 'Music' folder in your Sansa e200 folder.
[MyMusic] Song.mp3 >drag to> [MyComputer/Sansa] Music.
2answers
Deleting songs
Chances are that you are using windows xp. open up your sansa folder to where it says pictuer, movies, ect. look at the picture to see what to do. In your player folder click tools --> folder options --> View. Under hidden files and folders click 'show hidden files and folders, click ok. The music folder would now show up where the videos and pictures are. Simply open the music folder and delete the ones you do not want. By default the songs are sorted by artist --> album --> song.
4answers
Can i use limewire?
step 1; down load songs from lime wire. step 2; go to lime wires library, and about half way down the page there is a button called explore. click on it. step 3; open windows media player, and click sync. a list should show up, step 4; click on songs on shared folder, and drag to sync list. step 5; connect sandisk, and click synk to e 250 on upper right hand corner area, and wait for sandisk to write! hope this helped!
Top SanDisk Audio Players & Recorders Experts
SmartAviator
SmartAviator
Grand Canyon Tech
Grand Canyon Tech
Alexander
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
